Question about Element Televison & Video
My element tv has no picture
Everything on tv works, except I have no picture
  • yosvani gutierrez
    yosvani gutierrez Dec 11, 2016
    Hi tammy davenport, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
2 Suggested Answers
  • 101 Answers
SOURCE: everything works except no picture of tv
The Television may be out of synchronization with your remote or may be configured incorrectly.
1. In front of your Television, press the Help button on your Harmony Remote.
2. Answer No when asked "Did that fix the problem?"
3. The Harmony will then ask, one by one, if all of your required devices powered on when the Activity was started. Answer Yes or No until all required devices are powered on.
4. Answer No if the remote asks if the TV is set to the correct input needed for the Activity. In this example Input 4 is used, though this may vary from your setup. If the TV switches to another input but no picture is seen, continue answering No until an image appears.
5. If you now have a picture on your TV screen, answer Yes when asked if the problem is now fixed. Your television was simply out of synchronization with your Harmony One and should now work correctly. Please try switching between your other Activities to see if they switch correctly. If this has not fixed the problem, proceed to the next section Confirming your Activity Settings.
To confirm your Activity Settings, please follow the steps below:
1. Launch the Logitech Harmony Remote software and login to your account.
2. Click on the Activities tab on your home page
3. Click on the Settings button for the Activity you wish to troubleshoot.
4. Select Review the settings for this Activity and click on the Next button.
5. Confirm the input chosen for your television is correct. Select No, I want to run the setup wizard again to change these settings and click on the Next button.
6. Click on the Next button through the Activity setup screens until you arrive at the screen asking the question "What input or channel does your ... TV need to be on? From the list, select the input that the TV uses for this Activity. Once finished, click on the Next button.
**NOTE: It is recommended to perform these steps for all Activities that use the television.
8. Click on the Done button on the Set Up Activities: Summary page.
9. Click on the Done button on the "Select the Activity settings you would like to modify" screen.
10. When you have finished, click Done to save your changes.
11. Click on the Update Remote button to update your remote.
Posted on Jan 21, 2010
Where is the inverter board located on the element flx-3210? Is it somehow combined with the powersupply? I've taken the TV apart and have found everything except a part that resembles an inverter...
Yes, inverter circuitry is combined in one board together with the power supply circuitry. It is beside the connectors of the power supply board to the mainboard. You can see two high voltage transformers, these are the one producing high voltage feeding the bulbs...
Nov 01, 2011 | Element Electronics FLX3210 32 in. LCD TV
I have an Element 32" LCD TV that is 3 months old. Everything works except I can't change the channels. If I push the channel number, it will go to that channel, but if I try to use the remote or the...
I talked to the manufacturer & they said that all I needed to do was to run the channel search, uninterupted, again. I did it & everything works. Thank you for your input.
Mar 19, 2010 | Element Electronics FLX3210 32 in. LCD TV
Lost entire picture, sound and everything else OK
check the invertor boards resistors they power the back lights
also check for any capactors that have blown (raised tops) they look little bateries
Dec 12, 2009 | Element Electronics FLX3220F 32 in. LCD TV
Av and cable inputs stopped working over night
this is caused by your Hyper board failing
It is not availble anymore but try Tops Electronics in Haverhill ma or shop
Nov 24, 2009 | Toshiba 50H82 50" Rear Projection...
Can not find code for cable remote control for a element tv ELCHW321
i used code 10178 and the everything works except for input button, unfortunately you cant switch between inputs
Nov 06, 2009 | Televison & Video
Everything works except picture
Most probable cause is the vertical output IC. You can get a replacenment at the following link.
Feb 02, 2009 | Philips Magnavox 51MP392H Rear Projection...
B/W Picture Only.........No Color
Maybe the menu set-up got adjusted somehow. Use the remote or on TV menu buttons and go to picture using the ch+ and ch- increse the color. I hope it's that simple.
Sep 23, 2008 | RCA 27V530T 27" TV
Rca truflat with green tinted picture?
Just because a machine has failed, there is no cause for you to call it a stupid TV. And as it is only 6 months old, why not take it to the Company service Centre? There must be warranty.
Apr 01, 2007 | RCA 27F530T 27" TV
Televison & Video Logo
Top Element Televison & Video Experts
Are you an Element Televison and Video Expert? Answer questions, earn points and help others
