Question about Kenwood KAC 5206 2 Channel Performance Amplifier
My kenwood kac5206 the red light on top comes on no other lights I've seen nothing internally looks burnt nor any smell I don't know if it's good or bad should It work does this mean power or what
  • 119 Answers
SOURCE: Shutting Off
the usual repair for a morotized face plate with symptions of no display, some buttons working or no buttons working & sometimes even the faceplay not moving, is the ribbon backthat connects the main unit to the face plate. Sometime you might be able to see the gold/yellow flat ribbon as the face plate flips. it's not too difficult to cange but it takes patience. the cables run around $15 to $30.00.if you replace it yourself, watch out incase the spring for the ribbon tension unwinds. good luck
Posted on Dec 14, 2006
  • 2336 Answers
SOURCE: TV won't turn on
If that large capacitors is defective, the TV should still power up normally but it might produce a humming noise through the speakers.
I would suggest to check very carefully the capacitors on the secondary side of the circuitry, specially the 1000uF that filter the 5vdc line.
Let me know if you require further assistance.
Posted on Dec 02, 2008
SOURCE: KAC-X520 kenwood 1000w amp
try wiggling componites and look for cold solder.
Posted on Jan 17, 2009
Professor_V
  • 92 Answers
SOURCE: my kenwood amp wont turn on all the way i just
REMOVE THE RCA INPUTS AND DISCONNECT THE SPEAKERS, THEN POWER THE AMPLIFIER UP WITH THIS NO INPUT, NO SPEAKER LOAD CONDITION. IF IT STILL DOES NOT POWER UP, VERIFY THAT THE POSITIVE AND ESPECIALLY THE GROUND CONNECTIONS, ALONG WITH THE REMOTE CONNECTIONS ARE 100%, THEN TRY AGAIN. IF STILL NOT POWERED UP, MEASURE THE REMOTE WIRE VOLTAGE TO INSURE THAT IT IS NOT LOWER THAN 11 VOLTS. IF YOU CANNOT MEASURE IT, THEN DISCONNECT THE REMOTE LEAD FROM THE AMPLIFIER AND TEMPORARILY INSTALL A JUMPER WIRE FROM THE POSITIVE POWER TERMINAL TO THE AMPS REMOTE TERMINAL WHICH WILL FORCE IT TO TURN ON. IF IS STILL DOES NOT POWER UP, THEN IT WILL HAVE TO BE SERVICED. LET ME KNOW IF YOU NEED FURTHER ASSISTANCE.....V
Posted on Jan 06, 2010
  • 31 Answers
SOURCE: my kenwood amp doesn't light up, fuse is good
your amplifier has a power supply problem,contact Eric @ Capital Audio & Electronics Repair 850-339-1130 email poppa1puff@aol.com
Posted on Mar 21, 2010
Kenwood kac 628 red light comes on and no audio output
The red light you describe on your amp, is the protection mode warning light. An amp goes into protect for many reasons. Here's a checklist.
1st check the fuse (s) on your amp and make sure they are not blown.
2nd check the inline fuse next to your car battery (if you have an inline fuse)
3rd, disconnect the speaker wires with amp on, does the light go off?
4th check your ground, this may be ok if you have tried another amp with the same wires.
5th.if none of these turns the protect mode off, it may be an internal fault.
you may have blown transistors and it is a tricky job to repair and costly.
Jan 28, 2013 | Kenwood KAC-628 Car Audio Amplifier
On one of our HP DL360 G5 systems every time after soft reboot the server cannot be booted back. This is 100% reproducible also with Cold boot. Can someone help us find what internal component is...
The simplest way is to check Insight Manager. Type localhost:2301 on a web browser locally. Or, servername:2301 for remote access. You need local Administrator password.
Insight is only available if it was set up with a Smart Start disk. It's that pack that comes with all HP servers, but can be downloaded as well. Best practice is always install.
Don' know what IML is, and ILO has no baring to problems.
