Question about Garden
How do I get to the clutch on 1988 cx80 case farm tractor
    Top Expert:
  • Garden Master
  • 47,607 Answers
Talk with a case service center
normally the engine has to be split from the gear box case
specialist job requiring specialist equipment
Posted on Dec 11, 2016
Mid sixties Ford 4000. Suddenly decided to make severe grinding noise when trying to engage gears and cannot engage gears. Weirdly this does not always happen. Gears engage OK when engine not running
Hello, you may have more success in the proper category of lawn or farm stuff. Fortunately I have same Tractor. Sounds like clutch fork is not moving clutch the same way each time you press clutch. Could be clutch needs play removed. Sometimes there is a pivot ball for the clutch fork to rest on. When the pivot ball is worn the clutch fork can rock. Also remember RPM to give gears time to stop spinning before changing gears.
Jan 21, 2017 | Ford Cars & Trucks
John Deere 760-A scraper will not move forward but it will back up.
It is almost like a 4620 powershift farm tractor trans. When reverse goes clutch packs are shot. Sorry about that. Be sure the shift linkage is moving full range top to bottom.
Nov 21, 2016 | John Deere Garden
PTO inoperative.
What's the make & model of your tractor? If this is a garden tractor, it sounds like either the belt on your (I assume) electric clutch is slipping or you have low power to the magnets. If this is a farm tractor, then your pto clutch plate is worn and/or needs replacement/adjustment.
Apr 10, 2016 | Garden
Need firing order diagram 1948 case tractor 4cly
what model
Case VAC engine
http://www.tractordata.com/farm-tractors/006/4/3/6437-ji-case-vac-engine.html
May 17, 2015 | Garden
How do I fix a clutch on Massey Ferguson 165 1979 tractor. I need a manual to do repair on farm
This is easy. If you live on a farm i assume you have some mechanic abilities. the tractor needs to be split in half. I have done these tractors in as little as 4 hrs. The easy way to seperate the tractor is to sleightly jack up the middle of the tractor,put a jack stand under the front of the transmision. Now move the floor jack forward to the rear of the engine. take roughly half of the weight off of the jack stand. this will allow you to roll the front half of the tractor away from the rear once you remove the trans.bolts,hydro.lines and brake rods.
Sep 15, 2014 | A&I Products A-509057M91,Massey...
Lookup serial numbers
Hi, here's a link to these specs. It looks like however that you did also find this info. Perhaps you'd comment if this was helpful. Thanks and good luck!
Just in case:
TractorData.com Massey Ferguson 362 tractor information
http://www.tractordata.com/farm-tractors/000/7/8/784-massey-ferguson-362.html
Aug 30, 2014 | Garden
2090 case trasmission problems
That's because you have two separate pumps controlling each. My best advice is to get a farm mechanic to take a look...it may be a simple seal to a need for a rebuilt pump. www.nyagparts.com
Jun 01, 2010 | RTO Case W14 1570 2090 2290 2294 2590 3594...
Early Ford Farm Tracker- Clutch not engaging
Is it a 8N ford tractor or close to that?
Does the transmission grind or hard to put in gear if the clutch is left engaged while placing in a gear.......does it feel like the clutch is driving the transmission?
If so....there is a short drive shaft behind the transmission in the tractor which may have broken.
There's not much else that breaks in there.
Aug 16, 2009 | Ford 8N Tractor
Garden Logo
37 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
