Question about Cell Phones
How do I erases memory to start over from today's date & time that has been entered
Date and time not saved
After the warming up machines wants the Date and time.
first you press the stop button then enter 0101 followed by "enter" button. after one mints you machines display shows
"ready 100%"
if you are switch off the machines more than 7 hrs. again ask the date and time , then do the same steps above.
if you wants to enter the correct date and time pls. enter the month as first , then date , then year. suppose you want to enter today's date
like " 06012014"
ok....
Mar 19, 2014 | Samsung SCX 4521F All-In-One Laser Printer
We have a Panasonic UF - 770 fax machine which is showing the wrong time/date. Our manual has 'gone missing' so we're at a loss. Please can you help?
Oh thats an old beast. usually when the date and time go wrong it means it has lost all its memory and requires what is called a "shipment set".
To do this you press function,7,monitor 4 times,*,6,start. Scroll down to Initialise Ram shipment set,start. It may ask if you want to reset the counter, if so say no and enter and stop to exit.
Now you can input the date and time and your ID and fax number (they may have been lost)
To set the date and time=
Function,7,1,set. enter the correct date and time and press set then stop. To enter the logo and fax number its the similar but its 7,2 this time.
Hope that helps.
May 23, 2011 | Panasonic Office Equipment & Supplies
How do you set the time? and date
Try these steps.
1. turn on calculator
2. push button labeled GT . RATE SET over to the far right for SET.
3. enter the date (i.e. if todays date is 8/10/2010) as 8.10.2010 and press the clock button
4. to enter the time, do the same thing, entering military time.
Hope this helps!
Nov 01, 2009 | Sharp EL-1801P Calculator
Hands free phone stopped working
When I had this problem, I just held down the reset button on the face underneath the volume knob (look in the manual if you can't find it).  It erased all of my visualization preferences, date, and time settings, but kept everything else and now my bluetooth works again.  I hope this isn't something that happens often, cause it will get annoying to constantly be resetting the date/time and other stuff.
Apr 17, 2009 | Kenwood KDC-BT838U Car CD Player
Backup from Samsung DVR to CD
what type of media are you using?
Note
SHR-2040 supports the internal CD-R/W.
follow this process carefully
Backup
● If there is a device, the free space and the backup device is displayed.
● Select a date, time, and camera No. to backup, and press “Start”.
● When you change Start Date/Time or End Date/Time, free space keeps updated in
the Free Space zone.
● Afile name is composed of Folder/File Name. Afolder is composed of the backup
date(YYYYMMDD) while a file name is composed of the time(HHMM).
Afile may be renamed by the virtual keyboard. Afile name can composed of the
maximum 5 letters.
● In case that more than one backup device is connected, click the box in the
bottom of left corner to select a backup device.
● If there is no backup device, Warning sign pops up. Select and connect Backup
Device in 5-8.HDD Setup and proceed the backup.
● Press the “Stop” to stop the backup.
● Pressing Cancel during the Backup returns to the upper menu but this does not
affect the backup process.
● In case of USB HDD, the AVI check is impossible.
Caution
[In Backup Process]
Pressing THE “Cancel” returns to the upper menu but this does not affect Backup process.
Press “Stop” to stop the backup.
The speed of the set may down during the backup
mj
Sep 07, 2008 | Samsung SHR-2042 4 Channel Stand Alone Dvr...
Change date on wii fit
You may have to eject the disk and erase the memory blocks and start over.
Aug 11, 2008 | Nintendo Activision Guitar Hero World Tour...
Help dont want to lose everything
The reason it is asking you if you want to delete all is because you have not selected specific files to erase, so when you hit erase without selecting a file it assumes you mean delete all.
To erase try these steps...
To erase a selected file from Folder A, B, or C:
  1. Press the MENU/FOLDER button to select Folder A, B, or C.
  2. Press the - or + button to select the file to be erased.
  3. Press the ERASE button.
  4. Press the - or + button to select YES.
  5. Press the ENTER/INDEX button.
To erase the contents of Folder A, B, or C:
  2. Press the ERASE button twice.
  3. Press the - or + button to select YES.
  4. Press the ENTER/INDEX button.
To erase a selected file from a date subfolder in Folder S:
  1. Press the MENU/FOLDER button to select Folder S.
  2. Press the - or + button to select the date subfolder.
  3. Press the PLAY button.
  4. Press the - or + button to select the file to be erased.
  5. Press the STOP button.
  6. Press the ERASE button.Press the - or + button to select YES.
  7. Press the ENTER/INDEX button.
To erase the contents of a date subfolder in Folder S:
  2. Press the - or + button to select the date subfolder to be erased.
  3. Press the ERASE button twice.
To erase the contents of a month subfolder in Folder S:
  2. Press the ERASE button three times.
  3. Press the STOP or PLAY button to select the month subfolder to be erased.
  5. Press the - or + button to select YES.
  6. Press the ENTER/INDEX button.
To erase the contents of Folder S:
  2. Press the ERASE button four times.
May 30, 2008 | Olympus VN-480 Digital Voice Recorder
I want to delete some files!
PS. here is a link to download manuals and software for this device:
http://www.olympusamerica.com/cpg_section/cpg_support_product.asp?id=1080
Good Luck ... oh and dont forget to rate my response.
Problem with saving time and date
"ready 100%"
like " 06012014"
ok....
May 23, 2008 | Samsung SCX 4521F All-In-One Laser Printer
Hp Pavilion 8860 pc memory upgrade
when you removed the battery you erased the cmos settings, you should have been prompted to press F2 or Del to enter the settings to change time and date and save. If you get no beep at start up then the memory is not compatible with your motherboard. Try one old memory stick with one new one and see if it boots, if not, theres a definate conflict, did you go to the crucial memory site first for memory upgrade information and run the scanner tool http://www.crucial.com/
Oct 05, 2007 | HP Pavilion 8860 (P2941A) PC Desktop
Cell Phones Logo
27 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
