Installing Rabbit TV in Windows 10 - Televison & Video
    Top Expert:
  • Televison & ... Master
  • 8,213 Answers
How do you connect rabbit ears to a tv
First you may need a 300 ohm to 75 ohm transformer if you have a flat wire with 2 leads coming out of the rabbit ears..you can get one at walmart, I attached a picture of what they look like...hook the 2 terminals from the rabbit ears to the transformer and plug it into the round terminal of the tv, set the tv to cable or antenna, what ever it has for settings, unfortunately though you may not get all that much with old rabbit ears as they are lower frequency pickup than the new HD channels run on.
aceb6079-dc98-4da7-926e-7d52885feaff_1.13301fb611a36dff57b92b05b4fdcbd5-j2qglkibcccvgpapoz0ib4qd-2-0.jpeg
Nov 08, 2017 | Televison & Video
Hook rabbit ears to a vizio tv
Weak signal? Try introducing a known working video source and see if set works. If so, try hooking up an antenna amp to the rabbit ears. If that gets some results you need to either get cable or a good outdoor aerial.
Apr 25, 2017 | Vizio Televison & Video
Error says please make sure your rabbit tv device is connected to your computer
if you're already registered, you can log in to Rabbit TV without the USB at rabbittvgo.com
Jul 04, 2014 | As Seen On TV Rabbit TV USB Stick
No reception with rabbit ears
Check to see if you have the "Rabbit ears" plugged into the correct spot and you are on "Analog tv" if you are trying to use digital tv on "Rabbit ears" it can't send out a strong signal like the areal ontop of a house. You may need to get an adapter to broadcast a stronger signal but even better if you can connect to roof antena.
Oct 24, 2012 | Panasonic TH-42PX6U Plasma TV
Reader rabbit software won't install
If you are attempting to install this under Windows Vista or Windows 7, it may be a compatibility issue. Open computer and right click on the cd/dvd drive and click 'explore'. Then look for 'Setup' or 'Setup.exe' and right click on it and click properties. Go to the compatibility tab and check the box next to 'Run this program in compatibility for' and select either Windows XP (any service pack) or Windows 98 if that does not work. Also check the box next to 'Run this program as administrator' and click 'OK' at the bottom. Now you should be able to run Setup.exe and install the program.
Mar 05, 2011 | The Learning Company Reader Rabbit Reading...
Digital Converter connection with old Rabbit Ears TV
First, make sure your connections are right. The rabbit ears need to be disconnected from the TV and reconnected to the converter box. Then the output cable from the converter box connects to the TV. Then try turning the rabbit ears or re-locating them near a window if the wire is long enough. You should be able to get some signal. A newer indoor antenna may help you pull in some of the weaker stations.
Jun 15, 2009 | Insignia Digital-to-Analog Converter for...
Possible to connect rabbit ears with prongs to Toshiba 27A43C ?
yes, it can be done, make a quick trip to radio shack to get the adapter you need.
please take the time to rate this solution.
Jan 29, 2009 | Sony KV-20M42 20" TV
We have a new HDLCDVD220 Sansui television. The rabbit ears antennae we were using on our old tv worked ok, but on this one. its awful. There is almost no color and terrible reception. We were told to get...
You mentioned rabbit ears for old tv, how old are the rabbit ears? Time and humidity will make rabbit ears lose connections internally. Also, if your old rabbit ears have the flat cable going to the tv you probably had to add a converter to go to the new tv. The flat cable will lose signal strength were ever the cable touches metal. Also the adapter will cause signal lose. The best bet is to buy an amplified indoor antenna. You also may try a paper clip and about 3to4' of small gauge wire put the paper clip (bend out to fit) into the center of the antenna in on the tv have the wire connected and let it hang or lift it to see how the picture improves. The problem with rabbit ears is that you have to use war time tactics. Crawl on your stomach and adjust to best picture, if you stand and adjust the signal is usually reflected off your body and will be nice until you walk away.
Jan 28, 2009 | Sansui HDLCDVD220 22 in. LCD TV TV/DVD...
Sony rabbit ears
The "Horse Shoe Like Ends" on the leads are installed under the Screws marked ANTENNA and then the screws tightened. If No Screws then your Rabbit Ears do not hook directly to this TV. Is there a connector comming out of the back that is Threaded? If YES, then this is your antenna connector (R59) and will require an Adapter for the rabbit ears. Available at Radio Shack.
Feb 04, 2008 | Proton MM2701VT 27" TV
Televison & Video Logo
44 people viewed this question
Top Televison & Video Experts
