HDTV (mitsubishi) picture is on however it's non responsive w remote and buttons on the TV are non responsive. No controls whatsoever. Power button not even working.
wyoed1
  • 211 Answers
SOURCE: Vizio L32 HDTV 10A-remote
Try a new Remote control, and if that doesn't fix the problem, it may be a remote sensor in the set. Hope this helps. Have a great weekend
Ed
NC Electronic
Mills, Wyoming
Posted on Jan 07, 2008
  • 121 Answers
SOURCE: theres no picture on my sony bravia KDL-40S4100
Try pressing the TV/Video button. The problem could be that the TV is set to an input with no source.
Posted on Feb 25, 2009
jerryg50
  • 1689 Answers
SOURCE: LG TV 32LB9D VOLUME STUCK AT 100, NO RESPONSE TO REMOTES
The fault may be on the control board. Sometimes the button switches can be stuck, or there may be something causing some conduction on the control circuit board. It is also possible to have a component failure that is causing a continuous command to keep the volume to the high position.
Something that causes failures of controls in TV sets is when people clean the screen, they spray liquid cleaner on the screen. Some of it drips down in to the controls and on to the circuit board. This will usually cause damage, and thus the set will require shop service.
Jerry G.
Posted on Apr 10, 2009
SOURCE: Frigidaire Model FAZ12HR2A Digital control pad
coils freezing
Posted on Sep 21, 2009
  • 18 Answers
SOURCE: No Picture
I called Vizio, was told I needed a hard reset, and this fixed my problem: I unplugged the TV; held down the on button for one minute, then plugged it back in. It works fine now.
Posted on Apr 03, 2010
TV was on but picture wasn't as clear. I pressed the "device" button and the TV immediately went to snow. Now I don't get a response with pressing any buttons on the remote or any buttons on...
Try the soft reset, with set on and original remote hit 1,2,3 enter, some versions require menu first.
let me know if it helps.
The set also has a hard reset but only as a last resort.
SD TECH
Feb 10, 2011 | Mitsubishi WD-73927 73" HDTV
Hitachi 55vf820 problem
Most likely the buttons on the tv are stuck or malfunctioning, replacment of the button pannel will solve the issue
Mar 17, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Timer light will not stop flashing. can't turn on TV
Unfortunately the first generation DLP's from Mitsubishi are prone to have Capacitor failure through out the chassis. Most likely that is what your set is experiencing. I would start by replaceing the suspect caps on the DM amd The Power boards. You can get the V26 Chassis DM/Power repair kit from www.tvrepairworld.com which also contains instructions.
Jun 21, 2010 | Mitsubishi WD-52725 52". Rear Projection...
61md10 front panel controls lit uo, but the TV does not respond
With a non responsive remote that would be inpossiable you need to replace the control board inside around $100 bucks then you can have a good tv again but to get to the service menu your controll has to be working.
Aug 19, 2009 | InFocus ScreenPlay 61" Rear Projection...
Wd-73727 mitsubishi tv
I believe hitting the device button will supply you with a list of input options. sounds like you are just on an input that you don't use.
rustym62
http://www.the-tv-dude.typepad.com
Apr 26, 2009 | Mitsubishi WD73727 73" HDTV
TV is not responding to the remote control.
The set may have defaulted to a front panel lockout. To defeat that on the front of the set hold down the MENU button for 15 seconds and see if it will then power up. I know that doesn't solve the problem with the remote but one step atta time. These sets are prone to leaky switches on the control panel and when that happens the micro cannot accept two different commands at the same time. That could be why the remote is not working.
Apr 05, 2009 | Mitsubishi WS-55513 55" Rear Projection...
Tv screen went blank
sound like the inverter circuit board problem. check & replace back same part# inverter circuit board. hopefully could help!!
Dec 29, 2008 | Vizio L32 32 in. LCD HDTV
Comcast Remote Control Code
comcast sucks and its tech support are a bunch of idiots. the book that comes with the remote is wrong (and for some reason no one in tech support knows this). the remote requires 5 digit codes and all the codes in the book are 4. typing the number 1 in front of any of the codes in the book, for any device and manufacturer, should fix this problem.
Jan 28, 2008 | RCA HD52W59 HDTV Projection Television
Describe your Mitsubishi WS-65313 65 in.... Problem:
look for the CONVERGENCE settings either behind a small panel on the front or through the menu with the remote control
Jan 13, 2008 | Mitsubishi WS-65313 65" Rear Projection...
Mitsubishi remote and control panel issue
Did you ever resolve this problem and if you did, what was the fix? My same tv just got out of warranty and I have the same problem. Thanks.
Nov 22, 2007 | Mitsubishi WS-55813 55" Rear Projection...
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
