Question about Nextwave Televison & Video
Bought from CConverters, Nextwave THM 4290 set top box.It shows "boot" but box cant be manually turned on to reboot. remote does nothing either.Is the remote or box faulty,
SOURCE: set top box and remote control
I have the same problem. When I move the 8300HDC away from the TV, or power off the TV, the remote responds. There seems to be some kind of RF interference, which makes no sense since the TV shouldn't emit RF, and the the box should be using IR only for remote input. My TV is a 46" LCD Samsung. Try turning off the TV and see if the 8300HDC responds to powering on and off with the remote.
Posted on Nov 18, 2007
SOURCE: Nextwave SUC-2500C English manual
Posted on Jan 12, 2008
SOURCE: I bought an Alba CDVB4 and the remote isn't right
Not sure if you found the problem for this, but I had the same problem and couldn't find any reference to this except your question so thought I would put up an answer in case it can help you or anyone else.
Aparently, Alba have got hold of the codes that Toshiba use for their remote controls, so if you have a Toshiba telly an Alba product like this won't work. The only solution being to return it and get a different make.
I returned mine twice for a straight exchange thinking it was just a manufacture fault before I found this out. I then exchanged it for a Bush set top box - only a fiver more - and it now works PERFECT!
I hope this helps some.
Posted on Feb 21, 2010
SOURCE: bought onn tv from asda
just will not switch on - checked everything, no light coming on.
Posted on Feb 22, 2010
  • 518 Answers
SOURCE: I need a manual and remote for Bush set top box DFTA 10HD
try the bush web site for a manual
Posted on Jul 07, 2010
Need code for Nextwave THD1690 for URC 1629
1038,1046. Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts.
Search the site by type in the brand name to your device, in the "Search box at the top right of the display window" to see the set-up codes to your device, with different brand remote controls.
Nov 24, 2015 | One For All Televison & Video
Hi have a urc 2940 got it 2 work fine on 2 tvs but not on 1 we bought it for sony bravia can you help please
You have to set the new remote control with Sony Bravia; with the control codes said for it. Check the user manual with the remote control you did bought; to get set-up code/s and set-up procedure. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Mar 01, 2015 | Sony Televison & Video
Work recovery system, it wants to access recovery options, but i cant remember password
reboot laptop and keep tapping the f8 key while its booting.
you will get an options screen, select ''boot into safe mode''.
it should then boot up in safe mode, once on desktop go to start menu>>all programmes>>and look for the acer recovery tools...ity will be their as all acers have these tools.
in the recovery tool, you will have the following options.
factory restore computer = thios will erase all your files from the hard drive and reinstall windows again, once done it will be the same as when you first bought it and took it out of the box.
or..restore windows files and settings only = this restores the windows files system so as to fix the errors that are causing problems, none of your personal files will be erased or lost and will still be on the computer once the operation completes.
i would go with the first option and do a factory reset. If you have personal files you want to keep, then when booted up into safe mode yhou can copy those files to a usb thumb drive or a CD or whatever. Once you have your files saved, perform the factory restore instalation.
Or you could just boot into safe mode, and if you get onto desktop, goto start menu>>all programmes>>>accesories>>system tools>> back up and recovery. From their, select ''system restore'' will show a list of restore points with dates next to them. Their will also be a box unticked that says ''show more restore points''. tick that box so all restore dates and points are showing.
Then select a restore point and date about 5 to 7 days before the problem occured.
so if the problem happend on say the 7th november.....restore it back top around the 30th october.
this will just undo any system changes that are causing errors and get your pc working again without affecting any of your personal files.
if all the above fail, you will have to reinstall windows yourself, just download the iso from microsoft website
download the 'windows 7 usb tool' from microsoft website.
insert a USB thumbdrive at least 4GB in size.
run the windows usb tool and follow the on screen instructions which will then
load the windows downloaded file onto your usb drive.
once done, reboot pc and hit f12 (or whatever key it is for your model to enter the boot options menu - a quick search on google will tell you the key for boot menu if f12 or esc key do not work).
once in boot options your usb device to boot from and press enter.
windows will then install on your laptop.
once on desktop, goto start menu and eright click on ''computer''.
select 'properties'
then select 'device manager....and cxheck to see what drivers may be missing.
once you see what drivers are missing...goto acer (you may have to use another computer to do this if your ethernet or wi fi driver is missing and you cant access the internet.
once on acer website, selecter the drivers and manuals will then ask you to input your computer model number, brand, operating system.....then it will give you a list of all the drivers for your download the ones you need, then install them by opening the file and double clicking the ''set up .exe' file.
once all drivers are in reboot nachine and then wait for wqindows update to kick in and apply the neccesary updates.
Nov 07, 2014 | Acer 4220-2346 Notebook
Sony trinitron tv
set it in digital system and you can do it easily with the remote control device. search for the signal input as necessary
Jun 03, 2013 | Televison & Video
Antsig AP593 universal remote
Not sure if you've decided to throw your remote control away already or not. But try using the manual search code. Basically press "TV" (light blinks once), then press the "Up" channel button and the "up" volume button at the same time (light comes on permanently), then hold down "Power" whilst putting the remote RIGHT IN FRONT of the place where your tv receives signal (usually where you can see a light), and I mean right in front! Hold it down until your tv powers off. Then it should be configured and working. It took me about 1 minute or more for the TV to react and turn off. Then you can check if it turns on again and if the channels are working.
Jul 17, 2010 | Televison & Video
I cant get my ibook g4 to run it turns on with blinking folder
Blinking ? mark folder means that your OS can't be found. Take out your RAM underneath the keyboard and re-insert and try again. Nothing? Install a different new RAM chip and try again. Nothing? Install your disc 1 install disc, power down, wait a few seconds, now press the power button to turn on, now press and hold the option button, until your disc 1 shows up, select it, and bring your pointer to the right arrow on the screen and press enter. Now your booting from the disc 1. Go to disc utility folder at the top of the screen and select your hard drive and then select repair disc permissions. Then shut down and reboot when finished. Nothing? Your hard drive is fu.k.d-Try re-installing the OS. Nothing? Your hard drive is really fu.k.d-You need a new hard drive. Installing a new hard drive in the iBook is a *****. You may want to pay someone to install a hard drive or you can just get a new laptop.
Mar 09, 2010 | Apple iBook G4 Mac Notebook
I have an error code 01 on my sagem PVR set top box. The manual says perform a programme search then doesn't indicate how. i have tried to press the menu to get the original installation but nothing...
Unplug the box from the mains and leave fro 15 mins. Unplug the antenna (aerial), plug back into the mains and switch on. It will show 09 error; ignor. Press ók'on the remote. The box will reset and reboot into stby. Plug antenna back in and switch on. With a bit of luck you will be able to do an automatic channel scan (refer to your manual).
Er 01 refers to a failed upgrade, so you may have corrupted firmware, which is not good.
Jan 18, 2010 | Sagem PVR 6280 Freeview DTV Receiver /...
do a manual code search until tv shut off that will be your code
Aug 24, 2009 | Televison & Video
Cant find the right remote control codes
look in back of remote where you put battiers there should be a sticker that will say this... turn tv on press and hold set button tell it blinks or stays lit push tv on remote push on and off tell tv shuts off press enter now you should have it
Feb 17, 2009 | GE RM24930 Remote Control
I have a hikona 14" tv havew lost the tuning manual. Can you help!
Dec 22, 2007 | Philips Magnavox Learning Universal Remote
Televison & Video Logo
Top Nextwave Televison & Video Experts
Are you a Nextwave Televison and Video Expert? Answer questions, earn points and help others
