Question about Keurig B155
I have a keurig b155 commercial maker. It is not brewing even though it makes noise like it is trying. How do i fix this?
SOURCE: keurig b40
I dont think these machines are worth the money at all.
Posted on Aug 16, 2008
SOURCE: keurig coffee maker won't draw water from the resevoir
I just got mine to work by forcing water into the pump to force it to prime. I took a syringe for a meat injector and built a gasket so it would seal over the water intake. Then I forced several syringes of water into the pump till it finally picked up and caught its prime.
Posted on Mar 02, 2009
SOURCE: keurig maker dispenses too little water when brewing
I found this solution on another post. Unfold a small metal paper clip and insert through the lower piercing needle of the cup holder to **** out any debris in the needle.Even a small piece of coffee or debris can slow the water flow through the cup.
Posted on May 01, 2009
  • 1772 Answers
SOURCE: keurig coffee maker makes loud noise single cup
The brewer should be de-scaled at least every 3-6 months. Scale is harmless, but if left unattended, it can hinder optimal brewer performance. De-scaling your brewer regularly helps maintain the heating element, removable water reservoir and other parts of the brewer that come in contact with water. Better water quality and water heating means a better cup of coffee, tea, hot cocoa or iced beverage. We recommend de-scaling your brewer at least every 6 months (every 3 months if your water has a high mineral content). The de-scaling process involves using 48 ounces of undiluted white vinegar.
Take 48 oz of white vinegar. place in tank. pretend you are making coffee (Do No Use K Cup). let the water fill you mug. then empty that mug. Do it again until tank is empty. then let sit for 4 hours.
Then fill with fresh water to the top. let that tank of water run thru. towards the end taste the water.
If you taste vinegar..use more clean water, until the taste is ok.
I tried to help you. Please help me and Vote/Rate this response. Thanks and good luck
Posted on Dec 21, 2010
  • 3 Answers
SOURCE: my k cup reusable coffee
I had the same issue and found a **** fix that is working well. The issue is that the hole in the my-kcup doesn't seal to the machine so I take a square of foil and put it over the top of the closed my-kcup assembly, crimping it under the rim of the cap. This seals the assembly and forces the water through the my-kcup. It also makes a better cup of coffee because the water is all going through the grounds.
Posted on Dec 31, 2010
Press brew nothing happens plus screen cup size selection only shows 10 oz option.
Keurig B155 Manual Online: Section 4 - Troubleshooting.
look in the troubleshooting section.
Nov 21, 2015 | Keurig B155
Keurig loud squeaking noise
End of life procedure "Say Good Bye" or have a fire!
Mar 03, 2013 | Keurig B60 Coffee Maker
Water runs continuously
shut off valve is dysfunctional or dirt is trapped inside the exit tube.
Feb 21, 2013 | Keurig B155 Small/Medium Office Brewer
When I push the "brew" button, it makes noise like
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
Jul 27, 2011 | Keurig Platinum B70 Coffee Maker
Keurig will start to brew..noise get louder and stops before brewing.
Here is a tip that I wrote that will give you some things to try that will help you get your Keurig coffee brewer working again.
Keurig Coffee Brewer not making a full cup of Coffee
Jan 27, 2011 | Keurig B60 Coffee Maker
Keurig B155 Logo
156 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
