Question about Rain Bird Hardware & Accessories
How do you reset the timer for a rainbird sprinkler system?
    President:
  • 1,273 Answers
Resetting involves reprogramming, but that's easy to do. You probably have a cheat sheet, like I do.
Unplug the timer, remove the battery, and go have a cold drink (let it sit for about 10 minutes. Reinstall the battery, plug it back in and you are good to go. Reprogram.
Regards, --W/D--
Posted on Jul 20, 2009
  • romar1345 Jul 26, 2011
    power went off and messed up the entire system
  • woobie dog
    woobie dog Jul 26, 2011
    You should have been saved by your battery, unless it was already dead. Replace the 9v. battery if it is questionable, and check the little icons on the screen (you may need a magnifying glass to see them), to make sure that the battery backup and the AC power are both on.
    The re-programming is pretty straightforward. What will help is to generate yourself a chart showing what program(s) that you are using, what each station waters and how long each is set to run. That way, if all goes afoul, and you have your chart posted near the timer, reprogramming is a snap. Other info helpful for a chart like this is the location of the control valve, and the wiring colors used. I bought a cheap set of stencils and numbered the control boxes; this made it simpler whenever I needed to check or manually test a station.
    Best regards, --W/D--
    --W/D--
3 Suggested Answers
SOURCE: I have a Orbit 57161
Manual:
http://www.orbitonline.com/lib/media/57114-14%20rF_Eng.pdf
Website:
http://www.orbitonline.com/products/Timers/02/01/19/671/
Tech service 1-800-488-6156
Timer has 4 year warranty
The manual has troubleshooting
Looking through the manual I can see potential trouble areas:
-Water pressure too high > 60 psi is ordinary household pressure > order Brady BTG pressure gauge that connects to hose
-Overlapping times are 'stacked' by timer ... but 'more than one start time' is listed as cause of stations turning on when not supposed to >> reset and re-program timer, make chart of on-off times
-Weak or missing AA batteries >> clean terminal inside timer and replace batteries
-Hard water deposits or unfiltered water clogging water valve (water softeners frequently have this problem) >>> see if vinegar or CLR cleaner can help flush water valve >>> add sediment filter in front of timer
-Fuse blown
-Bad solenoid
-A combination of problems listed above with sediment -or- solenoid as main suspects
Posted on Oct 06, 2010
  • 582 Answers
SOURCE: I recently left town for 4 days and did not set
CHECK THE VOLTAGE COMMING FROM THE TIMER TO THE VALVE WHEN THE TIMER IS IN THE ON POSSISTION IF NO VOLTAGE THE TIMER OR IF IT IS LOW VOLTAGE THE TRANSFORMER IS BAD. IF YOU HAVE POWER FROM THE TIMER THE COIL ON THE WATER VALVE HAS GONE BAD
Posted on Sep 05, 2009
Rainbird esp modular controller will not operate system -
Make sure that the transformer is supplying the 26 volts ac required by the pump relay and zone solenoids. If the voltage is there and unit still will not operate then the electronics are to blame.
Jul 22, 2016 | Rainbird Rain Bird Esp-4mi Esp Modular...
When on auto mode, the system just keeps repeating the zones.
I don't feel you can repair system by yourself. Excuse me if you can; so do it.
You should take it to an authorized Rain Bird repair service. Look for it on some listing they might have given you when you bought your stuff or contact them from here:
http://www.rainbird.com/corporate/contact.htm
Sep 20, 2015 | Rainbird Rain Bird ESP-4ME Modular Outdoor...
System quit watering. Tried man/adv and won't energize sprinkler valves. I can operate sprinkler valves manually. Tried unplugging power source to reset. Any suggestions?
Most sprinkler valves run on electricity from the timer. If the time doesn't send electricity out, the valves don't open. If an animal has chewed through a wire, that valve won't open.
You can take a meter and check the voltage on the wire at the timer. If nothing, replace timer.
If you get correct voltage at timer, measure at valve. if voltage good there, replace valve.
May 31, 2015 | Rainbird Rain Bird Esp-6tm Sprinkler Timer
Rainbird troubleshooting
Use a straightened paper clip inserted into the hole. Push to reset.
Jun 29, 2014 | Garden
Rainbird sprinkler manuals
Normally, when there is a battery for an item that has a cord that plugs into power, it is to keep "Memory" of anything programmed, in case power goes out.
Jun 01, 2014 | Rainbird Rain Bird Simple Set 6-station...
Rainbird 4TM says NO PWR
Depends if it is a indoor or outdoor timer. If it is indoor you can easily find a 24V transformer at the local hardware store. If it is a indoor timer the transformer is usually not worth trying to purchase as it will be a manufacturer item usually costing almost as much as a new timer. Replace the timer.
Apr 10, 2013 | Rainbird Rain Bird Sprinkler System Wrench...
How to fix the problem on Rainbird sprinkler timer
There is no such thing as a impact rotor. It's one or the other. If it's a impact replace it with a rotor.
May 22, 2012 | Rainbird Rain Bird Ag5 Popup Impact Rotor...
Hardware & Accessories Logo
1,577 people viewed this question
Top Rain Bird Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Rain Bird Hardware and Accessory Expert? Answer questions, earn points and help others
