Question about Nokia Cell Phones
My nokia c5-00 camera not open when am try to open then it will close without open in 0.001s
My nokia x3-01 meun button not working
open yoyr mobile and clean all buttoons properly and close your mobile then try menue button
May 18, 2012 | Nokia X3-02 Touch Type Dark Metal Unlocked...
My nokia 5300 camera is not working.As soon as i open a camera mode it says camera on standby and operation failed
Switch off the phone, remove the memory card and boot again without the memory card. Now try accessing the camera, hope it's working now. I would suggest you to scan the memory card or format it (i recommend formatting the memory card so that it'll not fail).
If the problem persists even without the memory card, reset your phone's settings to Factory Default by going to the Settings > Restore Factory (open the settings, press up key once, you'll see the "Restore Factory") using the code 12345. Your phone will automatically restart. Now try again with camera.
If both the above methods don't help out, your only option is to flash the phone or update the firmware. But I don't recommend do these yourself, a small mistake or incomplete will damage the phone or will create more problems. You can visit any service center or any mobile repairing center and get it done with a small fee.
Good luck.
Thanks for using FixYa.
Aug 10, 2010 | Nokia Cell Phones
My N73 back camera auto opens at anytime, closes and reopens again without using the slide
if you have tat problem then there is problem in your back panel if you change it your problem wil be solved
Feb 03, 2010 | Nokia N73 Cellular Phone
I keep having an error come up saying Messaging: Memory full close some applications. I have also had an error saying General: Memory full close some applications. I have no applications open can you...
clear your browser cache as well
set your messages in messaging - options- settings - other to 999 and e memory.
restore factory settings *#7780# default code is 12345 that might just might help you a bit and turn off and on your phone when you do all these things see if it helps any.
“Memory Full…Close some applications and try again” is a normal
message that usually comes on Nokia N70. It showed the memory used in the phone doesn’t have space anymore. But if the message still appears although the user already closed some applications it can be theproblem.
Someone who experience in this memory full problem said, an error message of memory full like above is appears each time he’s opened the
Camera. It also happens for a few times when he’s trying to open
messages, Gallery, or other applications. And then it will force to restart the phone.
Seems like it’s a RAM problem and might there are some applications unable to close completely. If your Nokia N70 phone has gone a start
menu button you can try to hold it down. This way will show you
everything that you have open and they can be closed easily so that
you can continue to take your photos.
So if it can resolve the problem you can reset/format by pressing *#7370#
Oct 30, 2009 | Nokia N97 Cell Phone
Video camera is always closing everytime i use it..how can i fix these??
its more like this three thinngs
1. try back up your information and try to use this code to restore ur fone. *#7370# and it will ask you for code put 12345. i beliv that should remove the virus
2. remove your memory card and try to use the camera without memory card
or maybed the case is not good
best of luck
rate this
Oct 24, 2009 | Nokia N70 Cellular Phone
Cannot eject finalized disc
Try turnin the camera to the side where gravity will help pop open the disc and be careful not be keeping it close with your own hand. Its a thin cover and you can accidently be holding it close without knowing.
May 24, 2008 | Canon DC10 DVD Camcorder
Nokia n73 front camera not working
did you see the manual of your phone? please try to close the camera at the back then try to open the camera.
Mar 21, 2008 | Nokia N73 Cellular Phone
NOKIA N73 CAMERA FOCUS
good day, you have many open programs in your cp, try closing other running programs and start your camera again. tnx
Feb 03, 2008 | Nokia N73 Cellular Phone
Cell Phones Logo
27 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
