Question about ProntoTec Tablets & eReaders
My prontotec 9 inch tablet is stuck on loading screen, what can I do?
  • ProntoTec Master
  • 20,318 Answers
Do a Soft Reset. Hold the Power Button and the Volume Up button until you see the Recovery Console.
If you do a HARD RESET you erase EVERYTHING, so choose carefully.
Posted on Dec 11, 2016
  • 142 Answers
SOURCE: Pin no. set in error on this tablet now we can't access the tablet at all because we ca't get past the pin no. Please help or advise how to restore to factor settings.
Do you mean that the PIN of the SIM card is locked?
The PIN is needed to access the SIM card.
If you remove the SIM card the tablet will not ask for a PIN.
You do not need to change anything in the tablet.
(If you would insert your SIM card in a phone, the same would happen when you launch the phone.)
I hope this helps.
Posted on May 11, 2014
Testimonial: "The tablet does not have a sim card. Just a basic tablet with a number password instead of a pattern. many thanks"
lion_hart44
  • 16 Answers
SOURCE: I received a gift the I craig 9 inch touch screen
Note: the different types of methods are numbered, method 1, method 2, method 3, etc.
1. When the phone is powered off, press and hold the Volume Up and the Volume Down keys both at the same time, then press and hold the Power key until a test screen that shows some available options appears, usually takes about 15-20 seconds. When that screen pops up you can let go of the keys.
Press the Volume Down key to navigate down through the options until it highlights FACTORY RESET then press the Power key to select it.
2. Power the phone off all the way, press and hold the Volume Down key and press than release the Power key, still holding the volume down key for about 10-15 seconds. When you see some additional options pop up on the screen you can let go of the keys.
Press the Volume Down key to navigate down through the options until it highlights the reset option; it usually says FACTORY RESET, then press the Power key to make the selection.
3. While powered off, press and hold the Home key, while continuing to hold the home key power the device on by pressing the Power key.
Once the Android Recovery screen appears release the Home key, then while on the Android Recovery screen, press the Volume Up and Volume Down keys both at the same time.
If/when you're on the Android System Recovery screen release all the keys, and then use the Volume down key to navigate down to the "wipe date/factory reset" option. Once it's highlighted press the Power key to select it.
Once you see the "Confirm wipe of all user data?" Press the Volume down key to highlight "Yes-delete all user data", then press the Power key to select it.
4. Power the device off, then press and hold the Home key and press and release the Power key (while still holding the Home key).
From the Android Recovery screen, press the Search key.
Tap to select wipe data/factory reset then select Ok (located in the lower left of the screen). Note: if screen is not responsive use the Volume keys to scroll and the Camera key to select.
Select Yes - delete all user data, and then select OK (again lower left).
Select "reboot system now" and press OK.
5. This is becoming a common hard reset method and can be used to factory reset Samsung's more recent Galaxy smartphones such as the Samsung Galaxy S III, the Samsung Galaxy S4, the S5, the Samsung Galaxy Note the Note II and Note 3, etc.
With the device powered off press and hold the Volume Up key the Home key and the Power key all at the same time.
When the phone vibrates (or you see the GALAXY Logo) release the Power key but continue to hold the Volume Up and Home key.
Continue holding the Volume up and Home key until the "Android system recovery" screen appears.
Use the Volume buttons to scroll to and highlight the "wipe data/factory reset" option, and then use the Power key to make the selection.
Once the factory reset is finished you may use the Volume and Power keys to highlight and select the "Reboot system now" option and the hard reset will be complete and your cell phone will be nice and squeaky clean.
Posted on May 21, 2014
gopakumarg43
  • 75417 Answers
SOURCE: Ok I got info from this site yesterday on my I
It sounds like O/S problem. Re-install the OS.
Gopakumar Gopalan Google
Posted on May 22, 2014
  • 928 Answers
SOURCE: my touch screen dosent work when i press it i have a go tab tablet
If it doesn't respond to the touch when you tap it, at any place at all, the you need a new digitizer.
Posted on Jan 07, 2015
BENTECH7
  • 132 Answers
SOURCE: HAVE JUST REPLACED SCREEN ON 9 INCH A23 ALL WINNER ANDROID TABLET BEEN TOLD IT NEEDS RECALIBRATING AS NEW SCREEN NOT WORKING CORRECTLY VIA SCREEN PRESSING EXIT SCREEN NOT TURNING OFF
Calibrate through settings. Check if the flex of a touch sensors installed properly.
Posted on Mar 20, 2015
Prontotec 7" tablet wont turn on or turn off stuck on android screen
which android screen stuck on
press and hold restart until it restarts
Nov 15, 2016 | ProntoTec Tablets & eReaders
I purchased a tablet less than a year ago, and it needs repairs. ebay states I need to contact to have this issue done
Your contract is with the seller so you return it to them. The ProntoTec is from an unknown maker, and if you got your $65 worth, you just buy a new one. This is an entry level tablet, and as far as build quality and backup service, this is why people pay $800 for an I-Pad.
Here is the review on the unit, which is not very good.
What You Won't Like...
Apr 19, 2016 | ProntoTec ntoTec 7 Inch Android Tablet Pc,...
Forgot password. How do I unlock screen?
You will likely need to do a factory reset, how you do this depends on your tablet.
Google "factory reset (brand and model of tablet)"
Oct 22, 2015 | ProntoTec 7 Inch Android Tablet PC, Dual...
Why wont windows recognise my ptontotec tablet?
No drivers installed maybe? Find the Ptontotec website and see if the support page has drivers that need installing to your computer before Windows will recognise your tablety thing
Oct 20, 2014 | ProntoTec 9 Inch Capacitive Touch Screen...
How to reset Prontotec 7 Inch HD?
Hi
Do you mean reset the Tablet? These Tablets don't have mechanical HHD they are IC's.
If you want to reset the Tablet to factory settings use a small stiff wire such as a paper clip, eye end of a sewing needle. Push it into the small hole between the earphone & HDMI sockets on the side of the Tablet. Push the reset button to reset Tablet
May 20, 2014 | ProntoTec 7 Inch HD 1024x600 Capacitive...
What is wron with my tablet?
You need to do a hard reset,, read the owners manual for that step, as far as it telling you it would go faster if you had a USB 2.0. , that means your computer is way out of date
May 15, 2014 | ProntoTec 7 Inch HD 1024x600 Capacitive...
How do i reset the pass key?
Sign onto the Microsoft website and you can do it from there.
https://account.live.com/resetpassword.aspx
May 09, 2014 | ProntoTec 7 Inch HD 1024x600 Capacitive...
Tablets & eReaders Logo
53 people viewed this question
Top ProntoTec Tablets & eReaders Experts
bobwin
Andrew Taylor
Andrew Taylor
ray gallant
Are you a ProntoTec Tablet and eReader Expert? Answer questions, earn points and help others
