Question about The Video Cameras
DSR-SR68 camcorder getting error message "Use New AC adapter or reinsert" new charger but getting the same message.I have tried removing the battery, pressing reset button, etc.
silly girl
  • 513 Answers
SOURCE: Not receiving power from the battery, but getting it from the power adapter
Check for corrosion on the battery contacts, If you find some clean it using a pencil eraser. Otherwise you're looking at an internal malfunction that prevents the cam to draw power from the batteries. Some transistor needs replacing, if you can get to a lab that has experience working on these, shouldn't be too expensive. Good luck
Posted on May 31, 2006
  • 76 Answers
SOURCE: Reinsert cassette error... cannot record via tape
What error message is it giving to you ?? as this will be a good indication of fault.You have tried all the usual things to try by the sounds of things,
Posted on May 15, 2007
SOURCE: screen shows use new ac adapter or reinsert
i found a solution to my problem. i just let the cam on until the battery is totally empty and recharge it.
tell me if it worked for you
Posted on Jun 30, 2008
SOURCE: HDR-HC1 Sony camcorder- reinsert the cassette error message
Bill,
The problem is with the S-reel. Take the tape out, remove the battery, and give it a slight bump. This usually fixes the issue for a couple of weeks. I haven't heard of any permenant fixes. I took my cam into circuit city (before they closed) twice for the same issue. Very frustrating when you don't know what the issue is.
Posted on Mar 30, 2009
SOURCE: my hitachi camcorder says I need an AC adapter/charger
Hi Riannasmail,
You need a camcorder to charger DC cable,it looks like a battery with a trailing cable that has a DC plug on the end that plugs into the Hitachi battery charger.If you are in the USA you should be able to buy one for about $8 to $12,if you live in UK you will be ripped off at about £24.
I made my own adaptor and charger system for less than £20,If you need more info please contact me.
Posted on Jun 27, 2010
Canon charge light blinks 7 times
If your Sony camcorder displays a tape transport or mechanical error code always try resetting the camcorder. This is done by removing the battery or ac power, wait 10 seconds, reapply the battery or ac power and try again. If it still goes into error try another tape. The camcorder will not always display an exact error code. Sometimes you may see an error message such as, "Reinsert the cassette", on the LCD screen. This is the camcorders way of saying, "Take the tape out and try again." Try reloading the same tape as well as a new tape. If the camcorder is still going into error this means it is time to send it in for service or repair.
The camcorder may also sometimes display a "Reattach Power Source." This is the camcorders way of saying,"Try resetting my system,so I can try again." Many people mistaken this error and think they have a problem with the battery or ac adapter. This is not true and has nothing to do with your battery or ac adapter. Reset the camcorder by removing the battery or ac power, wait 10 second, reapply the battery or ac power. If the error reappears the unit needs to be serviced or repaired.
Jan 23, 2013 | Canon VIXIA Video Cameras
Video Camcorder Error Message
Per SONY; To service the C:31 code, Sony recommends you do the following: Turn off the camcorder. Remove the battery or disconnect the AC power adapter for 60 seconds. Insert the battery or reconnect the AC adapter. Turn on the camcorder. If the error message appears, service may be required.
Sep 15, 2007 | Sony Handycam CCD-TRV608 Camcorder
Sony 700X digital handycam
solution 1: Try smacking the side of the camera relatively hard with the palm of your hand. Eject the tape and reinsert. You may need to do this a couple of times. solution 2: Turn off the camcorder. Remove the battery or disconnect the AC power adapter for 60 seconds. Insert the battery or reconnect the AC adapter. Turn on the camcorder. If the error message appears, service may be required. If your camcorder still shows the same error code, then you'll have to send in your camcorder for service additional info that might help: According to the manual, the error code C:31:xx:xx means an error that >the owner can fix by himself has occured and that by taking out the >cassette and replacing it or by disconnecting the battery pack and >fixing it back should solve the problem. Error "23" means: "S reel emergency during normal rotation", i.e. the problem is with the tape deck mechanism and specifically the supply reel.
Aug 21, 2007 | Sony Handycam DCR-TRV350 Digital Camcorder
Hello, I am Angel from Romania and i've got a brand new Sony Z5.\r\nToday i discovered that i have a problem with my camcorder.\r\nWhen i insert a cassette, on display is shown "reinsert...
Sony is pretty secretive about the :23 code. It can't be found anywhere. However, to service the C:31 code, Sony recommends you do the following:
  1. Turn off the camcorder.
  2. Remove the battery or disconnect the AC power adapter for 60 seconds.
  3. Insert the battery or reconnect the AC adapter.
  4. Turn on the camcorder.
  5. If the error message appears, service may be required.
OR
This may seem silly, but it worked for me. I found this on another discussion forum. Try smacking the side of the camera relatively hard with the palm of your hand. Eject the tape and reinsert. You may need to do this a couple of times. Surprisingly it worked for me
Hope this is helpful
*Rating and comments are invited for this solution
Nov 11, 2010 | Sony HVR-Z5U High Definition DV Camcorder
My hitachi camcorder says I need an AC adapter/charger
Hi Riannasmail,
Oct 14, 2009 | Hitachi DZ-MV750MA DVD Camcorder
Will not rewind
If your camcorder still shows the same error code, then you'll have to send in your camcorder for service.
Sep 28, 2009 | Video Cameras
ERROR MESSAGE C 31:23
The error code is part of a self diagnosis feature of your cam. This particular code refers to something being wrong which you can fix yourself. The steps you should take, involve removing tape, and reinserting. removing power adapter plug and reinserting, remove battery pack and reinsert...
power down before each step, and power up again to check working status. The result of these checks should allow you to narrow down the problem.
You may have to look at trying a new battery, or replacing the cassette, or replacing power cord, or you just had not properly hooked something up, or the cassette wasn't properly seated.
These codes and their meaning can be found in your user guide, or manual. Good Luck!
Nov 11, 2008 | Sony Handycam CCD-TRV108 Camcorder
Screen shows use new ac adapter or reinsert
Mar 15, 2008 | Sony DCR-HC26 Mini DV Digital Camcorder
Video Cameras Logo
61 people viewed this question
Top The Video Cameras Experts
Lawrence Oravetz
abdul rauf
abdul rauf
Glenn Smart
Glenn Smart
Are you a The Video Camera Expert? Answer questions, earn points and help others
