I was unable to refill a prescription today and I have numereous refills remaining. On my bottle it has Refills: 5 by 02/21/17
Carafate 1GM/10 M SUS AXCA 1200 ML
SOURCE: HP PSC 2355 Won't accept refilled ink cartridges
If problem is what I think it is (that is if you cleaned whole thing and it is connected proprely), you have only one option. To buy at least three cartridges...problem is due a small trick made by HP. Printer remembers at least two cartridge serial numbers, and then wont accept refilled ones. But if you first stick one, then the other, and on the end the third one(only this one should be really full) it should reset printer and it should foul it to accept it. But on some printers it needs up to five cartridges! What a waste of money :( Anyway, hope this helps...
Posted on Sep 28, 2007
  • 13433 Answers
SOURCE: Canon PIXMA MP 500 ink refills stop working
Try to remove and reset the ink tanks
Posted on May 03, 2008
SOURCE: Brother laser cartridge refills
OK.. I agree that your problem is with the flag gear. However, there is a specific location in which it needs to be situated. The purpose of the flag gear is to trip a reset actuator on the left side of the printer. The correct position of the flag gear needs to be set so the reset actuator is depressed 3/4 of the way AND where the flag gear moves out of the way once this is done. If the flag gear is moved all the way forward, you run a risk of the gear mechanism inside not rotating it out of the way...which could leave you with a 'no cartridge installed' message. When the manufacturer of the toner cartridge made this unit, they decided to put a mark on the side to, evidently, let the assembly team know where to set the flag gear. Great for us :) On the outside plastic piece that you have to remove to get to the flag gear, you will see a diagonal line and a view window. When you rotate the flag gear, you will eventually see a portion of the white gear in that view window. Line up the white gear portion with the bottom of the diagonal line (typically two gear teeth), and you're done. Assemble and run!
Posted on Aug 01, 2008
  • 414 Answers
SOURCE: Refilled toner for ml 2245 samsung printer doesn not print
dis is quite common problem..don't panic..
did u change / replace the cartridge with original spare or refilled it??
this kind of problem often follows with an unbranded cartridge change and or refilling..!!
least chance of the defective cartridge itself causing such problem..!!
however always try to use genuine refill packs/toner.. ur system admin/vendor....
Posted on Oct 26, 2009
SOURCE: samsung ml-2240 printer is not accepting refill toners please hel
my samsung printer is model ml-2240 is not accepting refill toners please help, it is showing message that toner is exuasted, even though i refilled it, plesae help?
Posted on Nov 01, 2009
How do I lower landscape rake and keep mower up?
Just sign in to your account and click on Pharmacy. From the Pharmacy page, click on Prescription Center and then select the Prescription History tab. On this page, you'll see a detailed prescription history, including information on refills, date of last fill and amount paid. You also can print prescription records.
Apr 14, 2017 | Garden
How do I get into the pharmach to reorder my meds?
All pharmacies used to make you call in your prescription but this is rapidly changing. Today, many pharmacies are willing to reorder for you, which saves all those push button phone calls. When you pick up your prescription, ask the pharmacist if you can sign up for automatic refills.
Jan 04, 2015 | Health & Beauty
How do I reorder meds?
For meds, the pharmacy name and phone number are on the bottle or box. Also, the number of refills is listed as is the prescription expiration date. You can refill as long as the refill number is not zero and the prescription has not expired.
Note: this is different the expiration date of the medication itself which may also be listed on the label. Please ask your pharmacist to explain anything this is not clear to you..
Sometimes certain meds come in a box and the box with the reorder info is thrown away. Call your pharmacy or your doctor to find out this info.
For medical supplies, some are prescribed so the same information above applies. If they were not prescribed then you can replace them at a pharmacy, medical supply store or on-line.
Oct 13, 2014 | Medical
Refill kodak 30 cartridges
When will somebody begin mail-in cartridge refills for the Kodak 30 cartridge? I have about 10 for refills.
Larry H
Dec 30, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
I have 3 bottles of toner. How can I refill mt HP
There is no point in trying to home refill toner cartirdges unless you have an effective way of managing the waste toner. Almost all toner cartridges, including yours, have a waste toner hopper that holds the toner which was cleaned from the imaging drum that did not go on the paper. If you are unable to empty this is will eventually overflow into your printer, make a huge mess and possibly damage the machine. Also, the components in the cartridge are only intended for one time use, they will need to be replaced. If not the special coatings on them will wear off and the cartirdge will just fail to print. I would recommend high quality refills from a reputable seller who replaces parts, not just reuse, this is important to ask.
Jan 14, 2010 | HP LaserJet 1100 Printer
Did a black print cartridge refill at Costco. It
You used one of the worst refill services available. There's a reason they have a flat rate for refills, they use non cartridge specific inks, don't clean out the cartridge, and have a machine not a person do the thinking and the work for them. You will have similar failure on cartridges refilled by Walgreens, Office Max, and cheap online refills. I suggest Cartridge World first then Office Depot for refills. They have high quality standards and recycle your cartridges by refilling them.
Dec 18, 2009 | HP Photosmart 2610 All-In-One InkJet...
Refill a 564 black cartridge instructions?
Refills are not possible for this cartridge type yet. There is a chip on the cartridge that needs to be reset or replaced for the cartridge to function. Any chips for sale on the internet are technically violating patent law. Any refill kit that tells you to take the chip off your cartridge and place it on their refill is swindling you. Once the chip says the cartridge is empty it WILL NOT print, no matter how much ink is actually left. I would wait until a reputable refiller like Cartridge World or Office Depot offers refills for this cartridge before you try to fill it at home.
Nov 12, 2009 | HP PHOTOSMART PLUS B209A All-In-One...
24 people viewed this question
