Question about Sewing Machines
Can you demonstrate threading? - Sewing Machines
Please share the symptoms of a messed up timing on a Singer Confidence sewing machine. Thank you in advance
A timing issue is usually demonstrated by the needle thread failing to pick up the bobbin thread. First, try installing a brand new needle as a bent/damaged needle will sometimes also fail to pick up the bobbin thread. You can search the internet for sewing machine timing or take it for service.
Dec 07, 2016 | Singer Sewing Machines
How to thread a NECCHI royal series machine 3204FB
How to thread a Necchi model 535 FA sewing machine [now ...
? 8:52
https://www.youtube.com/watch?v=CEGuA6kZG4A
Jan 8, 2012 - Uploaded by Wren Paasch
How to thread a Necchi model 535 fa sewing machine. I'll make a separate video to show how to wind a ...
Necchi 3215 Sewing Machine Demonstration - YouTube
? 0:40
https://www.youtube.com/watch?v=ulo4kvnj3PU
Aug 9, 2011 - Uploaded by GoldCoastSewVac
... explains what the Necchi Heavy Duty Sewing Machine can sew and ... How to thread a Necchi model 535 FA sewing machine [now with ...
How to Thread a Necchi Sewing Machine (with Pictures ...
Dec 14, 2015 | Necchi Sewing Machines
Do you have a demonstration or diagram of how to thread and install bobbin for necchi 537L sewing machine?
Try this web site:
http://www.sewusa.com/Sewing_Machine_Threading_Diagrams.htm
May not have your exact machine but one may be similar enough so you can thread your machine properly.
Nov 25, 2015 | Necchi Sewing Machines
I need a diagram how to thread this machine please the one on the machine does not do it for me Thank you
you didn't mentioned anything about the brand and model number of the machine. Any way here i have added a video which demonstrate how to tread a sewing machine
Start Sewing How to Thread Sewing Machine
http://electro-medical.blogspot.com/
If you wish to get assistance over phone, visit this site. https://www.6ya.com/
Nov 02, 2015 | Sewing Machines
TENSION??
try a different needle, thicker thread different needle, see if that will
help
Aug 23, 2012 | Sewing Machines
Loops on top of cloth
If your thread loops on the top of your project, the the problem lies with your bobbin, Just take it out, make sure the thread is thru the tensioner and try again. That should fix it.
Apr 19, 2009 | Brother LS-2125 Mechanical Sewing Machine
How to thread bobbin, insert in machine correctly. Lost manual.
go to link: http://www.youtube.com/watch?v=YL433PhG05c
a vidio is here that will show you the route to follow for your automatic threading to work. You may need to watch it a few times as it is demonstrated very quickly near the begining only once.
Jan 18, 2009 | Baby Lock Esante
Threading cassette
Make sure that the thread is threaded through the cassette properly next make sure that the needle is at its highest point. When threading the needle push down gently so its in slow motion and if everything is done correctly you will see the thread go into the needle. Its the alignment of the needle that is important. I had that problem once and it was because the needle was not sitting up at the highest point. I hope this helps. let me know if it doesn't
Sep 24, 2008 | Brother CS-8150 Computerized Sewing...
Sewing Machines Logo
26 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
