Question about Maytag Washing Machines
Maytag centennial lid lock bypass - Maytag Washing Machines
Maytag317
  • 1136 Answers
SOURCE: maytag washer stops at spin cycle
Hi, You can get to the lid switch by removing the screws that hold the control panel to the cabinet. This model has a fuse included with the lid switch.
I hope this helps you.
Please let me knwo if I can assist you further.
Vic
Posted on Jul 01, 2009
wiringlunati
  • 576 Answers
SOURCE: how can I make the Maytag Centennial 3.2 agitate
You really can't without redesigning the washing machine.
Posted on Mar 07, 2010
jsrock516
  • 5911 Answers
SOURCE: how do I get top of my washer..Maytag Centennial
This model Maytag is actually manufactured by Whirlpool. To access the lid switch on this particular model, all you should have to do is remove the operator console. The console has a retaining clip on each side holding it to the cabinet top. To release these clips, simply take a putty knife and slide it under the left and right front corners of the control panel push straight in towards the back of the washer. The clips will depress, allowing the operator console to be lifted up. The lid switch is mounted next to the left lid hinge. Refer to the "Top and Cabinet" parts illustration, Item 6 at searspartsdirect.com:
http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Washer-Parts/Model-MVWC400VW1/3048/0153200?pathTaken=&prst=0&shdMod=MVWC400VW1
Some other websites you may refer to for parts include:
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
NOTE: If you model number does not cross reference to these sites, use the part numbers fromthe Sears websites as your search criteria. Often, the model numbers may not be included on some websites (newly added models), but the part numbers will.
HINT: In some cases, what may appear to be a bad lid switch, may only be an actuator adjustment. The acutator on these models is the rod attached to the left lid hinge. You can bend the rod slightly to adjust the contact with the lid switch, or it may be tightened as necessary. If the switch toggles (clicks) by hand with the actuator rod removed, the switch typically is not bad.
If you need to remove the entire cabinet to access under the lid, the following link explains how:
http://www.fixya.com/support/r3631789-washer_case_removal_whirlpool_top
If you need further assistance, please post back and let me know. I hope you find this information helpful.
Posted on Apr 21, 2011
caroldon
  • 17130 Answers
SOURCE: How can i bypass my maytag neptune TL aww lid
You will need to open the switch and short the switch using a wire, if what you meant is that there is a switch failure which will not start the program and so the motor will not start on the machine.
Posted on Mar 14, 2012
jamesstoner
SOURCE: want to disengage lid lock on maytag centennial
I had the same problem. The lid lock assembly is broken. If you are under warranty get it replaced. If not remove the top of the washer and take out the switch assembly. The 4 wires going in are Yellow, Red, White, and Blue. If you short the white and blue together, the washer thinks the lid is closed. If you short the red white and blue together the washer thinks the lid is closed and locked. The yellow is only there to activate the electromagnetic switch.
Disconnecting the switch assembly will not work.
The electromagnet locks the lid and it also unlocks the lid. It is not a matter of cutting the power to the magnet.
Installing 2 switches that connect the red white and blue is the best option if you want to remove the lock.
The first switch should connect the white and blue. (LID CLOSED)
The second should connect the red to the white/blue connection. (LID LOCKED)
After that the lid should work.
Please post a follow-up if this works for you.
GOOD LUCK
Posted on Aug 06, 2012
I have a Maytag centennial washer,it is 2 years old, i have no problems with this washer until now. the lid lock has stopped working,it will not start because it is not locking. So i was wondering if...
oh boy.. iVE SEEN THE LID LOCK SADDY B4, SOME PEOPLE HAVE TRIED BY PASSING THE LID SWIOTCH BY SIMPLY CONNECTING BOTH LEADS USUALLY NOT RECOMMENDED ESPECIALLY IF U HAVE CHILDREN AS THE LOCK IS A SAFTY FEATURE. HOWEVER NOT ALL LOCKS CAN BE BYPASSED IN SUCH A WAY
Jul 25, 2014 | Washing Machines
When lid lock flashes, that is an indication of a bad lid lock in some of the mvw washers.(depending on your unit and model number &error codes)
Nov 03, 2013 | Washing Machines
Washer won't start and lid won't lock . it keeps clicking and the sensing light keeps flashing
Thank you janesstone ive been looking for 2 hours trying to figure out that simple wire bypass i just couldnt find what wires did what. Your my hero for the day lol. Everyone should be able to find this answer easier just sayin
Oct 26, 2012 | Maytag Centennial Series MVWC200XW
Want to disengage lid lock on maytag centennial
GOOD LUCK
Jul 09, 2012 | Maytag Centennial 3.2 cu. ft. SuperSize...
Washing Machines Logo
27 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
