Error message 33 what does it mean? I ve tried both arms.
EC ERROR CODE
It means the unit is low on gas
May 19, 2014 | Midea Heating & Cooling
Error 5B00
If you google it the error and it should tell you what it means. Or go to a printer problems website and type in the error message. I've had google error messages and they came up.
Jul 21, 2012 | Office Equipment & Supplies
Singer Futura CE-250 error 6 when I am just sewing
This error means that the arm is not getting the electronic information with the main machine.Make sure the arm is "leveled' with the main machine. I found this out moving gently the arm up or down. I use a piece of thick paper folded in half and put it under one side of the machine (usually the front part of the arm) and then the arm moved showing that the connection was successful. Hope it make sense and helps!
Nov 04, 2011 | Singer CE-200 Quantum Futura Computerized...
Computer says that the cartridges are in the wrong slots- which they are not. I have tried switching off and on -no effect, same message.Error 1102 The only thing that is different than usul is that I...
Turn the printer off.
Disconnect the AC power cable from the wall-outlet, to make sure that is "100%-OFF".
Reconnect it.
Remove that #33 cartridge.
Does that get rid of the "wrong" message?
Reinsert that #33 cartridge.
Does that message still appear?
Have you returned the "defective" #33 cartridge to where you bought it, and gotten a replacement for it, and installed that replacement cartridge?
Mar 25, 2011 | Lexmark X3650 Printer
Printer says cartridge error: error 1203
Remove both ink cartridges and check the bottoms to be sure all of the tap is removed. Small pieces of tape frequently are stuck to the cartridge bottom causing errors. Confirm you have the correct cartridges (# 34 for Black(HIGHYIELD) and #33 for color). Reseat the cartridges and try again.
Sep 06, 2010 | Lexmark X7170 All-In-One InkJet Printer
Has 33 minutes and a error message of nd--maytag Neptune tl
What is the Model number of your machine if its a FAV6800A or FAV9800A please read on.
The ND error code means No Drain.
You could have a drain line clog or a stuck Pressure Switch contacts.
See this post for past troubleshooting;
http://www.fixya.com/support/t2209123-code_nd_fav6800aww_serial_number_10
There are links to the Service Manual and I go over how to put the machine in Service Mode to check that the Pressure Switch is signaling properly.
Do you want to DIY the repair?
Let me know.........Rich
May 19, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Have error code 33 on dash what does it mean 08 model r1
Error Code 33 means that there is problem an
Open circuit detected in the
primary lead of the cylinder-
#1 ignition coil.
• Open circuit in wire harness.
• Malfunction in ignition coil.
• Malfunction in ECU.
Hope this helps
Mar 02, 2010 | 2008 Yamaha YZF-R1
Inputting new ink cartridges
Error 1102 means cart error. Try cleaning the copper contacts on the cart and the contacts in the printer also. If still fails, then put old carts and check if u still get same error. If u dont get the error then there is a problem with the cart itself. But if you have bought a refilled cart then the print heads on the carts are bad. Needs replacement.
Sep 19, 2007 | Lexmark P4350 All-In-One InkJet Printer
26 people viewed this question
k24674
jasbo
jasbo
