Question about D-Link Xtreme N DIR-655 Wireless Router
DIR-655 does not allow Avaya VOIP phone to work
The VOIP phone simply hangs waiting for a DHCP assigned IP address to be assigned to it. That never happens. The same phone works great with the previous d-link router - AirPlus Extreme G without any problems.
  • 135 Answers
You need to check the DHCP configuration on your router. Also try setting up a static IP on your VOIP phone & try.
Posted on Jul 24, 2009
Avaya 9620-ip phone DHCP conflict
Give it a static address OUTSIDE the DHCP scope.
Aug 21, 2012 | Avaya 9620 IP Phone
Main unavailalbe resetting phone
Hello Roshani Ameresekere,
Welcome, and thank you for using FixYa!
To answer your question: Your phone has lost connection to the VOIP network.
These types of phones use DHCP to assign an IP address to themselves from your VOIP network, usually by means of a switch or router. When they lose connection to this switch or router, they cannot communicate with the VOIP network and load their network environment, called PXE. This in turn loads the phone.
Try replacing the patch cable on the phone between the phone and the wall. If that doesn't resolve your issue call your Telcom Specialist who installed the VOIP Network. He will need to test the phone, switch, Firewall, and VLAN to make sure the phone hasn't died or his configuration hasn't been hosed in the router or VLAN. He may also need to reset his VOIP box.
Have a great day!
Oct 19, 2011 | Mitel 5212 IP Phone
Avaya 1616 IP phone doesn't take the router IP when assigned statically. There is no DHCP. It shows Bad router after the phone gets a restart.
bad router means that you assigned an IP in the router section, that can not be found on teh network.
You dont have a DHCP server on the network?
Sep 13, 2011 | Avaya 1616 IP Phone
I've powered my 9620 off/on, moved the phone to a different desk. I keep getting DHCP Conflict and the phone keeps rebooting. I am not able to CRAFT... does not work on this phone at this point.
Someone configured a static IP on your network. The DHCP server thinks that IP is free and keeps handing it out to you. You can either trace the equipment (workstation or phone) that has that IP or you can go into the CRAFT menu and assign a static to the equipment (please check with your network or system administrator to see what IP you can assign to your phone. Also talk to your network admin if you are using VLANs)
To get into the craft menu and change the ip address settings
1. during the startup of the phone press the * key when you see "* to Program" during initialization
2. enter 27238#
3. navigate to the ADDR menu
4. change the ip address, call server ip, subnet, router to the correct ip addresses
5. if needed change the http, https, or file server address
6. restart phone
Mar 08, 2011 | Avaya 9620 IP Phone
When I try to install my DIR-655 with the software it came with, it says that I need to reset my username and password to factory default. (This is a new router!) I've held the reset button many times...
Okay---- assuming you have a "Network Light ON" for this device and your ethernet connection shows on your computer..... Make sure LAN [ethernet} port does NOT have an assigned IP Address. It should be set to DHCP!!!!!
1.] Try address of 192.168.1.1
that fails... try 2.]
2.] If you are using Windows, get yourseld to a "Command Prompt"---- aka the old DOS Prompt.
a.] enter "arp -a" without the quote
This should show the IP Address[s] of ALL devices on your LAN. One should be the wireless router.
Nov 05, 2010 | D-Link Xtreme N DIR-655 Wireless Router
Plycom ip330 phone - works fine when connected directly to Brighthouse modem, however when brighthouse modem connected to belkin router then to phone says - waiting for network to initialize, please help
sounds like your belkin router is not setup as a DHCP server or the DHCP is disabled. The DHCP in the belkin assigns addresses to the internal network, the error "waiting for network to initialize" means that the phone is waiting for an IP address, to which its not getting. When you connect directly to your modem you get an IP from your Internet service provider. I'll bet your internal network is setup using "static" ip addresses, if thats the case you will need to surf into the phones web console and set a static IP address. Or the opposite, enable DHCP in the belkin. hope that clarifies things a little.
Aug 28, 2010 | Polycom SoundPoint 330 IP Phone
D-Link DIR 655 - DHCP server but no internet
This usually happens when the router has timed out trying to grab an IP address from your modem.
I suggest unplugging your router and modem, waiting 1 minute, plugging in your modem, wait 1 minute, plug in your router, wait 1 minute, then try to connect again.
If this solution has helped you, please take the time to rate me.
Oct 04, 2009 | D-Link DIR-655 Wireless Router
3 vlans, data,1; data 2,;voip,5. Ports carry voice tagged, and data. currently Windows 2000 DHCP server lives on Vlan 1 (AND WORKS). Need to upgrade. When we test the new servers we are unable to make both...
Here's what you need to do:
First, be sure to assign an ip address(in the proper subnet) to each VLAN.
Second, use the ip helper-address command in the context of each VLAN, the address used should be the address of the DHCP server
Third, Add a scope for each additional VLAN on the DHCP server.
The switch will route the DHCP request to the proper server based on the ip helper-address command parameter and based on the ip address of the VLAN that is passed tot he server, a DHCP address in the proper subnet is automatically configured.
Here is a sample:
ProCurve Switch 3500yl-24G-PWR# configure
ProCurve Switch 3500yl-24G-PWR(config)# vlan 33
ProCurve Switch 3500yl-24G-PWR (vlan-33)#ip address 192.168.33.254/24
ProCurve Switch 3500yl-24G-PWR (vlan-33)# ip helper-address 10.1.2.250
Aug 06, 2009 | HP ProCurve 4104gl Networking Switch
My DIR-655 won't work!
It would be helpful if you could be a bit more specific regarding the way you hooked up the dir 655 to your network and your specifc DSL modem. If the modem you are using is the Actiontec M1000 DSL modem you will not be able to obtain internet access because the DIR 655 is trying to route an already routed IP, the M1000 has a built in router / DHCP that by default is enabled. You can use option 1, access the configuration settings of your M1000 and change the WAN configuration to act as a transparent bridge. After doing so and rebooting the modem you will have to enter your DSL login information like a PPPoE username and password for example into your DIR 655 network settings. With this configuration the modem simply acts as a bridge to relay data directly to the DIR 655 and the 655 itself provides login credentials to obtain internet from your DSL provider as well as hand out IP addresses to the local network. Option 2 is to continue to use the M1000 as a router by default and disable DHCP on your DIR 655 so that it essentially acts as nothing more than a switch or wireless access point while the M1000 hands out local IP addresses. I personally would recommend using the DIR 655 to route IP's as it's got far more configuration utilities than the M1000 does as a router, and really what's the point of getting the 655 if you're only going to use it as a switch or access point when there are other simpler and cheaper devices that could do that for you.
Jul 20, 2009 | D-Link Xtreme N DIR-655 Wireless Router
Dlink DIR-655 not accessable after 24 hours
U have to tell me whether u have to unplug machines or the router
If that's the case dhcp for ur router is assigned from some other place. Weird. U have to enable dhcp of ur router. Don't allow running another dhcp from ur local systems only if it is a must. WHEN U CONFIGURE THE ROUTER'S DHCP, MAKE SURE TO SET THE LEASE TO A MAXIMUM VALUE SO THAT IT WANT CHANGE THE IP ADDRESSES FOR MACHINES.
If u assign static ips u have assign the dns and also the default gateway
Type ipconfig /all in a comand prompt and check the settings and set appropriately
Remember, don't allow any other source to assign dhcp for the router.
If this solution works for U please rate the answer
Thanks
Best of Luck
Jun 24, 2009 | D-Link DIR-625 (790069292637) Wireless...
D-Link Xtreme N  DIR-655 Wireless Router Logo
587 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
