Question about LG 55LS4500 55 in. TV
LG 55LS4500, after turning on the TV the picture goes out after a while but the sound stays on. Wait a few seconds and turn it back on and the picture will come on again but after a while goes out.
    New Friend:
  • 25 Answers
BUENAS SERIA BUENO Q REVISARA EL CIRCUITO DE ILUMINACI?N DELA PANTALLA DE TU TV EMPIEZA POR AH? PARECE SER UN PROBLEMA DE SOBRECALENTAMIENTO SI TU TV ES PLASMA YO TU IRIA A POR LOS IC QUE ALIMENTAN LA PANTALLA DE NO SER ASI POR Q EL TV ES DE LED O LCD REVISARIA LAN LAMPARAS Y EL INVERTER EN ESE ORDEN ESPERO Q DES MAS DETALLES PARA AYUDARTE MAS SUERTE
Posted on Dec 11, 2016
  • Rod Cheroske
    Rod Cheroske Dec 11, 2016
    English please!
  • The Yeti Ahh
    The Yeti Ahh Mar 01, 2017
    Rod, did you ever find the cause? We have a 55LS4500 with the exact same problem. The picture looks perfect for a few seconds before it turns off. The sound still works fine.
    Master:
  • LG Master
  • 708 Answers
LG 55LS4500 55 in. TV has sound through speakers, no audio except a hum from headphones and the optical digital to analog output fiber lights up but no sound output What board is bad?
Hi Louis,
The audio circuitry is located in the main board. Try unplugging the TV for a while and try again if the audio comes back.
I would suggest to check all your settings in the audio section first and if everything seems OK then the main board should be replaced.
Feb 26, 2017 | LG 55LS4500 55 Inch 1080p LED LCD HDTV -...
LG 55LS4500 backlight issues
If you wish to get some details; check the site linked here. Pull up older posts.
Jun 21, 2016 | LG Televison & Video
My LG tv will go on then after a few seconds the screen goes from black back to picture of and on a few times then shuts off. Help!
LG LED TV has no picture (black screen) but still sound ...
www.tomsguide.com/answers/.../led-picture-black-screen-sound-fixed.ht...
7 days ago - My 32' LG LED TV has suddenly lost picture! The sound is all right but theScreen is pitch black. After switching it on the picture flashes for a second and thenthe ... LG LED TV has no picture (black screen) but still sound - can it be fixed? Tags: ... a touch on the screen reveals nothing so it's not the back light.
Monitor going black after 2 seconds [Solved] - CCM.net
ccm.net > Forum > Hardware
Oct 9, 2012 - Brightness goes down, display draws less juice, and you can at least use .... it's the LCD's Inverter ... you have to replace it for it to go back to ... If the screen is turning off every two seconds or so and then it comes ... i turn my tv on it comes right on, but then after a few minutes turns off, .... Digital Trends for LG. No display in monitor
Jan 11, 2013
Ps3 and hdmi cable
Oct 8, 2012
More results from ccm.net
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
Dec 20, 2015 | LG Televison & Video
Turn tv on picture for a secondthen goes black but still sound model number is 55LS4500
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
Oct 15, 2015 | LG 55LS4500 55 Inch 1080p LED LCD HDTV -...
Turn on picture for 2 seconds then goes black but still sound
Typical case of timing control board blew (T-Con), due to electrical shock on DC-DC converter, you might need to ask for a replacement, Good Luck!
Haier LCD picture goes dark, sound only
hi, since your TV is under warranty,It is better to ask for a replacement a new one ..the problem is factory defect.
Apr 02, 2012 | Haier HL15R LCD TV
My LG Plasma 42PC1DV turns on but freezes, the picture is frozen but the sound stays on...the it takes a long time for it to turn off. when you turn it back on the picture goes fro about 3 seconds and does...
hi wendy, I have the same model tv and it has been doing exactly the same problem you have ever since buying it (2007 - 08) and every time it does freeze it seems to be on channel 9. The only way i overcome this problem is to turn the tv off at the wall for atleast an hour and turn it back on and it seems to re-set itself or should i say the built in set top box re-sets itself and it works fine for a few months and bang it does it again. Apparently there is a LG software update but only technicians can install this. Anyway thats my story! :)
Aug 11, 2010 | LG Televison & Video
LG DU-42PX12X Plasma, picture startes flashing then goes black after a few minutes
You need to get this tv service asap.i beleive that the problem is in the inverter board or yb board.
good luck
caypianan@yahoo.com
Oct 25, 2008 | LG 42PX5D 42 in. Plasma HDTV
Samsung LCD TV, no picture only sound
is the picture clear when on? if yes, does the screen go black after a few seconds. if yes, sounds like you need a back light inverter!
Sep 13, 2008 | Westinghouse LTV-30W2 Television
LG 55LS4500 55 in. TV Logo
87 people viewed this question
Computer Repairing
Computer Repairing
