Question about Keurig B155
Keurig b155 not filling cup up completely
I have used the paperclip to clean it and i used a decalcifier. i want to take the cover off but dont know how and cant find instructions anywhere to do this. help Pleaseeeee
  • 4 Answers
SOURCE: Keurig Special Edition B60
I assume your coffe maker used to produce more coffee for each use. Roughly 6 ounces per large cup, and now is only making 3 oz. cups.
If your coffee maker is sputtering and not able to "suck" enough water to fill your cups of coffee it is most likely due to cavitation caused in the little pump due to a stoppage, which is most likely lime or scale buildup somewhere in the pump line.
To fix it, don't take your coffee maker apart. Get a bottle of distilled white vinegar, and pour it straight into the empty water resevoir. Press brew with no coffee pod so you are just running the vinegar through the system. Pour the vinegar out of the cup and back into the resevoir. Add some ice to cool it off. Repeat about 10 times. This should clear out the toughest lime scale clog.
After you notice the cups are filling full of water, Replace the vinegar with fresh water. Run about 5 or 6 cups of fresh water through the system to get rid of the vinegar.
Make coffee/tea/whatever.
Jade
Posted on Jan 06, 2008
pgh_pa_guy
  • 2992 Answers
SOURCE: My Keurig just started only filling my mug 1/2
Have you tried following the descaling procedure given in your owner's manual? The mineral build-up from hard water can cause low flow, and since the machine pumps for a fixed time this means less water in the cup. Descaling usually brings back normal operation.
Posted on Mar 06, 2010
  • 60 Answers
SOURCE: Keurig elite will not fill the cup all the way.
Time to descale
Posted on Mar 23, 2010
heatman101
  • 43501 Answers
SOURCE: My keurig is not filling up the cup with water,
Here is a tip that I wrote that will give you some things to try that will help you get your Keurig coffee brewer working again.
Keurig Coffee Brewer not making a full cup of Coffee
heatman101
-llllllllllll
Posted on Feb 26, 2011
SOURCE: my Keurig b60 is spitting water into reservoir instead of kcup
I had a similar problem except there was no water going into the K-cup. I fooled around with the machine for awhile but I had no luck. Figuring I had nothing to lose, I broke out a can of air that one uses to clean computer keyboards. I sprayed the air into the nozzle that puts water back into the reservoir and air came out of the water intake hole but not the needle that puts water into the K-cup. This meant that there was a block between the the needle and the reservoir. I plugged the water intake hole with a towel and my fingers then sprayed the air into the same nozzle. All of a sudden, a large blast of water came out of the needle. The machine worked after this. Just be careful not to put your hand in front of the needle because the water might be hot. Also, unplug your machine before doing any tinkering. Hope this might help some people.
Posted on Feb 28, 2011
Why won't it brew?
Have you cleaned the two little holes in the head?
Mine quit working and I used a paperclip, straightened out, inserted into each hole then ran a cup through, inserted paperclip again, ran another cup of water through, then it worked like new again. These little holes get filled with coffee grounds as they punch through the top of the pod, this is where the water comes out to make your coffee. I now clean these two holes every 3 months or so. Keeps it working beautifully!
Nov 25, 2015 | Keurig K10 K-cup Mini Plus Coffeemaker...
Press brew nothing happens plus screen cup size selection only shows 10 oz option.
Keurig B155 Manual Online: Section 4 - Troubleshooting. https://www.manualslib.com/
look in the troubleshooting section.
kolbrun
Nov 21, 2015 | Keurig B155
Need address where to ship Keurig to have repaired
call 1-866-901-2739 first, customer service will give you an authorization to return number. If you dont get a number they will ship it back to you. Keurig Incorporated 55 Walkers Brook Drive Reading, MA 01867
Jan 21, 2015 | Cafe Cup TM 4 Pack For use with Keurig...
Why does my Keurig only fill partial cup when it is on large cup and only seems to happen with a bold coffee
According to my Platinum manual your exit needle may be partially plugged clean carefully with a straightened paperclip. Run a couple cycles without a K-Cup inserted. This should fix your problem.
Oct 04, 2014 | Keurig Elite B40 Coffee Maker
Keurig Vue V700 not filling cup
You are experiencing a clog of the upper tube. Not outside but inside the tube. Use a paperclip, open an end force it up the tube to clear the deposits and your in business. Remember to do a Full cleaning now and again with vinegar solution. Keep Filter changes at least every 4 to 6 weeks.
Jan 18, 2014 | Keurig Vue V700 Brewing System - 110774
No water coming out of keurig
It could be that your Keurig's water line is clogged. To flush out debris, run water through your brewer a few times without a K-Cup. I'd recommend this step if your Keurig is brewing some coffee, just not a full cup.
Turn off your brewer and use an unfolded paperclip to clean out the holes in the top needle.
Still won't brew? Try the burp and slap method: unplug, remove water reservoir, turn your Keurig over and spank its bottom.
If you've given your Keurig a good spanking and it still won't behave, contact Keurig (866-901-BREW) for help.
Apr 12, 2013 | Keurig Coffee Makers & Espresso Machines
My Keurig B70 will not dispense the coffee. I have cleaned it, cleaned the needle, etc. but it still won't work. If I turn it off and on two or three times it finally will pump...taking longer and...
did you clean both top and bottom needles? Did the paperclip insert at least 1".
1. Power off machine.
2. Using a metal paperclip, insert it into left side of top needle. It must insert at least 1" deep. Insert it into slot on right side and again from back of needle.
3. Remove KCup cradle. Separate bottom from top. In the top section, insert the paperclip up into bottom needle from the bottom upwards. It will not go all the way thru and this is normal.
4. Reassemble KCup cradle and reinsert it back into coffee maker.
Sep 26, 2010 | Keurig Platinum B70 Coffee Maker
The Keurig is heating up the water, yet is does
May 13, 2010 | Keurig B60 Coffee Maker
B-60 Keurig. Does not give proper fill. The steam is weak.Stops in the middle of the filling cup process. Works fine if I just run water through it. Have descaled numerous times per Keurig instructions. I...
5. Power on machine.
6. Brew a cup of water only. There may be coffee grounds in the water and these should eventually clear during the remaining steps. NOTE: A large cup brew cycle should output a full 8 ounces (235cc). Less means there is still a blockage
Feb 10, 2010 | Keurig B60 Coffee Maker
Keurig B155 Logo
113 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
