Question about Kyocera Office Equipment & Supplies
Kyocera 6520 in scan copy it gives full black paper while printing copy output is clear please help
    New Friend:
  • 23 Answers
Full blank page you change the korona wire or charger
Posted on Dec 15, 2016
MUKHTAR
  • 2022 Answers
SOURCE: All copies and scanner outputs result in a totally black image
i is problem with your scanner if you ablt to open it and just apply little bit servicecing for your scanner head rod or ypy can show it service peronnel.
bye
Posted on Oct 16, 2007
checkitright
  • 1362 Answers
SOURCE: Canon ImageClass MP730 - Clear paper jam
Were you doing duplex? take out the duplex and look in side and UNDER it
Posted on Nov 19, 2007
  • 56 Answers
SOURCE: black smudges on copies
Hi, try to pull out complete process unit(cartridge) with toner box .You have cleaner(blue or green color) move this cleaner from right to left side 4 or 5 times.Note that cleaner MUST be in home position-right side when you finish.Check print.
If problem still persists, you must do following:take away small grey plastic cap on left side of cartridge,then push complete charge corona(part with cleaner on top of it) to left side just enough to lift right side of corona from cartridge.Pull out that corona and you can see drum and developer roller. Turn the gear on drum,and look for smudges on black developer roller.Try to clean smudges with brush or with dry cloth.Toner will again attract to that area,but regular.
Posted on Dec 14, 2007
Ajkill
  • 2035 Answers
SOURCE: two black vertical lines appear on copy, pdf, and scan results
  1. Unplug the power cord and the phone line from the wall.
  2. Open the control panel.
  3. Pull the roller lever forward, and then lift the white roller out of the All-In-One.
  4. Note: The scan lens is located under the white roller.
  5. Use a clean, lint-free cloth dampened with water to wipe the white roller and the scan lens.
  6. Reinstall the white roller.
  7. Reconnect the power cord and the phone line.
  8. And then try to copy if get the dame line then its the hardware problem in the printer you must need to replace the scanner unit in the printer ..
Good luck..
Posted on Nov 11, 2008
  • 6 Answers
SOURCE: Kyocera 5035 printing all black pages
Have you tried a new cartridge?
Posted on Feb 27, 2009
When making copies, only a part of the document prints; the rest is solid black.
Solid black in a copy typically means that the scanner is partially blocked. Open the top, where you'd place a sheet to be copied, and examine the small strip that runs down the side (left, most likely). See if it's clear, or if something is covering part of it.
Most copiers don't use the full size scanning plate for copies, but use a strip that scans the paper as it moves across it. If something blocks part of it, you get the black area.
Apr 12, 2015 | HP Officejet Pro L7780 All-In-One InkJet...
My kyocera 3035 print out nothing but black paper. what's hapng??
nesesitas give more information, but the problem is in the main charge corona,
replaces the charging wire crown,
Feb 24, 2015 | Kyocera Km-3035 Copier, Print,scan,fax ,...
Why-print-comes-all-black-all-over-paper/
Check the scanning lamp, when copying see if the scanning is not working,,it should be turn on when copying, if yes, then replace the scanning lamp, or drum unit, drum unit have certain life span or copying yield about 100 to 300 thousand copies produces. Check your counter reader in your machine. If yes, then replace drum unit, hope it help.....
Jun 15, 2014 | Kyocera Mita Office Equipment & Supplies
Copy Output all black
Janson; does this problem only occur if you're doing copying via the auto feeder, or also if you lay the paper in manually? The auto feeder uses a small glass opening to the front (or left) of the main flatbed scan area; if there is an issue with that area letting in light, an all black page would result. If you get all black with either type of scan, but regular printing still works, then you may have a dead scan element. Try scanning something to your computer or to an email account to see if normal scanning still works.
Apr 04, 2014 | Dell 2135cn All-In-One Laser Printer
Hi, I have xerox phaser 3100 mfp , when I try to copy or scan, only I got a black paper and not clear at all,,,, but when I try to print from the computer, it's OK... so what is the solution,...
The problem is with the hardware of the printer and all you can try is to reset the scan settings on the scanner .. clean the scan bed.
If neither of them works then it might be time to buy a new one.
Oct 25, 2010 | Xerox Phaser 3100MFP/S Laser Printer
Canon error code 6000 in mx308
please help me. i have canon print mx308. the have paper jams. paper has the full out from print. how i can finish the problems?
Jul 25, 2009 | Canon Pixma MP450 All-In-One InkJet...
Difference between ''Auot Color'' and ''Full Color Mode
Most Colour machines have three settings.
Auto Colour, Machine will determine if the original is Colour or Black and White from its scan. Then print in the format that best suits the original.
Full Colour, Machine will copy in full Colour regardless of Original type.
Black and White, Machine will copy or scan in B & W regardless of original type.
Hope this is of some help.
Ed
Apr 17, 2009 | Kyocera Office Equipment & Supplies
Please Help Kyocera KM-1510 Grayscale Copier & Minolta D251 C0F32
check the exp.lamp . it mzay be blinking at the time of scanning the original.
Feb 17, 2009 | Kyocera KM-1510 Copier
Photos
Does this help? You obviously have to insert the media type into the media slot on the far right.(omoademola) Using the top control panel Printing tasks Scanning/Copying/Faxing tasks Troubleshooting
The top control panel lets you print an image from a photo card, scan a document or image, and copy a document or image with the press of a button.
Button/Light: Function: 1 Power : Turns the All-In-One on or off. 2 Copy: light Illuminates when Copy Mode is selected. 3 Mode: Changes the copy, scan, or photo card mode. 4 Scan: light Illuminates when Scan Mode is selected. 5 Photo Card: light Illuminates when Photo Card Mode is selected. 6 Rotate: Rotates the image 90 degrees. 7 LCD Panel: Number of Copies- this changes the copy count. Note: This feature is not active in Scan Mode. 8 Display: Shows copy, scan, and photo card selections. 9 Resize: Enlarges or reduces the size of the image. 10 Page Preview: Shows a preview of the output. 11 Select: Secures an option. 12 Menu: Provides options for image. 13 Arrow : Scrolls left, right, up, or down. 14 Stop/Clear: Cancels a print job or clears a selection. 15 Color Start: Initiates color copy, scan, or photo card output. 16 Black Start: Initiates black copy, scan, or photo card output.
Jan 10, 2008 | Lexmark P4350 All-In-One InkJet Printer
Copying problem kyocera mita 3530
You did not specify how much of it it is NOT copying or left off.
Depends on how close to the end it is copying.
Try this make a copy of the ceiling ( open top with no documents and copy) it will give you a black sheet of paper, compare it to your copy, there is a margin of white around the black area this is because :
1- makes sure the toner is falling on the sheet
2- leaves enough room to clear out of the fuser.
Is your print falling in the white area? if so it can be adjusted but there has to be a margin of white around the paper. or it will cause jamming.
Good luck
Nov 15, 2007 | Office Equipment & Supplies
62 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
