Our Monitor will run a few minutes then goes off and flashes E 14
    Top Expert:
  • Computers & ... Master
  • 5,143 Answers
Can you put make model and what you are using to run it back on fixya so someone might be able to help you out.
Posted on Dec 11, 2016
My samsung syncmaster 920nw picuture goes blank after a period of a couple of minutes. If I turn the power off and then back on the picture re-appears but goes off again. It is not he pc since it works...
If you get a flashing screen which show your screen for few minutes and then goes blank it may be an issue with the Monitor.
Try to restart the computer and go to BIOS setup screen. If you experience the same issue in BIOS then the monitor needs a repair or replacement for sure.
Jul 19, 2010 | Samsung SyncMaster 920NW Monitor
Battery light on; then the instrument cluster goes
may be a bad alt check voltage while running should be about 14 volts
Jan 20, 2010 | 2003 Ford Focus
Monitor works for a few minutes, then flashes gray
Replace the bad capacitors in the power supply. They are usually visually detectable (tops bulged). The ones that usually good bad in that model are 1000mfd. 16v.
Dec 08, 2009 | Dell E151FP 15" Flat Panel LCD Monitor
Asus Monitor boes blank and comes back after power recycle
1. You can see images on the screen for a few minutes. That means there is nothing wrong with your computer.
2. When your screen goes blank, if you disconnect and then reconnect the monitor, it shows fine again for a few minutes before going blank (or dim) again. That means the problem is not with you video card.
3. It always shows the image after reconnection for exactly a few minutes before going blank again. yes? this means that there is nothing wrong with your cable.
Conclusion: Sorry, but you do not have many options. I bleieve that the problem is with your monitor that's going bad. Its far cheaper to get it replaced than to repair it.
Oct 04, 2009 | ASUS MW221U LCD Monitor
Hans-G Monitor monitor clicks will not power up
Sounds like capicitor could be faulty, shouldn't be that difficult or expensive to replace. What will cost you more is the labour so depends how expensive they are on that, if it's not too much then yeah it's worth fixing just ask for a quote first.
Aug 24, 2009 | Computers & Internet
Power Supply
Check all power cables plugged into M/board if these are correct
remove all hard ware
hard drives / cd player and anything else
except for video and memory and test to see if it boots. If it does, one of the removed hardware is faulty if it does not then you have M/board failure
Aug 02, 2008 | E-Machines Emachine T5026 power supply **...
Monitor image flashes off and on
Sounds like you've done all the trouble shooting. If you just need that extra nudge, I would agree... it sounds like you'll be needing to shop for a new monitor.
Jun 29, 2008 | Dell E153FP 15" LCD Monitor
Screen goes black and power light goes out after a few minutes
it would seem that one of the internal components has failed / overheated Dont open the rear of the monitor !
if pos drop it into your nearest pc repair shop and have is serviced it may just need cleaned to free it from dust build up
on the inner parts this may be causing the unit to over heat
Nov 04, 2007 | Gateway FPD1760 17" LCD Monitor
Display goes black after 5 minutes
Repairing the DELL E171Fpc LCD Monitor with the complaint of display shutdown after few seconds (power LED still on) was not difficult. Normally when this type of problem happens, we would first suspect the inverter board, then the filter capacitors and lastly the main board. A defective in one of the lamps and a faulty TL1451AC PWM IC or inverter ic may caused the display to shutdown as well. If the lamp is defective, it will send a feedback to pin 3 or 14 of TL1451AC IC and caused it to stop producing output signal thus the display just shut off once you switch it on.
Dec 09, 2006 | Dell E171FPb 17" Flat Panel LCD Monitor
Computers & Internet Logo
70 people viewed this question
David Payne
David Payne
