Question about Maytag Dishwashers
I have a portable dishwasher Maytag MDC4650aww 38857877LL type 779-0 I'm trying to figure out the size connector thingy (yes I'm a girl) I need to connect it to my faucet a112 18.1m 2.26gdm8?? size
    Top Expert:
  • Maytag Master
  • 47,705 Answers
Normal tap size is 1/2 inch same as garden hose fittings for garden taps
Posted on Dec 11, 2016
2 Suggested Answers
  • 4 Answers
SOURCE: Portable dishwasher won't stay connected to the kitchen faucet
it the faucet connector has a lever u push in order to latch on to the faucet, just jam something under it so it maintains upward pressure and wont come unlatched when the water starts flowing
Posted on Feb 22, 2009
Maytag Portable Dishwasher coupler/faucet problem
Standard garden hose has same threads/adapter size.for trouble shooting run garden hose to washer try running cycle. Give it 20 minutes to finish previous cycle as it may not be trying to run what appears on settings. Water won't fill unless cycle that will allow such is chosen and active.
Dec 01, 2013 | Dishwashers
Faucet connector
Any store that sells new portable dishwashers to the public should have such.
For example: around here are, Sears, H.H.Gregg, or Best Buy.
Also, places like Home Depot, Lowe's, and Menards should be having some.
There is more than one size, so be sure you have a place where you can return the part if it does not fit.
Be blessed
There are a few different threads inside your faucet, and a few different couplings for your dishwasher.
Feb 09, 2013 | Avanti DW6W Portable Countertop...
I own a Kenmore portable dishwasher model#C110- 764400 i cant get the hose to fit on my kitchen faucet , do i need a special connector? what kind or size?
Yes. It is a special screw on adaptor. It should have come with your washer but it is available at any hardware store or at a place like lowes. Just ask the sales people. Easy to do. Read your manual!
Dec 31, 2010 | Dishwashers
I recently purchased a portable Maytag dishwasher model # MDC4650AWW. So far so good but I would like to have a user/owner manual if possible. I am not seeing this model listed and wondered if it has...
You can download the manual from the manufacturer's web site at
http://www.kitchenaid.ca/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%206-920109.pdf
Nov 16, 2010 | Maytag 24 in. MDC4000 Free-standing...
I have just purchased a used dishwasher #MDC4650AWW. They said it was 2 years old. It is a portable. I have not been able to hook up yet to see if it even runs. Please let me know what year it is and if...
The dishwasher is manufactured by Maytag. The date of manufacture is determined by the last two LETTERS in the SERIAL number. The following link explains:
http://www.fixya.com/support/r2880528-determining_age_maytag_appliance
If you have any difficulties determing the manufactured date, please post back with your serial number and I can assist you. I hope you find this information helpful.
Oct 03, 2009 | Dishwashers
Replacing drain hose of Haier portable dishwasher HDP18PA
how do i get to the hoses on maytag portable dishwasher
Jul 27, 2009 | Haier HDP18PA Stainless Steel...
Jan 30, 2009 | Maytag MDB9600A Jetclean II Built-in...
Maytag portable dishwasher is not draining
try to clean the filter by taking off the bottom section of the water jet, it might be clogged, if that does not work, u got the same problem as me, it just wont drain. The pump is probably broken.
Dec 05, 2008 | Maytag MDB9600A Jetclean II Built-in...
MDC4650AWW Portable Dishwasher
We've had a similar problem. A banshee screaming noise that's makes the skin crawl. Since our machine is well out of warranty I took the insides apart and found only a few cherry pits. (Lesson learned, always scrape your dishes before loading.) We covered out ears for a few minutes and the bad, bad noise went away. But the noise came back, it didn't stay away.. So here's what I found with more tinkering.
1. Problem: Small hard things can get lodged in the food mill/grinder assembly at the bottom of the dishwasher tub. It's there to cut up the big chus of organic matter I presume.Today I found a thin piece of plastic about an 1" long that got caught and was resisting being ground(even though we know resistance is futile) by the grinder thing. Anyway, I took the offending piece out, put it back together and the machine is working fine. I have a hunch that the first instance may have been one of those stray cherry pits that broke up enough to get caught.
2. Solution: take apart inside assemblies to get down to the "foodmill" like thingie and see if there's something hard organic or unorganic causing the noise. Discard. Put back together and hope that solves it. (It did for our machine)
3. What's needed? Good knees or a decent knee pad and a few simple tools as follows:
A. 1- medium flat blade screwdriver
B. 2- TORX screwdrivers, # T-15 and T-20, or equivalent bits for a portable electric drill/screwdriver.
C. Small pair of regular pliers or simialr tool.
D. Muttering under your breath like Fred Flintstone, or not.
4. Process:
Take out the water jet assembly. It is held by a clip at the back and top. Use the screwdriver to pry the tabs away from the clips, then pull the assembly out at the bottom where it connects. It's a simple slide in/out fit. The bottom whirlygig water jet is fastened with a threaded cap that can be removed with the pliers. (BTW, this can get clogged with gunk. while you have it of check for gunk. Then, keeping track, remove the remaining hardware with the TORX #T-20 screwdriver until you get to a round black piece. The black piece has to come off before you can remove the piece with the filter and grinding screen. Use the #T-15 bit for removal of the black piece. Then remove the rest 'till you see a "blade". Hopefully in that process, whatever was causing "the noise" will fall out and you can discard it. Observe how gross it is in there, shudder, and begin the process in reverse.
I do have some pictures of the process in stages if you want. E-mail me at: gpfn47atyahoo.ca (note: please use the "@" symbol to replace the "at")
Well, that's it. I hope it helps someone.
Have a Blessed New Year!
Greg F-N
Apr 01, 2008 | Maytag MDB9600A Jetclean II Built-in...
Dishwashers Logo
50 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
