Question about Necchi Sewing Machines
How do i zig zag stitch on a necchi 4575? Help!
  • Necchi Master
  • 11,774 Answers
SOURCE: Zig Zag Skip Stitch
your machine might have a problem with the rotary hook, it might need to get timed by a professional.
Posted on Oct 30, 2007
night71
  • 328 Answers
SOURCE: upside down stitching
Sounds like the needle alignment is out.
This website has some instructions on how to properly set it up and also has manuals too.
http://welcome.solutions.brother.com/bsc/public/us/ca/en/faq/faq_list.html?reg=us&c=ca&lang=en&prod=hf_cs8072eus&Cat=53
Posted on Nov 01, 2007
  • 980 Answers
SOURCE: Skipping stitches while zig-zagging
If you have put a new needle in then the chances are the machine has gone out of time, you can either take it in to the repair shop or you can contact me and I will attach timing instructions drivewithken@blueyonder.co.uk
Posted on May 14, 2009
SOURCE: Zig Zag Stitch not working
THis problem occurred as I was sewing on Neoprene. I was using Gutterman all-purpose thread and a size 80 needle. Tried switching to a size 70, then to size 90. Still unable to zig zag. After inserting a test sample of cotton, the zig zag worked perfectly, so I knew it was not a mecahnical problem. I switched needles again. This time to size 90 for stretch fabric. Voila! Problem solved.
Posted on May 24, 2009
  • 46 Answers
SOURCE: only does zig zag stitches, no straight stitches,
make sure the pattern selector is set for straight stitch first. If it is set correct then the machine may be "stuck" is zig zag mode. May need to be de greased and then re lubricated.
Posted on Jul 27, 2009
Please how do I work a zig zag pattern on my manual operated singer sewing machine
Hello, Annelien -
Unless your manually operated sewing machine has switches to realign your sewing machine needle to make zig zag stitching, as is demonstrated in this YouTube video (starting at around 6:30 minutes in the video):
https://www.fearlessmakers.com/manual-sewing-machine-works/
you cannot. Note: The machine in the video is a Necchi brand sewing machine.
Without knowing the model number of your manually operated Singer sewing machine, I cannot try to find operating instructions for it to determine if your machine has zig zag stitching potential.
Best wishes.
Jan 24, 2018 | Singer Sewing Machines
I need zig zag settings for model 4575 of a Necchi sewing machine
Does your machine look like the one in this eBay listing?
If so, does it have the stitch number guide on the left of the sewing arm?
Bill in Oregon
Jan 26, 2015 | Necchi 4575 Mechanical Sewing Machine
What is the difference in Necchi BF and Necchi BU?
Necchi BF is a straight stitch machine
Necchi BU is zig zag machine
Necchi BU Supernova had cams for additional stitches
Jul 17, 2014 | Necchi Sewing Machines
I bought a R-2000 never used Necchi at an estate sale. Did not thoroughly read the manual before beginning to sew. Now it will only sew a zig-zag--think I did not use the release knob before changi
since you bought the machine at a state sale it would probably be a good idea to have the machine serviced.
you should be able to go from straight stitch to zig zag with out any problems.
if you move the dials or knob & the machine will not do a straight stitch then it needs to be checked
May 21, 2012 | Necchi Sewing Machines
Trouble sewing lycra fabric using a zig zag stitch
You have the machine set for blind hem stitching. Change the stitch selector to stretch stitch, which is a single, in line stitching zig zag stitch.
Cheers,
Embroidery Services
San Diego, CA
Sep 13, 2017 | Sewing Machines
My cousin has a machine that straight stitches fine but skips when you zig zag. I have changed her needle, dust out underneath, made sure that it was threaded correctly, changed thread. My question is...
Yes, it sounds like you've gone through all the usual trouble shooting so timing is probably out just a bit which means that the needle and rotary hook are not getting close enough to each other during the zig zag.
Probably best getting a sewing machine technician to give it a service and reset the timing.
Jun 28, 2011 | Necchi 4575 Mechanical Sewing Machine
Only does zig zag stitches, no straight stitches,
Jul 26, 2009 | Necchi Sewing Machines
Zig zag stitch
If your stitches do not look good on the top side you have a problem with the bottom thread. make sure you have the correct bottom tension: Is the thread under the bobbin tension plate and when you hold the bobbin and case lightly in your hand the tension should be set in a way that there is little resistance , yet still some, when you pull the thread. After you set your bobbin tension, you may have to adjust your top tension to balance. Also make sure the thread comes off of your bobbin the way your manual tells you, clock or counter clock wise.
Make sure your bobbin (plastic) is not sooooo old, buy a new one.
Jan 14, 2009 | Necchi 6011
The zag part of zig zag won't work
i believe your machine is skipping the stitch on the RIGHT side as you sew and this is normally a timing problem. Lower your needle about 1/16 inch and try it . It might work to finish your project but it will need to be serviced to have the timing corrected.
sewman7
Jul 28, 2008 | Necchi 3101 Mechanical Sewing Machine
Zig Zag Skip Stitch
Oct 03, 2007 | Necchi 3537 Mechanical Sewing Machine
Sewing Machines Logo
50 people viewed this question
Top Necchi Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Ellen Den Dulk
Ellen Den Dulk
Level 1 Expert
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
