4 ft overhead LED light was working fine, but now the whole fixture is flashing when powered on.
  • yosvani gutierrez
    yosvani gutierrez Dec 11, 2016
    Hi Chuck Marchman, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
  • Chuck Marchman
    Chuck Marchman Dec 11, 2016
    The light fixture is a Lithonia Lighting LED. When I installed it last month the light would come on and worked great at illuminating the kitchen. Then all of a sudden it started flashing on and off. The pattern is approximately 1/2 a second on, 1/2 second off.
4 Suggested Answers
  • 2306 Answers
SOURCE: All 3 Error lights are flashing (4 if you count the GO button)!!
When all lights flash it's a service problem. You press and hold the go button and see what lights are on then.error light means main PCB failure, Toner light means fuser failure, drum light means laser failure. Toner and error light means main motor error, drum plus error light means its a fan failure.
Posted on Jun 26, 2009
SOURCE: Driver side dome light fixture popped free into
Did you ever find out how to remove the dome light counsel, I have the same problem.
Posted on Dec 22, 2010
  • 21 Answers
SOURCE: i was having my light
Best way is to check the manual. You can get a free download of your models manual from here
Hampton Bay Ceiling Fan Manuals
Posted on Sep 30, 2015
My freightliner 2007 columbia overhead light won't turn on when door closed , can anyone help me...
Either the bulb is burned out or the switch is not feeding power to the overhead fixture.
Oct 28, 2015 | Cars & Trucks
How to stop the flashing (strobing) lights inside both the fridge and freezer?
I had the same problem but instead of throwing a couple hundred dollars away I decided to let my lights stay on all the time inside the fridge. All I did was pop the filter switch out so it wouldn't trigger when the door was closed. No more flickering and the hole doesn't irritate me like the rave party inside my fridge did????
Apr 01, 2015 | Whirlpool WRS325FDAM 25.4 cu. ft. Side by...
How to retrofit fluorescent tube with led tube lights
First, corrosive or solubility chemicals will destroy the protective shell of lamps.
Second, the normal ambient temperature is -20 ° C to 40 ° C, if beyond the scope of this provision, it will make adversely affect on the lifespan of the product.
Third, before installing, do not connect high-voltage power supply, if there is damage to the external of lamp, switching to the engineers with qualifications for the repair and replacement; otherwise,the bulbs can not be replaced; take care of the the discharge of fire and shock.
Replacement Procedures Information:
First, the LED tube is generally a double-ended conductive LED lamp containing professionally designed built-in power supply, which can be directly input voltage AC100-240V,it can be mounted directly on a dedicated LED T8 tube light shelves, do not need to add other drives.
Second, the LED tube can directly replace fluorescent tubes, the user can remove the original fluorescent tubes and install LED tube, then double-check the configuration of lighthouse, following the figure A, B, C three installation diagram for installation.
Third, cut off the power for the installation, repair, maintenance and demolition work to avoid accidents.
Installation Guide:
led-tube-light-installation-instruction.jpgA, connect the power cord on the lighthouse to the external power lines, no need to distinguish neutral wire and line of fire fit with LED lamps , then rotate 90 °,then connect the power to light up.
B, if there is starter on light house , take out the starter, then just repeat the A
For more information about LED tube,just visit
May 21, 2014 | Acclaim PIXEL TUBE w/ 15 RGB LEDs
Flood lights in back yard not working
Which kind of flood lights? Long time lighting during whole night or security lighting sensitive to people walking across.
If it is for long time lighting, you should select the fixture lighting source as compact fluorescent, led or small wattage HID lamps, this kind of fixture you do not have priority requirement for instant on, the following fixture is just for reference.
For security purpose, you need the flood light right away reach full brightness, normally you take following fixture with halogen bulbs.
Nov 10, 2013 | Dishwashers
Replaced sylvania 26 w 4 pin in overhead light fixture and it is not working
replace the ballast almost always these lights do not usually burn out the ballasts go bad
Dec 13, 2012 | Lithonia Lighting Fluorescent Flush Mount...
I have numerous Chauvet 200b LED lighting fixtures. The problem I am having is: the "blue" LED"s on most every fixture are starting to go out. All the other colors are fine (it's just the...
Before jumping to conclusions, one should do some testing. It is posssible that you are having a DMX data error. If your lines are long, please review the need for a termination resistor at the far end of a DMX chain. The reflections of the data pulses can confuse or cause errors. Test a unit up close to your controller so the cable is short. If that magically works, install a terminating resistor.
Beyond this, electronic testing needs to be done. I did find in a Chauvet LX5 a bad solder joint at a connector that brings the power for, in my case, the green LED's. There will be surface mounted resistors on the back of the board that limit the current to groups of LED's.
If the whole fixture loses the blue at once, either suspect a DMX error or the driver in the fixture.
Mar 02, 2011 | Chauvet (2) Chauvet Ledsplash 200b Dmx...
My GE 7-Day Digital Timer model 15086 flashes on
I just bought one today and installed it. It does the same thing - flashes the lights off and on. After some research on the net, it seems that the problem is that an old house is wired with two pole wiring and the new fixtures, (timers included) are 3 pole. The conclusion I have found is that it will not work in a 2 pole wired house. There supposedlly are timers available for 2 pole wiring. I hope this helps. If you find out anything different, please let me know.
Oct 17, 2009 | Hardware & Accessories
Colorlogic Pool Light flashes like strobe
These swimming pool lights have a power-cycled feature. THis means that you can power down the light and then power back up in 10 seconds and the light pattern will change. It sounds like your light is not cycling properly. Power it down for a full 60 seconds. This will reset the power cycle. Then try turning it on and off in 10 second intervals. If it doesn't reset, you bulb may only be partially functioning and it may need to be replaces.
Jul 06, 2009 | Hayward 12v LED Color Logic Pool Light...
Tradewind range hood- model PSL736: both lights out, fan works
The screws by the lights probably only hold the fixture in place. If you took the screws out you would only get access to the fixture and maybe some wiring. If you have already replaced the lights you can assume its not the fixtures. Not likely both fixtures failed at the same time. The common problems would be the light switch. You would need to gain access to the switch and then check that for power.
You already know house power is good because the fan is working, But since both lights failed and new bulbs don't fix the problem it would most likely be a switch.
According to their website it looks like that whole front panel should come off including the fixtures and the switches.
Once you remove that you can check the wiring harness for the lights. You may also see wire nuts on the harness double check those as well.
Jul 05, 2009 | Kenmore 51840 Kitchen Hood
Televison & Video Logo
Top Televison & Video Experts
