Not spining well since the new pcboard was replace
Ocasionally, after the TV has been on for a while, the red color just disappears leaving the picture with a pronounced yellow tint to the colors.
First check all your input cables at both the source & the TV. try wiggling them at the units to see if problem may be in the cable or possibly in the PCBoard. You may have to replace the MAIN PCBoard. I cannot give you the part# since you didn't give your brand or model#.
To locate the part# you might go on line to the manufactures support site.
May 14, 2015 | Televison & Video
How do I repair micro sd slot
I would remove the old socket from the laptop mother board with hot air or infra red heating and source a replacement to fit back to the mother board. I am highly skilled in reworking PCBoards and if the track is not damaged have no trouble.
Oct 07, 2014 | Computers & Internet
My megaworks 5.1 550 gets no power... I dont know why. when i plug in power cable, there is no power...
Step 1:
i had same problem with my magaworks 5.1 thx550.
i have tried to find solution in web but it was only one which voltage sense resistor 2Mohm track in PCboard was damaged.
after check PCboard in my megaworks thx 550 i found that tracks are quite well and voltage sense resistor is well too.
Step 2:
REPAIRING PROCEDUREin below items there are repairing procedures that i did with my THX550.to access to BCboards it is required to remove electronic boards from woofer case.
1- remove cover of woofer.2- remove woofer speaker from case by cutting and marking connected wires.
3- remove all Philips screws around cover and remove electronic parts smoothly, care about glues around power cord.4- remove and disconnect power supply board from other parts.
3_12_2013_7_45_42_am.jpg5- replaced switcher TOP234Y and capacitors C102, C206, C205 and D10 as below photos.3_12_2013_8_08_28_am.jpg6 check all of related tracks in repairing area.3_12_2013_8_10_00_am.jpg
3_12_2013_8_48_15_am.gif7- now it is time to re assemble electronic parts very carefully and prepare for test. it is better to use isolated transformer and put a lamp in serial to protect PCboard against short circuit. if green LED (POWER LED) is on it means that every thing is O.K.
8- in this step all of electronic parts should return back to case and reconnect sub woofer connections.3_12_2013_9_02_39_am.jpg
Step 3:
after replacing damaged parts my THX 550 is working well maybe for next 10 years.
i hope above mentioned instruction can be useful and helpful.
Sep 15, 2011 | Creative Labs MegaWorks THX 550 Computer...
I dropped my HP mini notebook, and now it wont charge battery when plugged in, wont come on unless plugged in
I would say that it sounds like the battery contacts have been dislodged from the main PCBoard.
It may be repairable, consult with an engineer experienced in reworking PCBoards. It is a very specialised job!
Hope that helps.
Feb 24, 2011 | HP Mini 1035NR Notebook
How do I replace the touch pad
It looks like the panel is stuck on, much the same as uk microwave ovens and the flexible pcboard is fed through a slot behind the panel.
If the new one is at hand, that will show you exactly how to replace it.
Jan 05, 2011 | Electrolux EI30MH55GS Microwave Oven
Whirlpool microwave oven model #MH6150XMS - nothing works! There is no sound or light...nothing engages when bottons are pressed.
Remove the mains plug and check for a faulty/blown fuse. Remove the lid and follow the mains cable through the casing and to a PCBoard. On the PCBoard is a fuse, check that one. If it blows again, check the door interlock switches.
Hope that helps.
Nov 06, 2010 | Microwave Ovens
Screen keeps turning out
the problem is the power supply of your main board...you can replace the bulging/leak capacitors...to acces the power supply open the back cover of your tv..the power supply board is the pcboard which the mains supply is connected..you can also replace the whole power supply with a new one..resolder the board for its loose connections..
hope this helps good luck..
please rate my help...tnx for using fixya.
May 30, 2010 | Microtek 997M 19" Flat Panel LCD Monitor
Starter 86 F250 with 93 460
make sure wires on selinoid are on ther right sides if that isnt it replace selinoide
Feb 13, 2010 | 1986 Ford F 250
Washer not spining burn smell
belt burrt out advise new belt or new machine
Jul 12, 2009 | Maytag LAT3600A Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
