Question about Panasonic viera tc-p60gt30 60-inch 1080p 3d plasma hdtv
I have a 2011 Panasonic tc-p60gt30. It will not turn on, there is no relay clicking, no buzzing, no blinking light. p board needs replaced but 1is main and 2 sub p supplies. How do I know which one?
    Top Expert:
  • Panasonic Master
  • 75,032 Answers
If you wish to get some details; check the site linked here. Pull up older posts.
Circuit diagrams to many popular brand TVs and other devices are given. You can get details there. Search the site by type in the "brand name" of your device, in the "Search box at the top right of the Homepage" to get gathered related posts.
Posted on Dec 11, 2016
SOURCE: Vizio P42HDTV Power on Diagnosis
Please check the U29 8 pin little surface mount mosfet it has this letters > FDS4935 > > In this part inputs 13.2 volts which is ok for the near 12 vdc but it > outputs 1.250 vdc i am 100% sure that this is all the problem > > check it out, and tell me if you´re agree with me > > On this output pin it feeds the audio Ic, the 7809 and the tuner side board > which needs de 12vdc too and its getting only the 5vdc part > > what do ya think?? > > Richard
Posted on Apr 13, 2008
SOURCE: Panasonic TH-50PE700U red light flashing 6 times
Replaced the sc board and tv works fine again.
Posted on Jan 22, 2009
  • 8457 Answers
SOURCE: plasma 50 inches dont turn on
The power supply board is dead.Tries the websites like, to buy the refurbish power supply board for the replacement.
Posted on Jun 22, 2010
  • 736 Answers
SOURCE: I have Samsung UN46B8000XFXZA LED TV. After power
Yes based on your testing it appears that the power supply is at fault solely and you can opt to attempt a repair or replace it altogether. Unfortunately you will not be certain that the main board does not also need to be replaced until you have repaired the power supply.
Posted on Feb 05, 2011
  • 22 Answers
SOURCE: Sanyo DP50747 Replaced Power Supply still not working
this issue is related to either the y sustainer and z sustainer boards, checking the fuses on the y/b will giving you a good indication, if they are open(bad) then you'll have a easy fix, if not, i would try replacing the y board first.
Posted on Apr 16, 2011
I have panasonic TC-P60GT30 that will not turn on. I turn it off at the power strip and then turn it back on it clicks once no lights a minute later clicks again then nothing it won't turn on....?
Main board fault. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Jan 04, 2016 | Panasonic Televison & Video
How do you replace a fuse on the 2011 Panasonic TC-P55VT30 plasma TV?
gently lie it facedown and unscrew the back to reveal the boards and fuses
Jul 28, 2015 | Panasonic TCP55VT30 55" VIERA 3D HD Plasma...
I have a Plasma TV with black screen and 6 red light flashes.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
May 19, 2015 | Panasonic VIERA TC-P55VT50 55-Inch
How do you to troubleshoot a Panasonic Vierra tc-P46G25 TV that does not turn on?
Check for bad capacitors (they'll look bloated) on the power supply board. Also check the voltages on the power supply board with your meter ; they should be etched on the board at test point location(s)
Jul 16, 2014 | Televison & Video
Panasonic tc-50Pu54 dinostic code...
test the ac power 2) main power ac/switch 3)fuse 15aa,and replacemente
see the diagram attached. God bless you
Jul 20, 2013 | Televison & Video
6 blinks of red light
You need to replace SC board. It will be the interior board in the set of 3 boards on one side of the set.
Feb 16, 2013 | Panasonic TC-50PX24 50 in. Plasma TV
Wont turn on clicks then clicks back off red light blink 7 times
check the capacitors and replace the power components check mother board also .. not handy with electronics and soldering call tv repairman 75-150 dollars Fix ?????
Sep 21, 2012 | Panasonic TC-50PX24 50 in. Plasma TV
Panasonic tc-p60gt30 won't turn on. Something hit screen. Screen did not crack but now won't turn on
May have damaged the PDP (plasma display panel) inside---if the panel which is fragile shorted inside it will trigger shutdown.
Aug 28, 2012 | Panasonic 60 TCP60GT30 3D Plasma TV
Panasonic viera tc-p60gt30 60-inch 1080p 3d plasma hdtv Logo
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
