Why does my heater always shut off after seconds
Heater wont shut off
its a defective fan resistor they always can be had at auto store for around 25.oo ....have a good day !! this is most always, why a heater fan does not shut down. should be behind glove box next to blower motor.
Jan 30, 2011 | 2001 Chevrolet Silverado 1500
Always we used the equiptment i have to reset the boton red.why?
I have a Honywell, Beckett motor for my water heater, I'm trying to turn it on, and it won't. The fuel reaches to the motor, it goes on only for a few seconds, at list that's what is sounds like, and then it shuts off......what could it be? Or causing the problem.
Jan 24, 2010 | Stiebel Eltron DHC-3-2 Tankless Electric...
Heil heater keeps turning on and then shutting right off. Reset interior and exterior breakers to no avail. When the unit will kick on heat does come from vents
How long do burners stay on? If they go out within a few seconds, the flame sensor may need to be cleaned. The control board you have shown is probably doing it's job by shutting down and something else is causing this. Always check your air filter first. More info needed.
Jan 11, 2010 | Honeywell International Heil Quaker...
How do I know if I have 240v when replacing old baseboard heaters
When you turned off the power to the heaters was the breakers a double (2 pole ) one? If so, then yes, it defintely is 240v. There are very few 110v baseboard heaters out there anyway. The best way to check is to have an electric meter and check it out for sure. Actually if you are working on electrical circuits and you do not have an electric meter to check if you have them shut down for sure, you are on dangerous ground. Always be safe and check before working on any circuit.
Nov 14, 2009 | Fahrenheat Electric Hydronic Baseboard...
Pool heater wont start but when i turn off the pump and start back again the pool heater comes on for 2 seconds and shuts off AGAIN
Heater must have water before it will fire up. There is a delay relay that may be dozing off. Not a bad thing but should be chk'd by a pool sevice.
May 26, 2009 | Heating & Cooling
Reddy pro155 runs for 3 to 5 seconds
Reply with the correct model number. "Pro 155" designates a series. We need to know whether you have a heater with a spark plug or a heater with an ignitor (glowbar).
Feb 01, 2009 | Reddy R155D Utility Heater
Atwood water heater problems
probly the sensor on the modul. Take and clean it off with emery cloth and then reinstall it.
Jan 21, 2009 | RTO Atwood Water Heater - 6 Gal LP
Lasko 5365 Ceramic Compact Heater Troubleshooting Forum.
Try taking a can of compressed air and spray in the vents in the front and the back of the heater. The heater has a sensor that gets dusty and causes it to shutoff to prevent overheating.
The heater should function properly once the dust is blown off the sensor.
Dec 02, 2006 | Lasko 5365 Ceramic Compact Heater
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
