Question about Focupix Office Equipment & Supplies
My motorised focupix screen has retracting issues? how should I fix it?
It is 120"screen and is controlled by an RF remote. It has retracting issues.
4 Suggested Answers
SOURCE: DirecTV RC64R RF Remote control
Actually, you can go into the system settings by choosing "Parental, Fav's & Setup" then choose "system setup" then choose "remote" the IR/RF setup. Change it to IR and follow the instructions. Once I did that my remote worked on my DirecTV DVD HR22-100
Posted on Nov 22, 2008
  • 3197 Answers
SOURCE: garage door remote control signal problem
On the rear of the motor unit just to the left of all those white wires you will find a small LED. Random flashing is normal but if it is flashing rapidly it shows some type of interference. If this isn't happening then the most common thing is a logic board going bad.
Posted on Sep 01, 2009
  • 3197 Answers
SOURCE: Craftman 1/2 garage door. Model 13953879. RF intereference issue
Limited range of your remote controls could be related to radio frequency interference that comes from something in your home or in the surrounding environment. Certain electrical devices can radiate interference; this could be almost anything that is plugged into an electrical outlet.
Please keep in mind that the device can be brand new, or can be an item that has been in use for quite a while. Also, the item may continue to function properly as far as you are able to tell. The only problem with the item may be that it has started to broadcast the interference, with no other symptoms noted.
Some devices are more likely to generate interference than others. This includes TV cable, cable amplifiers, surge protectors, fluorescent lights, battery charging devices (power tools, golf carts, etc.), anything that utilizes a timer (sprinkler systems, lights, alarm systems, etc.), and a myriad of others. If the problem seems sporadic, we can safely assume that the device responsible for the interference is only being operated during these times. Again, please keep in mind that the age of the device does not determine if it is capable of broadcasting unwanted interference. Any electrical device can be the source of the problem.
The first step is replacing the battery in your remote. If the range on your remote does not improve, remove the wall control wires from the overhead unit. If the range does not improve you will likely need to replace the remote control. After replacing the remote, or if you have other remotes programmed in to the opener, and the range problem still exists, please proceed to the Power Down test.
Multiple garage doors:
If you have two garage door units and one is working just fine, you will need to start by unplugging the good unit. This will help determine if the unit with no range starts to function properly. If the range comes back to the bad unit then you will need to replace the logic board on the unit that was unplugged as it is emitting an RF signal that is over powering the other garage door opener. If the range does not improve after the “good” unit has been unplugged, replace the batteries and try programming some additional remotes to determine if the existing remotes are the issue. If the extra remotes do not have any range then you would need to replace the receiver logic board in the “bad” unit.
Power Down test:
To isolate potential sources of interference, turn the circuit breaker off to the garage and plug the garage door opener into an extension cord from another room. If the range improves, then the interference is coming from a device in the garage. If no improvement is seen follow the same procedure, this time turning off the circuit breakers to your home, with the exception of the garage and test the remote controls. If improvement is noted, turn the circuit breakers back on, one by one, until the range problem resurfaces. This will allow you to narrow down what room the problem device is in. You will have to go from there to isolate it further, by unplugging and re-plugging the items in that room.
If you are unable to determine any source of interference, then the receiver logic board in the overhead unit will need to be replaced.
Posted on Apr 19, 2010
Screen wont retract all the way up in ceiling
Assuming your screen a motorised type and is able to move down and up when you press the remote, it means that the motor is working well. 2 possible reason are:-
1), The limiter mechanism to stop the movement for the up and down position is faulty or misalign. Up limiter in this case require check and realignment.
2), The end of the screen ( the bottom ) while closing ( move up ) stopped too late, over shot and it fell down on the other side causing that extra length hanging. Up limiter in this case require check and realignment.
Pls contact your local Dalite support if you are unable to find a repair man.
Jan 20, 2011 | Da-Lite (84402) 133" 16:9 Projector Screen
LCD screen will not turn off
this sounds like it is a hardware issue. i suggest that you contact logitech for further information about the issue your having. be ready to give the following informaiton.
The PID of the remote:
The P/N of the remote:
The PID of the RF Wireless Extender:
The P/N of the RF Wireless Extender:
Full Name:
Phone number:
Zip/Postal Code:
Please Note: The PID (Product Identification) and P/N (Part Number) for the remote can be found either on the underside of the battery cover, or at the bottom of the battery compartment (the battery might be covering it). Your PID number is a character code with a combination of letters and numbers, starting with either WL, WD, or LZ
also, try performing a firmware upgrade as well.
1. Log into the Logitech Harmony Remote Software on your computer
2. Click on the Downloads button at the top-right corner of your screen
3. Click on the Firmware button. Follow the onscreen instructions to upgrade the firmware on your Harmony remote
4. Once the firmware upgrade is complete, click on the Update Remote button
5. Test your remote.
Jan 18, 2010 | Logitech Harmony 890 LCD Remote Control
Ceiling installation of pull down screen
Found the correct clips (at an acustical supply store) needed to install the 120" Projector Screen to the 'drop' ceiling in our office. Thanks anyway.
Jan 26, 2009 | Focupix 4:3 Standard Format Manual Pull...
URC-9910 remote: The RF part for this remote stopped working.
I have the same remote as yours and occasionally the RF remote is not working due the interference signal from outside or next door at certain hours.
My suggestions:
(1) To relocate the receiver and reposition the anntena for better reception of the RF signal from the remote unit.
(2) Replaced the battery.
Hope these help!
Aug 04, 2008 | One For All URC-9910 LCD Remote Control
Cannot interface with harmony rf wireless extender
the One doesn't have rf capabilities, so you can't use an rf extender
Jun 08, 2008 | Logitech Harmony One Advanced Universal...
76 people viewed this question
Top Focupix Office Equipment & Supplies Experts
Are you a Focupix Office Equipment and Supply Expert? Answer questions, earn points and help others
