Question about Mackie Music
I own a mackie MR8 , suddenly one of my pairs I can't hear except the High only no low I change the cables but the problem is still Can you tell me what shall I do Or which part is damaged?
  • Sam Piasecki
    Sam Piasecki Jan 24, 2017
    Is the woofer moving at all when you run signal through it or is completely dead?
    Novelist:
  • 152 Answers
I think you mean No Lows, but if you don't have the solid lows your issue may be a blown sub speaker. check the large speaker with a direct signal if it does nothing that's your issue if it is working then your main amplifier board needs a check. with these separate components your best bet is finding the defective part, one of my Mackie's went silent once I replaced the speaker, Hope this helps.
Posted on Jan 03, 2018
  • Mackie Master
  • 17,417 Answers
Better to contact them direct.
Contact Support Mackie
Posted on Jan 24, 2017
5 Suggested Answers
SOURCE: How do I replace the tweeters for the mackie mr8
I built a web page on how to replace the tweeter on the MR8. Lots of good photos to help you with this problem. You can find it at: http://www.idahomojo.com/IdahoMojo/Mackie_MR8_Tweeter_Replacement.html Hope it works out for you!
Posted on Dec 20, 2009
  • 5603 Answers
SOURCE: What voltage and power from the transformer mackie
This is just a hint as I was unable to find the schematic. Transformers VERY seldom fail, if you are getting anything out and the fuse is holding with no heating, the voltages are probably right.
Common voltaages seen after the rectifier and filter and regulators are +/- 15 volts and sometimes +5 volts. For the power amp they are usually between +/- 35 and 60 volts unregulated.
For small amps using the TDA2050 type amps, you will see aproximately +/- 24 volts DC unregulated.
Posted on Jul 20, 2010
  • 5603 Answers
SOURCE: Part # for tweeter in the Mackie MR8? I need 5
From a site:
Order new replacement tweeters from Mackie by contacting Mackie at: LOUD Technologies Inc.
  1. 16220 Wood-Red Rd NE
  2. Woodinville, WA 98072
  3. Phone (800) 258-6883
Ask for the tweeter for the MR5 & MR8 the part number might be 0030616. The price is about $31/tweeter
Posted on Dec 22, 2010
sg1972
  • 225 Answers
SOURCE: Hi, I have a Mackie MR8 that isn't putting out sound anymore.
I assume that you switched L and R monitors to verify the problem and so I would say that you have a amplifier failure issue. Knowing Mackie, they're probably using an output IC for amplication which although it took some time, has now completely died.
Me being an old-timer I can honestly say....Oh how I miss the discrete transistor and "thru-hole" component mounting days.
Posted on Nov 01, 2012
Oct 24, 2012 | Mackie Mr8 Active 8" Powered Studio...
One of my MR8's has only its tweeter working, im guessing the bass driver might be blown? How can i test this though and be sure it is the bass driver and not just a simple electrical fault?
Open the unit and remove one wire from one of the woofer terminals and using an ohmmeter check the resistance between the terminals. It probably should be between 6 and 16 ohms... they don't give the specs on the speaker... if it is very high or infinite resistance, the voice coil is blown and you be re-coning or buying new speaker. These are close in speakers and intended for a small room for studio listening while mixing. If the speaker is OK, then the bass amp in the cabinet has a failure... pray, as that is cheaper to repair than a speaker.
Sep 22, 2011 | Mackie MR8 150W 8 Active Two-Way Studio...
When I turn it on, the speaker has a loud buzz. The 8" sucks in at that time.
The amp driving the 8 inch has shorted to one of the power rails of the power supply. With the short, the voltage is dragged down to the point that the filter caps can't keep it up so you hear the hum or buzz. DO NOT operate it as it is driving a high current into the speaker and will blow the voice coil...Take unit for repair.
Apr 26, 2011 | Mackie MR8 150W 8 Active Two-Way Studio...
Hi, I have a problem with both of my Mackie MR8s. They both play really quiet, like ridiculously quiet with no low end at all. They don't make that "clicking" sound when you turn them on either....
The woofers were likely the problem in the first place. DO an ohmmeter check on them.
Note that the ohmmeter often doesn't work for testing piezo tweeters, but does work for the woofers with voice coils.
Feb 05, 2011 | Mackie MR8 150W 8 Active Two-Way Studio...
From a site:
Dec 22, 2010 | Mackie MR8 150W 8 Active Two-Way Studio...
MR8 has a very nasty ground hum immediately when powered up. Where do I start looking for the cause/solution to this problem
What cables are you using? I have found brand new XLR cables that were mis-wired causing hum.
Check that the signal wires connect to pins 2 and 3 in the connectorss and that the shield is tied to pin 1.
Find images of the pin positions here:
http://www.google.com/images?hl=en&expIds=17259,27740,27760,27796,27824,27867&sugexp=leprodsca4&xhr=t&q=xlr+pins&cp=7&wrapid=tljp1291152977062014&um=1&ie=UTF-8&source=univ&ei=V271TMPdLoj2tgOK2PG7Cw&sa=X&oi=image_result_group&ct=title&resnum=3&sqi=2&ved=0CDgQsAQwAg&biw=1233&bih=570
Make sure the speakers are powered from the SAME receptacle as your mixer !!!!!
If you are using 1/4 inch connections they MUST be TRS type using BALANCED lines to avoid hum.
Nov 30, 2010 | Mackie MR8 150W 8 Active Two-Way Studio...
Very loud ground hum when turned on
If nothing is pluged into the speaker and it makes that noise. It is not a ground problem. You either have a blown amp or remotely some bad connection at the large filter caps.
What voltage and power from the transformer mackie mr8
Jul 20, 2010 | Mackie MR8 150W 8 Active Two-Way Studio...
I have mackie mr8's my left one, when powered on makes a loud buzzing sound...i have disconnected power and pre amo...reconnected and it still happens...whats wrong?
Sounds like a ground loop. MAKE SURE ALL of your equipment is fed from the SAME receptacle. Make sure the ground pin on the power cable is good (try another cord or swap). Swap the audio cable to verify the cable has a good ground.
Sep 19, 2009 | Mackie MR8 150W 8 Active Two-Way Studio...
How do I replace the tweeters for the mackie mr8 is it from the rear or does the front pops off Thanks!
May 18, 2009 | Mackie MR8 150W 8 Active Two-Way Studio...
Music Logo
21 people viewed this question
Top Mackie Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Lawrence Nentwig
Lawrence Nentwig
Level 1 Expert
Are you a Mackie Music Expert? Answer questions, earn points and help others
