Question about Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin
Poulan wild thing chain saw rope came off
While pulling the starter rope to start chain saw it came off.how do i reinstall it?
    President:
  • 583 Answers
By the time it would take to tellyou ,you would be better to take it to any small engine work shop. it is not difficult but it is to explain
Posted on Jul 25, 2009
How to start poulan 18 inch wildthing chainsaw
Hello Wade,
There should be starting instructions on back on saw, if not its usually the same for most saws. Fill tank with proper mixed fuel. Add bar and chain oil if necessary. Pull knob out to "start" position. Pull choke all the way out. Prime unit 6 times. Place saw firmly on floor, slide right foot under handle and have left hand firmly on top handle. Pull throttle and lock it in high. Pull rope 4 to 5 times until unit pops.Then, set chock lever on half.(this is usually pushing in half way). Pull rope again 4 to 5 times until unit starts, then after 30 seconds or so push choke knob in to turn choke off. If this procedure doesn't work, give it 10 minutes or so, because unit may be flooded, then try again. Good luck!
Sep 28, 2013 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Where is closest repair shop to Gibson Island, MD 21056
Go to the Poulan service locator site at www.poulanpro.com/service-locator/ and put your location in the search box to find close service centers.
May 10, 2012 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Starter rope hard to pull. It's not smooth and takes a lot of effort.
Make sure the brake is off and retest. If brake is off and still difficult to pull, remove the side cover, chain, bar and retest. If still not right (remove sparkplug), remove the muffler and make sure that the spark arrest screen is clean and verify that the cylinder and piston look clean and smooth by looking into port. You can clean the cylinder by spraying wd40 and pulling the rope untill it all comes back out. Verify that the rope pulls smoothly before you reinstall the spark plug. If all looks good, reinstall muffler and retest. If the compression is normal, it should be rather hard to pull thru the compression stroke. Reinstall bar and chain for final test.
Oct 12, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
I have a wild thing. the rope pull starter is very hard to pull. when i take the spark plug out it is easy to pull. the saw was not used for about 4 years until yesterday. it ran for about 45 minutes fine....
one piston ring has expanded now having no or a very fine gap increasing the compression ratio causing this to happen. When the spark plug is removed it is very easy to pull on the cord in any means. A inspection is due of this engine or a new chain saw is needed
Jun 05, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
My Poulan 14" chain saw has become difficult to
If you have more questions or need additional help pleasereply below and I will get back to you. HTH & Good Luck. Lou Thank You for using FixYa. gif,gif89a%12%00%12%00%b3%00%00%ff%ff%ff%f7%f7%ef%cc%cc%cc%bd%be%bd%99%99%99zyzrur%00%00%00%fe%01%02%00%00%00%00%00%00%00%00%00%00%00%00%00%00%00%00%00%00%00%00%00%21%f9%04%04%14%00%ff%00%2c%00%00%00%00%12%00%12%00%00%04x0%c8i%2b%1d8%eb%3d%e4%00%60%28%8a%85%17%0ag*%8c%40%19%7c%00j%08%c4%b1%92%26z%c76%fe%02%07%c2%89v%f0%7dz%c3b%c8u%14%82v5%23o%a7%13%19l%bcy-%25%7d%a6l%df%d0%f5%c7%02%85%5b%d82%90%cbt%87%d8i7%88y%a8%db%efx%8b%de%12%01%00%3b
Jan 09, 2011 | Poulan 14" Chainsaw
Chain saw won't start - pull starter pulley hard to pull?
If it worked fine the last time you used it, then pull the spark plug and try pulling the rope. See if it's easier or if gas shoots out of the plug hole. I've seen this happen when the diaphram in the carb goes bad from sitting over winter. It loads up the cylider with fuel and makes it very difficult to pull the rope. If there is no fuel in the cyliner and it's still hard to pull, make sure there is nothing binding the clutch/sprocket. I've had chucks of wook lodged in there that caused it to bind the crank output, which resulted in a hard pull on the rope as well.
May 26, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
This is my second wild thing. I wore the first
Hello Ms Weem:
Will the starter cover from your first Wild Thing fit?
Have you looked at the starter cover on a different new Wild Thing (demo)? Is it like yours?
Are you releasing the starter rope with it extended?
Yours is the first problem of this type I've heard for your saw. There is no pulley guide or starter rope thimble I'm aware of. I'd think a small nylon or teflon bushing for the starter rope could be fabricated by a machine shop but it would be at your expense. HTH
Lou
Oct 19, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Starter rope will not retract.
inside the rope pull housing is a flat spring,it may have come loose from its anchor, its an easy fix...unscrew the 3 screws on housing, lift off housing, and the rope pull is inside the casing, you will then see if its broken, or just come off anchor, 10 minute job if its just loose......
Jul 21, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Recoil spring on homelite chain saw doesn't retract pull rope
Easy suggestion would be to get new spring coil. Is it older saw? Have had to change mine on poulan saws before.
Jul 04, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Pull start on my wild thing keeps jamming
you can not pull the starter rope out to full length. Just short rapid jerks. everyone has this problem
Jan 26, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin Logo
259 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
