Question about Home
Why my 300 fluidmaster won't let my toilet tank fill unless I smack the side of the tank or turn a tap in the bathroom on
    Top Expert:
  • 48,245 Answers
Replace the inlet rubber washer
Posted on Dec 11, 2016
First shut water off at stop than flush all the water out of the tank next take a sponge and get all the water out of tank next unsrew the supply line from the valve under tank than move out of the way next unsrew the nut on the valve of fluidmaster than pull the fluidmaster out of tank stick the new fluidmaster in tighten nut srew the supply line back on turn on stop and let the tank fill up thats it if the fluidmaster dont shut off press the handle let some water out and adjust the fluidmaster screw Tip the water should stop a 1/4 inch below the flush valve tube in center of toilet
Jul 11, 2016 | Fluidmaster Plumbing
How to adjust fluidmaster
There should be a small black rubber tubing piece that connects to the fill valve and the other end goes in the overflow tube to refill the bowl after each flush. Make sure this tubing is installed correctly and that should solve the problem. Hope this helps.
Jul 03, 2014 | Home
Fluidmaster fil valve float sticks
Give it a slight turn to stop it from rubbing on the side
Nov 26, 2013 | Fluidmaster 400A Toilet Tank Repair Fill...
I have a fluidmaster 200a and my toilet tank won't refill unless I push the metal rod down
Plastic pieces inthere that give up after a while. I would go ahead and replace the assembly. But try this first,disassemble the top of the valve assembly and remove any debris. It could be the problem. There are rubber and
Jan 13, 2013 | Home
300. Why does it occasionally get stuck in the up position or fails to refill tank completely?
It has been my experience that they are reliable. Fluidmaster instructions say to flush the valve (not the toilet) after installation to purge debris. It may be necessary to do this again. Also check for interference with the refill tubing. The float and linkage should be able to move freely.
Oct 10, 2012 | Fluidmaster Fill Valve and Flapper Repair...
The toilet flushes but it won't fill. I can turn the water supply off and then back on, then it fills normally.When the tank is full, I can push the float down and no new water enters. when I flush,...
Hi!please kindly check your fill valve if it is working correctly.I thought the problem is in your fill valve.Kindly adjust the floater of your fill valve.
Aug 24, 2011 | Kohler Home
After flushing the toilet with the fluidmaster 300 installed, and during the tank refill, the refill valve emits an extremely high pitched squeal until just a second or two prior to the tank being...
hiya:) This is a result of a very minor design error (i am a big fan of FluidMaster products) combined w/a slightly higher than normal water pressure situation or foreign matter stuck in the valve somewhere. try turning down the water pressure via the shuttoff under the toilet tank:)
Jul 26, 2011 | Home
I've just installed a Fluidmaster 400 Series. When I flush the toilet, it doesn't refill the tank unless I tap the Float.
The first thing I would check is to make sure that the body of the float or the linkage that connects the float to the top of valve are not rubbing on inside of the tank and stopping it from moving freely.
Also when tank is full hold float down so that all air that is inside the top of the float is let out. I hope this hepls you. Thanks.
Jan 21, 2011 | Fluidmaster Plumbing
I have fluidmaster in my mancesa toilet. After flushing the toilet tank doesn't refill unless I turn off the water supply and turn it back on. What do I do to fix this problem. Wayne
First thing to do is figure out if the problem is with the fluidmaster or with the shutoff valve. If the water doesn't run at all after flushing, then instead of cycling the shutoff valve, just loosen the nut where the supply tube attaches to the fluidmaster (under the tank). If the problem is in the fluidmaster, it will start to squirt out at you, otherwise it won't. Then you know what to disassemble and attempt to repair, or replace.
Jan 29, 2010 | Fluidmaster Plumbing
Home Logo
148 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
