Operating instructions for vivid walkietalkie n13275
Vivid universal remote codes
If your Vivid remote has a code search function, you can use it to find a code that will control your Yamaha Micro-040 device (whatever it is). The instructions for your Vivid remote may also include a procedure for searching the entire code library in your remote.
Mar 08, 2014 | Televison & Video
Midland walkietalkies -how do you put in new
You have to remove the belt clip, then the battery cover. There is a locking tab at the top of the belt clip.
To remove the belt clip, press the LOCK TAB down , then gently pull the belt clip up toward the top of the radio.
Then remove the battery cover, press near the seam and slide the cover down:
Replace the batteries, observing polarity.
Slide the cover back on until it locks in place.
To install the belt clip, slide the clip down into the slot on the back
of the radio until the belt clip lock clicks.
Hope this helps! If you need more help, please ask!
Oct 17, 2013 | Midland LXT310 2-Way Radio
Im charging up via the computer and car adaptor. It says it takes ten hours but the way i am doing it will it take longer? It keeps flashing red and the green light comes on occasionally. I have tried...
I found a manual in Google by putting in "N13275 manual" It's the first entry.
Check it and see if it's your model.
It says it has to be turned on while charging.
To turn it on (or off) press and hold the play button.
Leave it charging for a day and see if it works.
Jan 28, 2011 | Audio Players & Recorders
Can anyone supply operating instructions for cobra walkie talkies model mt800 pmr446, I bought a second hand pair but there were no instructions included, can anybody help please.
Follow this link to download/print the operating instructions for you MT800:
Bill B
Mar 13, 2010 | Radio Communications
Bought a Onix 2gb from Aldi no instructions how do
The Onix Mini Coupe I works just like a flash drive ... I am only running W2K ... I plugged it in and it was recognized ... copy mp3 files to the drive that appears in your list of disk drives. (just at the lowest (root) level). It works fine.
Dec 19, 2009 | Audio Players & Recorders
Driver for genius colorpage vivid pro scanner
Go here and choose Service & Support, then selects your exact scanner and operating system.
Nov 19, 2008 | Genius ColorPage Vivid Pro Flatbed Scanner
Genius colorPage Vivid 4x driver
Go here and select Service & Support, then select your scanner and operating system...
Nov 16, 2008 | Genius ColorPage Vivid Pro Flatbed Scanner
61 people viewed this question
