Question about Minn Kota Boating
On low speeds the motor cuts out.if I increased the speed and turn the head vigorously from left to right on the foot pedal it would kick in and be ok for a time. The motor has stopped now. Power on.
This is a Minn Kota Maxxum Pro 80 bow mount( foot pedal).
3 Suggested Answers
  • 2920 Answers
SOURCE: MINN KOTA MAXXUM FOOT CONTROL PROBLEMS
it has an electrical connection problem... check all the connections on the pedal control. your loosing connection making it die and when you kick it it connects again... look for a frayed wire. or a corroded connnection.
Posted on Sep 21, 2008
  • 3 Answers
SOURCE: Prop spins slow on any speed on the foot pedal
There is a good chance that the control board is bad. This is a common problem with these units. I have replaced my control board twice. When the control board goes out, some function of the unit will not work correctly while other functions work fine. The first time mine went out, the prop motor would not work. The last time the board went out, the unit would only steer right.
Posted on Jun 04, 2009
My vintage kenmore hand wheel was frozen now it turns manually but not when I use the foot pedal, then it won't turn
Either you will replace the belt or have to adjust the motor/belt tension.
1. The motor can be loosened by a couple of bolts. This allows the motor to be moved to adjust the tension of the belt.
2. The tension can be adjusted properly by turning the motor on with the foot pedal; low speed.
3. While the motor is running move the motor in a fashion that will loosen or tighten the belt. The correct location will allow the motor to run at it's highest speed.
4. Re-tighten the bolts and retest the machine.
May 04, 2017 | Kenmore Sewing Machines
Minnekota power drive 55bl. stuck at high speed. The foot pedal could turn the motor on and off, left and right, but when use slider to control speed it doesn't seem to have any contact.
If you can get inside the rheostat and move the wiper arm to properly wipe across the resistance then................
But often there is no getting inside and the only thing you can do is to replace the rheostat itself.
Aug 31, 2015 | Boating
Replacing clutch type with a variable speed 3/4 hp 400 watt motor. I need a compatible foot pedal. can you suggest one that will handle the wattage
Sewing Machine Foot Pedal - Alibaba.com
www.alibaba.com > Machinery > pedal
804 Results - Sewing Machine Foot Pedal, Buy Various High Quality Sewing Machine Foot Pedal ... Power: 400W Compact AC servomotor(direct-drive system).
Jul 30, 2015 | Sewing Machines
My pfaff 1222e is running slow
1. Remove any stuck material from the feed dog, bobbin area including the hook (pointed object under bobbin). Lubricate as you go.
2. Remove top and end of sewing machine to look at the motor and belt. Place pressure on the foot pedal. Still slow?
3. With bolt attached to motor release the pressure on the belt. Now, place pressure on the foot pedal. Did you notice any increase in speed?
4. Apply pressure on the foot pedal and simultaneously adjust the motor. Adjusting means tightening of the belt and making it move in a straight line. (If it doesn't move straight it puts pressure on the motor so it will move slow.) When you have adjusted the motor to the right position the motor will be at it's highest speed.
5. If the pressure foot is the problem it will require a pro to take care of it.
Apr 16, 2015 | PfaFF Sewing Machines
I have acquired a necchi automatic supernova. I want to know how to install a foot pedal - it never came with one. It did come with a sewing motor controller (dark brown/black block with two cables leading...
foot pedal is a HD voltage regulator that controls the motor speed by simply increasing/decreasing voltage supply. e.g. if the two wires to the foot pedal were connected the motor would get full voltage and run at max speed. most foot pedals can be adapted for your machine
Feb 16, 2014 | Sewing Machines
Thumping sound in front end while driving
Have the wheel bearings been checked?
Sep 24, 2012 | Cars & Trucks
Machine wont stop once started.
your foot pedal is just like an accelerator , lifting and pressing the foot increases and decreases the speed ,but if this does not happen ,,change your foot pedal
Mar 18, 2010 | Singer Sewing Machines
Can not start at a slow speed with foot pedal need to now how to adjust start speed
THE FOOT PEDLE IS NOTHING BUT A REASTAT. A REASTAT IS A WIRE WRAPPED AROUND A CONDUCTOR THE WINDINGS START OUT FAR APART AND GET CLOSER TOGETHER THE FARTHER YOU PUSH THE PEDLE DOWN . THE FAR APART WIRES ARE THE SLOW SPEED THE CLOSER ONES ARE FASTER SPEED
THESE WIRES WILL WEAR OUT OVER TIME OR CORRODE OVER TIME AND CAUSE THIS PROBLEM. TRY SOME ELECTRICAL CONTACT CLEANER AND SPRAY THE FOOT PEDLE INSIDE ANY WHERE YOU CAN AND LET DRY. MOST CONTACT CLEANERS ARE NONE CONDUCTIVE AND DRY IN MINUTES
Aug 15, 2009 | Consew 206RB
The hand wheel will not engage by itself when I pressonthe peddle
hi! there,
the foot pedal lectronicaly or carbon speed are controling
the speed of sewing machine motor as long your put
pressure you increase the speed motor,replce foot pedal
cheers and have a nice day,
there are two posibility in this case,check your motor brush
carbon which locate inside the motor,posible change motor
Apr 03, 2009 | Sewing Machines
Heavy steering while care is stationary.
At idle speed the the pressere deliver by your steering pump are low; try to modified your pulley to increase the speed at low idle.
Oct 19, 2008 | 1995 Jeep Wrangler
Boating Logo
116 people viewed this question
Top Minn Kota Boating Experts
Mike Marcotte
Mike Marcotte
Andrew Taylor
Andrew Taylor
Colin Stickland
Colin Stickland
Are you a Minn Kota Boating Expert? Answer questions, earn points and help others
