Filled with water wont drain humming noise - Washing Machines
    Top Expert:
  • Washing Mach... Master
  • 49,322 Answers
Call a technician as it may be the start/run capacitor that has failed and not starting the motor spinning for the wash action
check the drain pump for obstruction in the impeller like, coin, bobby pin , bra wire etc
Posted on Dec 11, 2016
SOURCE: Model numer RAS6233RQ0...only get humming sound, and nothing else
yes i have a roper ras6233kg top load washer. I have not had any problem with it until about Two weeks ago, it over filled and it would only make a hummuing sound. Now it has dried out and have been working beautifully. Then Three days ago it stopped agitating,will not spin only making a loud humming noise. I guess its time to get another one.
Posted on Nov 02, 2008
  • 9 Answers
SOURCE: full of water wont drain
had trouble with some washers not dumping water found penny screws and other small material in the pump removed and worked o k .this might help.hum might be from restriction in pump.
Posted on May 21, 2009
venexcsd
  • 1185 Answers
SOURCE: Fabric Softener Dispenser wont drain
Try using a long handled babies bottle brush to clean out the rear of the dispenser and the tube leading down into the drum
Posted on Jun 18, 2009
  • 454 Answers
SOURCE: washer is filled with water,,it wont drain,,nor
Sounds like a bad lid switch. When you close the top lid, there is a safety switch that closes, it is actuated by a pin attached to the lid, there will be a small hole located on top of the machine, somewhere on the perimter of the top of the tub. Could also be a bad timer.
Posted on Jun 25, 2009
barkencoa
  • 3463 Answers
SOURCE: washing machine wont drain keeps bleeping ERR2
It will not spin with water in.
See if you can locate a filter, and clean same.
Posted on Jan 19, 2010
Hi I have a fisher and pykel fresh smart drive 9 and its filled up with water but wont drain,ive tried advancing the cycle but all I get is a humming noise.please help
The humming noise is due to the drain pump being jammed due to clogging of dirt. All you need is to remove the drain pump and do a full clean up. You can also try to tap on the drain pump while it is humming as it will release the dirt and wash off.
Sep 07, 2013 | Fisher and Paykel GWL11 Top Load Washer
Water will not drain humming noise
Humming sound could be jammed pump.Remove th filter and check pump Blades are free, nothing is stuck in it....
Nov 25, 2009 | Washing Machines
No water running through cycle once filled....making humming noise once clicks into cycle
pump should be checked for restriction of movement,is there something blocking it?does the capacitor smell?if it does its blown(or meter check-more accurate),hope this helps
May 27, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Full of water wont drain
May 21, 2009 | Kenmore Washing Machines
Whirlpool Waher not working
does it make a humming noise if so there might be something in your pump
Dec 19, 2008 | Whirlpool Washing Machines
Mah2400aww
The problem is the washer is defective.
Jan 18, 2018 | Maytag MAH6500 Neptune Front Loading...
Dl error will not clear
My Whirlpool cabrio is making a humming noise an the water filled the tub but wont drain i tried pressing buttons but no luck please help,how do i reset it
Sep 20, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Jul 24, 2008 | Roper RAS6233KQ Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
