Question about Canon imageRUNNER 2525 AllInOne Laser Printer
Canon ir 2525. When I try to make photocopy it making scan and then I don't getting copy of the document in screen it showing scanning and printing paper jam but while printing reports itz working
SOURCE: Document Jam in Dell 1600n
The Automatic Document Feed (ADF) has a white rubber pad that wears out. You can find it by opening the ADF cover and removing the roller bar. Under that is the white rubber pad. Pinch the sides together and the assembley comes out. Contact Dell for the replacement. You may also refer to the Dell 1600n Owners Manual for instructions.
Posted on Jun 19, 2008
  • 1314 Answers
SOURCE: vertical black line in scan document not in copies through document feeder
Lift the lid and to the left of the main glass is a smaller glass; that is what scans during the feeding process. Make sure that it is completely clean; even a speck of dust can cause a line to appear. I took a lens wipe and cleaned mine and my line was gone.
Posted on Jun 01, 2009
SOURCE: trying to scan, but keep getting error code
I finally got a solution to my problem, which is the same as this one. When trying to scan via USB, you have to make sure the unit is set to USB. On the top panel just above the LCD display, is 3 buttons, Copy, Fax, Scan. Hit the SCAN button, till the display says USB SCANNING. Then try to scan again. Good luck!!
Posted on Sep 05, 2009
SOURCE: trying to scan, but keep getting error code 2,162,0 My scanner pr
This works!:
noavatar_s.gif the_sunman
Rank: Apprentice
Rating: 94%, 4 votes
Posted on Oct 21, 2009
  • 1684 Answers
SOURCE: i get vertical lines on scans and copies when
Check out this page on our web site at: This page shows you what to do to get rid of the lines on scans and copies.
I hope this helps, if so please rate our solution.
Corporate Computer
Posted on Jan 12, 2010
MY canon iR3035 ccd scanner position is faulty..
Re: canon ir 3035 copy not lined up 1/4 inch higher it scans but configuration page i
service mode > copier > adjust > adjust xy > adjust Y input the value from the label on the front cover
This is all I could find. Try adjusting by 1/4 inch. Thank you Santosh
Jun 25, 2016 | Canon imageRUNNER 3035 Black and White...
How to make darker copies
if your referring to photocopying but printout is darker, it doesnt work. canon copiers produce copies like the original or better than the original sometimes. try to scan the file in custom mode and adjust the brightness and contrast and click preview to view the outcome before scanning it then print it later
Sep 30, 2013 | Canon PIXMA MP210 Photo All-In-One Printer
Ir 3530
please cleen your scanner home position sencor
Jun 30, 2013 | Canon ImageRUNNER 3570 Copier/Printer
Canon ir2016 show
Mar 22, 2012 | Canon iR 2016i Black and White Copier
When I am photocopying and scanning documents I am noticing vertical lines on the print in the middle of the page which is ruining the copy, any ideas? Alos message intermittently coming up waste toner...
Most probably you are using the automating document feeder for the photocopy or scanning. If you can lift up the document feeder , there should be the mirror where you can put the original document for manual photocopy or scan. Clean the edges of the mirror with a printer cleaning liquid. There may be some foreign particle stuck there or it is just dirty from long use. Hope this helps.
Sep 02, 2011 | Office Equipment & Supplies
My canon MP40 will not scan/copy
This is because you have NOT installed the actual Drivers for the scanner and the Scan Manager. Driver link below. Ensure you get entire package A:SO get the user manual, it shows you what to do.
May 14, 2010 | Canon PIXMA MX310 All-In-One Printer
How do I scan on the Canon imageRUNNER 3300
instalation of photocopier/scanner with pc model no IR-3300. Kindly tell me the procedure to install it and make it functioning...
Mar 26, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
Cannon MP530 scanner won't scan document it shows error code
hello ! reinstall the machine fax and scanner program cd's may be the installation was not completed or is the machine having issues .
Jul 22, 2009 | Canon PIXMA MP530 All-In-One InkJet...
My Canon Imagerunner 2200 won't scan.
Sorry that was actually me...after i asked me to i did.
Okay, you need to download Canon Network scangear from the Canon website. then take your document...put it on the top feeder...turn you scanner up microsoft word 2003..insert, picture....from scanner or camera select network scangear....custom insert....then scan. The machine needs to be hooked up to a network...but note...a simple cross over cable or usb between pc and the photocopier will not work.
Oct 22, 2007 | Canon (6981A002AA) for imagerunner 2200,...
Canon imageRUNNER 2525 AllInOne Laser Printer Logo
old marine
old marine
