How do i get auth off an play the music - Audio Players & Recorders
  • 1 more comment
  • Brad Brown Dec 11, 2016
    Hi Thresea Gibbs, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? What model number is that?
  • Thresea Gibbs Dec 11, 2016
    It is a tdk ak 400400334 molde
    I put the ipod on the dock an it was ok it played for a litte bit then it stoped then i took it off then put it back on then it come with AUTH on the sreen
If i reset my password will this get rid of multi-auth helper
No. Uninstall it from control panel and run an anti malware programme.
Feb 27, 2014 | HKC 7" Touchscreen 8GB Tablet 1GHz Android...
Motorola gleam
Hello John,
For the sake of discussion we are saying that you have the WX308 Gleam plus. Just a check, press the Centre key and the House Profiles key. Be sure that your current option is not silent or vibrate only. Select your current profile name and press options and customize to modify that profile. Now check the volume settings for that profile.
Here is a link to the quick-start page: And here is a link to the customer support website:,6722,8419/action/auth
We hope that this helps you some. If there are further problems please return here and post your findings.
Nov 26, 2013 | Cell Phones
Can't access my Facebook .It all started after downloading 7.0 I also play Candy crush
Ensure you have made changes to the native Facebook Auth in Settings. See image for solution a72d6c9c-bcd1-405c-b622-41de2a10b1ab.jpg
Oct 09, 2013 | Apple iPad (16 GB) WiFi Tablet PC
I had microsoft publisher 98 installed on my computer but the system crashed so I need to reinstall. Problem is that I purchased the software years ago and still use it to make newsletters, cards, etc....
It is not possible to install it without the auth code. You can contact microsfot and they can provide you with an auth code you can proceeed with.
Apr 05, 2013 | Microsoft Publisher
Airtel GPRS setting for Nokia Express Music
GPRS Account AIRTEL Account Name AIRTEL_GPRS APN User Name Leave it blank Password Leave it blank Auth. Type Normal WAP Setting AIRTEL Rename Profile AIRTEL_WAP Homepage Data Account GPRS GPRS AIRTEL_GPRS Connection Type HTTP HTTP Proxy Address Proxy Port 8080
Nov 04, 2009 | Nokia 5800 XpressMusic Smartphone
Need Photoshop CS3 Auth Code
We cannot generate an authorization code, only Adobe can do that. Otherwise that would be illegal. Just call into adobe and get it activated.
Sep 28, 2009 | Adobe Computers & Internet
Bose Lifestyle sound system shows "Failed 801"
your hard drive is about to fail or has failed.
If you can still play music from stored area and If you want to keep your songs thats stored on system, turn off at power point and take to bose auth repairer, they should be able to transfer songs across to new hard drive.
I have same problem, this is a common problem with bose.... not good for how much they are. Hard drive is left of cd tray, on its side.
hope this helps :)
Mar 29, 2009 | Bose Lifestyle 38 DVD Home Entertainment...
User Auth. for Mac on BizHub C250
setting up auth. on mac requires that you open the doc on appropriate app, on print menu select output method, set auth. credentials, and save. then print. some mac OSX ver. will save others won't. prompting you to set auth, every time you need printing.
Aug 26, 2017 | Konica Minolta bizhub C250 All-In-One...
RB INV DATA 0001 Error PC Charge Pro Version 5.1.0
The best solution is to have tech support remove the offending transaction from the batch, and then settle the batch. Since it is just a pre-auth, you'll need to run a post-auth to complete the transaction anyway, so it's not a big deal in this case. In the case of it being an actual sale transaction, you would have to remove the transaction from the batch, and then re-run it through PCCharge as a post-auth.
If you don't want to deal with VFI's tech support (I wouldn't either), then depending on your version, you may have more options. If it's a later version 5.7.x and up, there is a batch utility that will allow you to remove the transaction by yourself. If you are using an older version that does not include the batch manager utility, you could rename the batch file (in case you need it later) and in the case of 2 transactions, re-run them in directly in PCCharge as post-auths. Verify that the correct transactions are in in the batch, and then settle as normal. (just as an FYI, pcc tech support will not rebuild any batches with less than 50 transactions. So it might not be a bad idea to learn the batch manager and/or renaming files if you are sticking with PCC).
Jan 15, 2009 | Go Software Inc. PCCharge Pro...
26 people viewed this question
