Question about Garden
This unit has new plug and new petrol in other and will start and run for a few mlnites and then stops
Rockwellseries x3750 lawn mower
  • Garden Master
  • 2,195 Answers
If this unit has a fuel cup at the bottom of the carburetor remove it and clean and clean the fuel jet as well. I blow mine out with air pressure or take a fine wire and push through it but do not mess the holes up. It does not take very much dirt to stop the flow. Check your float in the carb as well as it may stick and won't let enough fuel into the carb to keep running. I would check the fuel bowl and jets first. That is most likely to be the problem. another possibility could be the filter in the gas tank at the end of the tube that runs to the carb.
Posted on Dec 11, 2016
Engine starts. Why does it only run a few minutes, then stop?
a few things may cause this. it sounds like it is starving for fuel. the spark plug may be breaking down when it gets hot. try a new spark plug. if the fuel and fuel lines are in bad shape, old, soft or hard. the fuel don't smell right. fuel filter plugged up. the carburetor may need to be cleaned and a rebuild kit as they are cheap. if it is 30 years old. be sure the fuel lines, filter and carburetor are in good shape. hope this gives you an idea on where to start. good luck
Mar 14, 2016 | Garden
Hard to start Icon X3750
make sure your getting the three main things, 1. fuel 2. air 3. fire. if your getting those then something as simple as cleaning the carb/throttle body or new fuel or a new air filter
Sep 05, 2013 | Garden
Mower will start but runs rough & stops
Is the carb flooding?is there black smoke coming from exhaust when running, if so it could be the carb over filling with fuel. Is there petrol leaking out of the carb? If not check the fuel pipe is in good condition
Jul 22, 2013 | Briggs & Stratton Lawn-Boy Insight Series...
Toro self propelled lawn mower dies after an hour
maybe u have to much oil in it or there mite be a stone in the carberator or petrol tank thats blocking the petrol ?
Aug 07, 2012 | Toro Garden
1997 Mountfield 21" Emporer Petrol
check the FUEL plug. when unscrewing the fuel bowl it is the nut holding the bowl on. It sounds like it may be clogged
Jul 17, 2011 | Garden
My Lawn mower will not start, there is no spark, when the new plug is held against the casing. All else looks fine, new oil, new petrol, clean carb, filter. It worked ok up to a month ago, then would only...
It also could be the stop switch is not opening up. On mower you have a stop bail that a cable is attach to the engine if this cable does not open the stop switch, when the bail is pulled back, the mower will not allow the mower to start. The stop cable may need to be replaced because it is stretched out. HTH
Good Day. mate.
Oct 27, 2009 | Garden
Honda Izy will not start.
try fresh fuel
Apr 04, 2009 | Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
