Question about Element Televison & Video
Were is the power supply fuse on a 2014 65 inch element tv. Tv is not turning on
    New Friend:
  • 25 Answers
SI UN TV DE ESA MAGNITUD VOL? SU FUSIBLE NO LO REEMPLACES CAUSARAS MAS DA?O REVISA PRIMERO LA FUENTE Y ASEGURATE DE Q NO HAYA NADA EN CORTO ANTES DE REEMPLAZAR EL FUSIBLE..
Posted on Dec 11, 2016
SOURCE: Element flx-3210 lcd tv
I have an element lcdtv 32inch. The tv is less than a year old, i was watching the tv and it just shut off. The red light is on, when i go to power it up, the blue light comes on for a second then blinks, and goes back to red. I know its not a brand name tv, but for 600 bucks, it should last for more than 8 months. Anyone have any advice ?
Posted on Oct 31, 2008
SOURCE: my element 19 inch flx-1910 tv will not power up
Element FLX-1910
Problem: When the TV is turned on a picture appears for a few seconds and then the picture turns off. Audio is still heard.
Solution: Not a simple fix! This TV has 4 small florescent looking bulbs that act like a back light to light the image on the liquid crystal display (LCD). At least one of these bulbs is burned out or broken. The wires powering the broken bulb need to be cut and spiced together. Basically you’re bypassing the bulb and completing the circuit when cutting the wires going to the bulb on each end and splicing them together.
WARNING: This worked for me but no guarantee for anyone who tries it. This is a very involved procedure and involves completely dismantling your television. To be honest I don’t recommend anyone trying to fix it unless you are very technically minded and have a couple of hours to waste carefully tearing apart your TV. If anyone is willing to attempt this repair I am willing answer questions.
Cause of problem: It is my guess that this problem occurs when the TV is left on for extended periods of time. Like leaving the TV on when you fall asleep at night. My TV was left on a lot. I noticed that the plastic was melted and discolored where the bulb had burned out. (This can only be seen internally and is no way visible from the exterior)
Posted on Feb 14, 2009
SOURCE: no picture
Had the same problem, Insignia 32 would click on then go off. About 6 months ago I found (somewhere on the net) a guy who explained that he changed blown capacitors. As I recall he even posted a picture. I found the blown capacitors and replaced them with larger capacitors (less than $20) problem solved...
But now my screen image is showing only half a picture and is pulsing on a off.
I think I'm going to make a Wii commercial......GL
Posted on Jun 03, 2009
  • 16 Answers
SOURCE: Tv wont turn on
Replaced two N-Channel Mosfet transistors(FQPF13N50CF-ND) and some faulty electrolytic caps in the power supply. I found the Mosfets online at Digi-Key. Mosfets are difficult to read. Only one read bad but I replaced both because they are in the same circuit. Set works great now.
Posted on Mar 30, 2010
SOURCE: Samsung model ln40a450c1d.TV is dead.
Some power? I would recommend you should get a sams photofact reference on your set and find out what voltages you should have at all exit points from the power supply.
I did find this entry on some people who had similar problems.
If you are handy with a soldering iron and not afraid to take apart the set give this a try!
Because the Samsung LNS4051D would not turn on and the power LED would blink 4 times and the relay would click and this would repeat again and again. I replaced power supply board parts CM806, 811, 812 & 817, all 1000 uf 10v capacitors, three had their tops bulged up slightly that I missed on initial visual inspection. After seeing the reports of problems with these caps on http://www.fixya.com/support/t1336881-will_not_turn_or_off , I replaced them with Radio Shack part 272-1032, 1000 uf, 35v. They are slightly bigger, but fit OK. TV is working fine now. Cost was 4 x $1.59 = $6.36 plus the time. I saved between $100 to 300 in the process of either replacing the board or getting the unit serviced. If you are not comfortable replacing components which means using a soldering iron, you can replace the power circuit board, available from http://www.discount-************/ProductDetails.asp?ProductCode=1030952-SAMSUNG&&Click=46
Posted on Oct 11, 2010
Testimonial: "Tried the 1000uf at 35volt Capacitor replacement and my TV came right on. They were slightly puffed up. Thanks very much.. Saved a lot of money...:) "
My element tv 50 inch led tv started acting up and now there are lines throughout the picture and the picture is barley visible and a hiss coming out the speaker please help.
try unplugging the power cord, this might reboot the tv. I have replaced the power supply and or capacitors on power supply. and sparked them back to life.
Feb 18, 2015 | Element Televison & Video
I think my 55 in element tv had a power surge tv went to static then shut off when i was watching a movie on my dvd now no power the led light does not come on at all i open the back and i did not see any...
Are you competent in using a test meter? There is a high risk of electrocution if you are not! If you don't know what you're doing disconnect the mains and use resistance checks only.
Is there a fuse in the plug? If so check it for continuity
If not there will be a fuse on the power supply board which may be blown. This only applies if it is completely dead. You can check this by measuring the voltage at either end of the fuse.
You may need a new power supply.
Apr 03, 2014 | Element Skateboards Element ELGFW551...
Sounds like a main board fault. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. Pull up older posts.
Element tv elcpo371
Check the voltages on the power supply board. If they all are present and correct, then the main board isn't sending the On signal to the power supply board. Replace the main board.
Feb 10, 2014 | Element Televison & Video
Where are the fuses located on a 37 inch flatscreen magnovox?
The fuse can be located on the power supply board. To locate the power supply board, trace the TV wire back into the TV. The area where the TV wire is soldered inside the TV is the power supply board. There is fuse on the board. So this means you have to disassemble the TV....
Regards.
Walesarumi
Sep 28, 2011 | Televison & Video
Element (FLX-3210) I lost sound when I unpluged my pc plug from my laptop to the TV. Then I went to the tv output which had picture on the screen but no sound. Once the power was turned off the tv it...
The tv turn on now have power and LED power light indicator is on and solid green?Yes,than it is the main Tuner signal board had a short some where and it is the problems and the causes.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner signal board for the replacement.
Nov 29, 2010 | Element Electronics FLX3210 32 in. LCD TV
Tv wont turn on, changed .5 amp fuse but nothing, its a 47 inch tevion lcd tv
hello have you check the fuse inside the tv glass type it will be in the power supply
regards
shaun
Jun 14, 2010 | Televison & Video
Sanyo TV LCD 32 inch about 3 years old. No
the power supply of your tv is bad try to check the fuses if fuse are open try to replace them with the same value..try to power it on but if the fuse blows again replace the power supply board...
good luck plse rate my help.
Jun 04, 2010 | Sanyo DP32746 32 in. LCD Television
Element FLX 3211B has no power after 14 months of use. TV will not power on. Checked th fuse near the power cord and the fuse is good. There is no power going to the TV. Tested the power cord and it is...
Took it to a TV repair shop and they did the following:
1. Rebuilt Power Supply
2. Replaced Diode
3. Replacd Transitor
Total cost was ~$100. Tv works fine now.
Mar 13, 2009 | Element Electronics FLX-3211B 32 in. LCD...
Televison & Video Logo
29 people viewed this question
Top Element Televison & Video Experts
Are you an Element Televison and Video Expert? Answer questions, earn points and help others
