Question about Garden
How does one remove the choke knob? I want to replace the spark plug. (toro power max 724/826 OE Snowthrower)
#1 Taper
  • 1041 Answers
SOURCE: toro recycler runs like ****
You will need to disassemble the carburetor and spray with carb.cleaner. Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals and/or the jet in carb. These portals can become blocked. Replace the diaphragm as well. Reassemble and start.
If you need further assistance, just let me know.
Jim
Posted on Jun 19, 2009
kel1guy2002
  • 3740 Answers
SOURCE: My Toro Mower is running real rough, and doesn't
Hi and welcome to FixYa. I am Kelly.
Does it sound like it is running rich (Black smoke) or lean can not reach normal speed)?
In either case. Here is how to clen the carb properly:
Before you start.... if you have a digital camera take "close up" PICTURES of the linkages and springs attaching to the carb. If this is your first time you will be so glad you did. You can always delete them later if you don't need them. :)
Here is what you need to do:
1. Fuel selector off
2. Remove float bowl mounting screws and nut
3. Remove the BRASS Jet / Orifice in the very bottom of the venturi tube inside the pickup tube. (Flat blade screwdriver) Hold the Orifice up to the light. You should see a pinhole. If it is not clear clean the orifice but do not force anything through the hole.
4. Underneath the Orifice there is yet another BRASS tube that you need to remove. (Flat blade screwdriver) Make sure all of the holes in the tube are clear. The tube will be over 2 inches long. Clean it and reinstall it.
5. Reinstall the Orifice.
6. Using a catch fuel container turn on the fuel selector. Fuel should flow at a good rate. GENTLY lift the float assy level and make sure fuel flow shuts off. When you drop the float again fuel should flow.
If you do not have fuel flow at this point the needle and seat will need to be inspected. Fuel selector OFF.
(The following procedure is to be done only if there is no fuel flow with fuel selector on.)
a. Remove the silver float pivot pin retaining screw
b. Drop the Float down (The needle will come off with the float. NOTE the position)
c. Inspect the tapered rubber of the needle If should be pointed. If it is not pointed then the rubber tip is stuck inside the seat.
d. Clean the seat hole ONLY if obstructed. (Easily damaged)
e. FUEL Selector on then off fuel should rapidly flow through the needle seat.
f. Renistall Float and needle making sure to get the pivot / hinge pin installed correctly and reinstall the silver retaining screw.
g. Fuel selector ON. Raise and lower float checking for free movement with fuel flow when lowered and stopped when the float is raised level.
NOTE if fuel does NOT stop when float is level you will need to bend the float tab (tab up if level is too high or tab down if level is too low) where the needle attaches to the float assy until it does.
7. If there still is no fuel flow at this point remove the fuel hose from the carb and check fuel flow. If no flow check that gas tank exit hole, fuel filter (if installed) and the selector valve assy for obstructions.
Reassemble connections.
FUEL FLOW IS GOOD
Step 8 is VERY important"
8. BEFORE you install the float bowl inspect the bowl nut. There are 2 holes in the side of the nut where it screws in to the bottom of the carb that must be clear.
9. Install Float bowl mounting screws and nut. Check for leaks.
10. Test engine.
That should do it.
Thanks for using FixYa.
Kelly
Posted on Apr 23, 2010
  • 760 Answers
SOURCE: toro s 200 snowthrower electric start when air
Can you hear the motor run when you try to start it when it's cold? If so then it could be in the drive mechanism. I had one that I thought had a bad bendix in the starter. Here it has a rubber disc that turns the starter sprocket. I removed the retainer, took off the sprocket. Cleaned everything and re-assembled, and low and behold it worked. A new starter was over $100.00. Now if yours doesn't even turn when its cold, I'd look into the starter push button, or key switch for bad connection.
Posted on Nov 22, 2010
  • 16 Answers
SOURCE: My Toro CCR 2450 GTS Snowthrower loses power after
have found that even with self propel mowers-- the brake cable is worn and makes it hard if not impossible to start.
Posted on Nov 30, 2011
  • 3640 Answers
SOURCE: toro snowthrower model # HSK 635 won't restart, stated first time, ran about ten minutes, then died, put brand new spark plug in, getting good spark, just won't fire up, even when I tried a li
check and make sure its getting fuel. when trying to start, spray some engine starting fluid in spark plug hole. just a little bit. replace the plug then try to start it. if it starts then quits then its a fuel problem. fuel not reaching engine. good-day !
Posted on Jan 30, 2012
Problems shifting toro power max 726 oe snowblower
adjust the cable easy to do , get the manual or just look good at it ,
Feb 04, 2014 | Toro Power Max 726 OE Snowblower - 37771
Toro snowthrower 38180 won't start
You have probably fouled the spark plug (got a heap of black carbon on it) remove the spark plug wash in some petrol then use a wire brush vigorously brush between the contact points on the plug then reinstall. & lastly don't forget to push in the choke when you get it fired up next time.??
Mar 14, 2017 | Garden
My Toro CCR 2450 GTS Snowthrower loses power after it gets warmed up. New spark plug and fresh gas with proper oil mix.Why?
Mine does same. Wait a half hour, restart, runs good for 20 minutes and slows again. Just had it in for a tune up. Machine is only three years old.
Dec 31, 2010 | Toro Lawn Mower With Toro Power Tools
Will not start, no spark seen, do I need a puller
First I would replace the spark plug with a new one. If that does not work, there is a little electronic ignition part that may need to be replaced.
Please let me know what you find.
Feb 11, 2010 | Toro Co M/R Blwr/Trmmr Rear Bag Kit
Engine will not stay running
Hi
When the engine stops check the spark at the spark plug.Check compression(remove the spark plug and ground the plug wire on the engine,seal the plug hole with your thumb.Operate the starter.If the compression preasure blows your thumb off the hole,the compression is adequate for the engine to run.Now priming the engine(put some gas into the spark plug hole,back the spark plug and try to start the engine.Let me know. savumihai71 regards
Dec 10, 2008 | Toro Garden
Garden Logo
122 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
