Question about Lands Phones
I have a KX-GL 430,a few numbers have been blocked accidently. This happened when I first got the phone.I didn't get a Manual with it.I don't know how to unblock the numbers, can you help me?.
4 Suggested Answers
SOURCE: kx-TGA641T how does one unblock blocked number
http://ww2.justanswer.com/uploads/MCVGreg/2009-09-21_023145_KXTG9331-Remove-Blocked.pdf
Viewing/editing/erasing block call
numbers
1 {MENU} -> {#}{2}{1}{7}
2 {V}/{^}: Select the desired item.
~To exit, press {OFF}.
3 Proceed with the desired operation.
■ Erasing a number from blocked list:
{Erase} -> {Yes} -> {OFF}
you can also edit:
■ Editing a number:
{Edit} -> Edit the phone
number. -> {Save} ->{OFF}
Posted on Feb 28, 2010
SOURCE: Hi there, I have a Panasonic kx-tga840c cordless
Go to the main menu. Then click on the wrench Icon (initial setting). then go to call block. From that list you can remove the blocked number.
Posted on Feb 11, 2011
AndrexT
  • 20966 Answers
SOURCE: how do I ubblock a number on model kx-GL430
same as before Eula
How do I unblock a number from my blocked calls list? - Panasonic ...
eng.faq.panasonic.com/.../how-do-i-unblock-a-number-from-my-blocked-calls-list%3...
  1. Cached
To erase a number from your blocked calls list;. Press [MENU] [#] [2] [1] [7]; Press the [?] or the [?] button to select the telephone number that you want to erase. ubblock number on model kx GL430 Google Search
Posted on Dec 11, 2016
How do I ubblock a number on model kx-GL430
same as before Eula
  1. Cached
Dec 11, 2016 | Panasonic Lands Phones
I need to know how to unblock a telephone number on my model #KXTGD220 telephone
Here is a link to the owners manual page for call blocking. It has a lot of abbreviations I don't understand, but hopefully they will match what you see on your menu and display.
https://www.manualslib.com/manual/888692/Panasonic-Kx-Tgd210.html?page=26#manual
Jun 01, 2016 | Clothing
How do I unblock a phone number
You can find the procedure in the programming section of the manual. Look for "Viewing/editing/erasing call block numbers" The Panasonic KX-TGEA20 model number crosses to the additional handsets for your cordless phone, but these handsets are compatible with the TGEA-21X through the -27X series base units. If the [MENU] # code sequence is different you will have to share your exact model number.
The Quick -n- Dir(ect) answer is:
    1.[MENU] #-2-1-7
    2.<Navigator key "up/down" arrows> to "Block a single number" ? [SELECT]
    3.<Navigator key up/down arrows> to highlight/select the desired entry.
    This should offer you the choice to edit or erase, so choose...
    4.[ERASE] ? <Navigator key up/down arrow> to "Yes" to confirm your action? [SELECT]? [OFF] The number should no longer be on the "Blocked" list if you go back in and start from step 1 (above).
    If you have lost your original manual you can get a replacement from the Panasonic FTP site here:
    ftp://ftp.panasonic.com/telephone/om/kx-tge210_mul_om.pdf
    V/R,
    Veg
    If a train station is where the train stops, what happens at my workstation?
    ~Author Unknown
May 05, 2016 | Asavings Panasonic KX-TGEA20S Dect 6.0 1...
I have a Panasonic digital cordless phone model KX-TGE210. I accidentally block a number on my phone that I need to unblock to receive calls. Can you tell me how to unblock a number?
I have similar phone.
Press Menu then enter #217 to edit blocked numbers.
Use up or down arrow to scroll through numbers.
You can erase or edit blocked numbers.
For more info, see manual at: http://www.manualslib.com/manual/754430/Panasonic-Kx-Tge210.html?page=1
Mar 08, 2016 | Panasonic Lands Phones
How to clear a memory full in the block feature on the KX-TG4031?
I have a KX-TG7644. Had to look harder for the Call Block directory. The manual really didn't help much. Press "Menu", go down to "Initial Settings", go to "Call Block". You can access the list and delete all or part to open up memory space. I had to do this after all the election calls.
Jul 09, 2011 | Panasonic KX-TG1033S Cordless Phone
Hi there, I have a Panasonic kx-tga840c cordless phone and I accidently blocked a number from calling my phone. I lost my manual and I can't figure out how to undo the number I blocked.
Feb 01, 2011 | Panasonic Lands Phones
How to unblock a number on model#kx-TGA931T panasonic house phone. Number was blocked by accident.
THIS IS HOW YOU DO IT!!!!! EASY VERSION
Step 1
Press the Menu button followed by the # key on the handheld unit.
Step 2Enter 217 on the numeric keypad to access the blocked numbers menu.
Step 3Press the down arrow on the keypad. Scroll through the list to select the number you wish to unblock.
Step 4Press the key under Erase to remove the phone number from the list.
Step 5Select Yes to confirm your selection.
Feb 25, 2010 | Panasonic Lands Phones
Kx-TGA641T how does one unblock blocked number
numbers
you can also edit:
■ Editing a number:
Sep 28, 2009 | Panasonic Lands Phones
Programe my phone KX-T7730
The phone you have (KX-T7730) requires a phone system to operate. This phone can be installed on a few different Panasonic phone systems. You need a "programming" manual for the phone system to do what you want (not a user guide) so you will first need to determine which system you have. Look for a part number on the system itself, it should start with "KXT" just like the phone.
Sep 16, 2007 | Panasonic KX-T7731 Corded Phone
Program manual
Your phone will work on a few different Panasonic phone systems. If you are looking for manuals on KX-T7720 and KX-T7720 all you will find is a user guide for the phone. You need to determine the model number of your phone system before starting to look for a programming manual.
Jul 17, 2007 | Panasonic KX-T7730 Corded Phone
Lands Phones Logo
Top Lands Phones Experts
David Burbee
David Burbee
Are you a Lands Phone Expert? Answer questions, earn points and help others
