Question about Cell Phones
My gf dropped her flip phone and now the screen stays white how do i fix that?
  • Cell Phones Master
  • 17,417 Answers
Buy a new phone or send it in for repair. They don't like being dropped as it damages the screen. If it is just the screen it will cost you 50 bucks to replace.
Posted on Dec 11, 2016
Why does my phone screen stay white?
it will be alright after 30 days. Be calm and quiet.
Aug 11, 2012 | Samsung C3050 Cell Phone
I dropped my env2 cant see anything phone still recieves messages
The problem with your phone is just flex problem, the flex on the screen of your phone is weak or worn out, this is a common problem among slide or flip phone.
What you need to do is to replace the flex on the screen of your phone, you can get this done by going to any local phone repairer within your vicinity to help get it fix or replace.
Once the flex is replace, your phone display problem is solve and the screen will start displaying.
Take care.
Jul 27, 2010 | Cell Phones
My phones screen turns white and takes long to go
there is nothing wrong with your screen, the problem is from the flex that connects your screen to the phone's main board. This flex must have worn out that's why your screen is not displaying.
The problem is common with flip and slide phones. The flex gets worn out as a result of constant opening and close of the flip or slide phone.
I would urge you to replace the flex and I am assuring you that your screen will display again. You might also be lucky to find out that the flex is not well fix, that is, it may have loosed contact.
If you cannot change the flex yourself, maybe you should take the phone to a local repairer within your vicinity, so that the flex can be fixed/replaced.
Good luck.
Apr 18, 2010 | Motorola Mobility Rival A455 Cell Phone
I856 white screen
there is nothing wrong with your screen. The problem is from the screen flex. The flex is either worn out or has disconnected from its right position.
So you need to open the phone cover and check the flex. If the flex is well fixed and the screen is still displaying white, then it means you have to change the flex completely.
This kind of problem is common with flip and slide phone. Its as a result of constant opening and close of the slide or flip phone.
Take care.
Mar 18, 2010 | Motorola Mobility RAZR V3
White screen of death?
Hello
The white screen of death is a flex problem.
The flex of a phone is what connects the screen to the board of the phone. it is found in most flip and slide phones.
When you flip and slide these type of phones after a while the flex gets weak and that causes the white screen you see.
The only solution is to have your flex changed,that will definitely solve the problem..
Goodluck
Feb 19, 2010 | Motorola Mobility Rival A455 Cell Phone
White screen on G'zOne
The flip/folding and slide mobile phone have these kind of issue. Its a matter of Flex cable (strip) that connect one display portion to the other circuitry. you need to replace/repair it.
hope u understand the matter as i described.
Dont hesitate to ask further, if required.
goodluck...
Jan 16, 2010 | Casio G''zOne Type S Cellular Phone
When you flip phone open inside screen stays white
Moto RAZR phones are notorious for this. Best thing to do - Get a new phone. Inside of the hinge, there is a sensor that detects if the phone is open or shut. When you open the phone, it still thinks its closed, so the screen stays white, and if im correct the outside display should still work. Pretty much not-fixable unless you know someone who can take it apart and re-position the sensor (will void the warranty)
Best thing to do....Upgrade.
Nov 26, 2009 | Motorola Mobility RAZR V3
I dont know what is happening, nothing happened to my phone to my knowledge, it just went to a white screen. on the white screen it says --download started-- blank then it says, emergency @ usb, then at...
buy a new phone and try real hard nt to drop it the a920 tends to pack up when dropped as it happened to my last a920 and even telecom went to repair it but it was going to cost more than the price of a replacement a920
Sep 17, 2008 | Samsung MM-A920 Cellular Phone
Samsung e900 white screen
Need a new ribbon, can be found on google about £8
Nov 04, 2007 | Samsung SGH-E900 Cellular Phone
Drop Razr and inside display screen is white
there is 1 or 2 flex cables in the phone on the flip part. ( display board) you an check & make sure those are properly seated. open the flip you will find 1 small round piece of rubber in each corner underneath is a torx 5 or 6 screw. remove those. then very gently using a flat screwdriver. pry appart the phone. u must start at the hinges. on both. sides. with the screws out, only 4 clips hold the cover on. hope this helps.
Dec 22, 2006 | Motorola Mobility RAZR V3
Cell Phones Logo
24 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
