Question about New Home Security
, how do I order a new remote for my new security cameras
LOST MY REMOTE...WANT TO ORDER ANOTHER. IF I ORDER IT ONLINE, DO I HAVE TO TAKE IT TO THE INSTALLER TO REPROGRAM OR WHAT DO I DO?
This will depend on the model, however most don't require going to an installer. The new remote must be synced with the starter. Replacements I have ordered in the past have come with instructions, otherwise consult the manufacturer's website. The last one I did only required setting the car starter/alarm to program mode using a hidden "valet" switch, then just a quick sync instruction set.
Jan 10, 2015 | Vehicle Parts & Accessories
My camera is hooked up to my tv as instructed but nothing happened. Is there a special channel that you put your tv on in order to get a view
Connect the yellow connector of the camera to the TV Video input 1 or 2
Using the remote select the right video input on your TV by pressing, Video or Source on the remote to select the video input 1 or 2 whichever, input you connected the camera to that input needs to be active using the remote or keypad on the side of your TV set.
AAA TV SERVICE
http://www.aaatvservice.com
Aug 20, 2011 | Lorex Corp SG6184S Weatherproof Mini Color...
I cannot control the TV with remote control. Originally, I thought the remote control did not work. I ordered a new control, and still it did not work
To ensure that your remote is working correctly (infrared) take your cell phone, switch on the camera mode, now point the remote towards the camera lens and press the remote button, you shall see a red light come up on your cell phone screen, if this means your remote is fine the problem is with the receiver on the television.
Feb 27, 2011 | Televison & Video
I have lost my 4 button coolstart car remote ser rs-830/rs-810 need to order a new one
You can purchase the remotes directly from Crimestopper or call them to direct you to a dealer near you. Their contact and order information can be found at this link:
Crimestopper contact page
The following 2 links will help you identify which remote you need.
Remote chart by system number
Remote identification by image
Nov 08, 2010 | 4-Button Remote Start/Keyless Entry with...
I have a crimestopper security system and the remote 1 way EZ Start remote (cs-34 II TX) battery keeps dying. How do I repair
if the battery keeps dying on your remote it probably has a bad contact somewhere inside you could order a new one from www.crimestopper.com you would have to have your unit model number for them to help you that is located on the unit under your dash
Oct 28, 2009 | Crimestopper CS34II Remote 4but rs1304...
Want to buy a prestige aps998 remote and cant find it
You have to contact Audiovox by web or phone to order the dot matrix remote. It cost $85 + shipping. I'm lookin for a way to order online myself.
Sep 24, 2009 | Prestige 2 Button Remote Security System...
Broke remote and bought new one
lick on this link and go to contact us . call tech support and they will help you. http://www.bulldogsecurity.com/
Jan 16, 2009 | Remote Starter with Keyless Entry
Activex blocking usage of speco remote
Open the "internet options" menu through tools. Click on "security" tab. Then select the "internet" and click on custom level. Here, navigate to the "Activex controls and plug-ins" section. Change "Download Unsigned ActiveX Controls" to "prompt" and do the same for the setting directly below that. This should clear up your problem
Nov 03, 2008 | CSi Speco DVR-PC8 Video Recorder
Emerson EWD2203 DVD VCR
Lost ours so I found a place to order a new one
https://secure.remotes.com/remotes
Hopes this helps
Jan 19, 2008 | Emerson EWD2203 DVD Player/VCR
Home Security Logo
41 people viewed this question
Top New Home Security Experts
john h
Eddie Dalton
Eddie Dalton
Are you a New Home Security Expert? Answer questions, earn points and help others