There is Insight Manager link on specs.
http://h18004.www1.hp.com/products/quickspecs/12476_na/12476_na.html
Nov 12, 2012 | HP ProLiant DL360 G5 Server
I have a 40" screen colby flat screen, I'm having problems with my monitor coming back on???? I've tried leaving it unplugged for two days but when I plug the monitor up, don't nothing com
if the power indicator goes light green then turn to red, you must check the power supply board. look for a bulging capacitors.http://en.wikipedia.org/wiki/Capacitor_plague.a panasonic brand capacitors with low esr is a good replacement just look for the ratings and value must be the same when replacing. then make it sure check the polarity the positive and the negative. just let me know if you need further assistance good luck
Nov 01, 2012 | Computers & Internet
Sony kf-ws60s1 front red light flashes 6 times after lamp replacement. Need thermal fuse part number
hello!
your issue has nothing to do with "thermal switch". while you have replaced the lamp, you could lose a piece of plastic hardware, in front of the lamp housing. It pushes auxiliary interlock switch, right under the front of the lamp compartment. If you take lamp out, use flashlight and shine inside. There is a little switch at the bottom. Try to make the lamp housing push it, without breaking anything. you could get "generic" lamp with housing, which is not correct. Anyway, that's the deal. Also: don't forget to install lamp door and turn the handle clockwise! there is another switch. I've seen people who forget to put that door back! Really!
good luck,
Alex.
Mar 06, 2012 | Televison & Video
Mitsubishi lt 52149 52 hdtv will not come on. Like no power. Smell burnt smell at top. Is this something I can possibly repair myself if handy?
No,tv do not any indication of any LED lights that light up at all or any blinking LED lights at all wright?Yes?This tv have major components parts on in one board or could be any boards parts are completely fries and could spread all over the tv other boards too.That why u able to smell burn smell,minor problems don't have a deep smells like that.Best get a quotes from tv Techs from many tvs shops best prices u decide and get it fixed by a tv tech certified professinal.
Aug 22, 2011 | Mitsubishi LT-52149 52 in. LCD HDTV
I have an older model Flair unit. I took it apart to try and give it a good cleaning and noticed that there was a small glass bulb-looking part with one of the thin wires was broken. Of course the other...
It's attached to the pulse radio-wave ionizer. It comes on when the unit is on to show the radio wave is working. It's not needed and I've never seen a replacement but Radio Shack could probably help you replace it if you wanted.
Jun 23, 2011 | Ecoquest Flair Air Purifier
Amp lights up, but no power to outputs.
channels mey be burned....does the amp smell like burnt electronics
Nov 07, 2009 | Kenwood KAC-8104D Car Audio Amplifier
a red light indicates you got no power check your wiring you may not have a good ground, you need the green light to come on
Oct 09, 2008 | Kenwood KAC-X520 Car Audio Amplifier
Transmission/shifting 2001 Sante Fe - Hyundai
Sounds like you might have serious internal transmission problems.
As soon as you can, get someone with a code reader to plug in the vehicle and find out what the code is for the Check Engine light to come on. Might give you a better picture of what`s going on.
It could also (cross your fingers) be something more usual like a clogged transmission filter (located inside the pan), or shift solenoid.
By the way, have you checked the level, look & smell of your transmission fluid?
Level should be checked with the vehicle running, after passing it in all gear ranges on the shifter, and putting it back in park (Check it on "cold" or "hot" level depending on if it`s been driving for a while or not).
As for look and smell, it should be reddish and not smell burnt. Hard to describe the smell of burnt transmission fluid, but normal fluid does not smell too strongly, kind of sweet. Burnt oil is usually black and has a strong odor. If the oil is burnt you have internal damage to the transmission.
One piece of advice I give you is get it fixed as soon as possible because if you don`t already have serious internal transmission problems, the longer you wait, the more chances you have of getting some, to the point of the vehicle just refusing to move. And believe me, speaking from experience, the transition point from the symptoms you describe to total refusal to move and the need for a tow/transmission rebuild is not that long usually.
Aug 19, 2008 | 2001 Hyundai Santa Fe
MY TV WAN'T COME ON
First off, it is impolite to post all in Caps, everyone should know this, it is just internet politeness. That said,You could have a bad solder connection or you overheated a component. If you have no TV repair experience, you are going to need to call in a pro to assist you in this repair. Good Luck
Jun 15, 2007 | GE 32GT660 32" TV
Kenwood KAC 5206 2 Channel Performance Amplifier Logo
75 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
