Question about RIM BlackBerry? Curve 8330 Cellular Phone
Blackberry 8330 voicemail problems
I cannot access my voicemail. When I call voicemail, I get a recording stating that my call cannot be completed. I'm out of the US, (home) but am still getting voicemail. Any idea on how to get my voicemail? Thank you!
fkcarroll@aol.com
    President:
  • RIM Master
  • 688 Answers
There should be a prefix used when dialing abroad. check the country where you are at
i believe if you dial the number this way you will get your mail.
add country code for long distance
Posted on Jul 21, 2009
Bought this phone off of ebay and think its hard locked. When I enter a code that I was given it says program lock code has exceeded limits. This is a sprint non sim card phone. Any help would be...
You need blackberry curve 8330 network unlock code for original phone sim network card. But if your blackberry already in hard locked state, you just have one option left to unlock blackberry. Go to your nearest local mobile repair shop and asking them to cable unlock your blackberry, it should be solve your problem. Good luck!
May 15, 2011 | RIM BlackBerry? Curve 8330 Cellular Phone
I pluged my blackberry 8330 onto my xbox360 to
Try to clear your memory card first ,then just put other things inside.
Jul 08, 2010 | RIM BlackBerry? Curve 8330 Cellular Phone
Unlocking my blackberry
There isn't a way around the password on the device. If he enters in the incorrect password 10 times the device should wipe itself, and take the password off. He will lose any unsaved data, though.
If he got a backup on the computer then he will be able to restore it back to its normal state.
Hope it helped.
Nov 26, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Black berry wont play videos that i recorded on it. media players states error message
mine did the same thing, i had to go into my options menu and do a system upgrade and then it started to work perfect.
Nov 11, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
I have the same problem. Any ideas??
Hi, the setting is controlled by your mobile service provider. You will need to ring them and get them to extend the time which it will ring before going to your voicemail. Another option is to totally disable the voicemail function. On your blackberry, enter the phone screen, then press the blackberry logo button to open the menu then select options. Once in the options, select the call forwarding option. Change all settings to "do not forward". Please rate this solution if it helps. Thanks
Jun 08, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Reset to factory specs for blackberry curve 8330
how to reset the Curve back to factory state (a complete wipe-out). Please note if you just want to reboot the device, you only need to take out the battery.
To reset the phone back to factory state:
Go to Options -> Security Options -> General Settings
Press the BlackBerry Menu key and select "Wipe Handheld" and type in "blackberry"
Thanks.
Jun 04, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Blackberry 8330 browser errors
To resolve this error, change the Browser Configuration Emulation Mode using the following steps:
  1. On the BlackBerry smartphone, open the Browser.
  2. Display the menu and click Options.
  3. Click Browser Configuration.
  4. Change the Emulation Mode to Microsoft IE.
  5. Save the changes.
  6. Close the Browser.
  7. Open the Browser.
Apr 11, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Verizon 8330 does not ring
1. Check and make sure you're call forwarding settings are correct. Normally people have it set to ring for 20 seconds, before forwarding to voicemail. Your cell phone company should be able to walk you through what their default setting recommendation is.
2. Is the call making it to the device, but the ringer isn't turned on? Does the screen show INCOMING CALL? If it does, check your PROFILES and find out which one is active and see if the ringer for that profile is set to SILENT.
3. If the call never makes it to your BB, your internal antenna is bad - take it back.. or you get no signal where your at. Basic troubleshooting for the BB should be to pull out the battery. Turning it off completely by removing the battery - should reset any bugs that hose it up.
Mar 24, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
How can I disable the voicemail on my blackberry 8330 because I keep getting the voice mails and its not necessary for me to have it since I am deaf?
Call your carrier and ask them to remove voice mail from your phone. Explain to them that you cannot go into the voicemail menu's because you cannot hear them. They should be able to fix it on their end. If you have no TTY method to call them with then check to see if there is a local corporate store in your area and they can assist you.
Hope this helps.
Mar 21, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
How do i reset blackberry curve 8330 to factory settings
Dec 28, 2008 | RIM BlackBerry? Curve 8330 Cellular Phone
RIM BlackBerry? Curve 8330 Cellular Phone Logo
207 people viewed this question
Top RIM Cell Phones Experts
Computer Repairing
Computer Repairing
Longtime User
Jason
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
