Question about Electrolux Ovens
My electrolux in wall oven's led screen is lit up but it does not react at all to my touching any buttons. It will not turn on or allow me to turn off light
  • Electrolux Master
  • 3,095 Answers
Hello BOLD POINTS,
Would that you had a warranty I'd suggest you get the ELECTROLUX folks out there... but if your wallet is as abused as mine...
Put your model number and the parts (or "spares" (depending on what part of the planet you are on))...
You should get some control board SUPPLIERS...
With video help on several...
Just make sure to work SAFELY...
Take pictures and note what COLOR wires go to what terminal
BEFORE YOU GET IN TROUBLE...
after does NOT help.
Search Over 2 1 Million Appliance Parts
PartSelect Appliance Parts and Repair Help
ereplacementparts.com
FIND PARTS FAST
I am personally loath to recommend SEARS... but they are getting a little competitive... (so I won't)... but they do have a decent online library
http://www.searspartsdirect.com/partsdirect/brands-products/Electrolux-Parts/Wall-oven-Parts
Posted on Dec 11, 2016
SOURCE: T3 electric wall oven - Temperature set buttons
I had the same problem. The entire control panel had to be replaced. That included the display, keypad and all the hardware behind it.. it's one integrated unit. Luckily I had the extended warranty, otherwise it would have cost close to $400.
Posted on Oct 11, 2008
  • 3600 Answers
SOURCE: I have a wall oven. The burner is lit but the
It means the the thermal bulb is bad or not lined up in the oven or it's not in the flame so it won't ignite untill you hit it, use a pair of plyers to move it directly intothe flame, if it still does not work relpace the themal gas bulb controller.
Posted on Aug 26, 2009
SOURCE: I have a caloric wall oven. Ultramatic model
Hello - I have the same exact problem - how did you solve it? I read to take the burner out and soak/clean it...
Posted on Jan 17, 2010
  • 1244 Answers
SOURCE: All the possible lights on the keypad are lit and
the controller keypad needs to be replaced it has a i/c chip that controls the oven timer that is weak
Posted on Jan 20, 2010
heatman101
  • 43501 Answers
SOURCE: Electrolux wall oven not heating after self cleani...
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Posted on May 19, 2010
I have an Electrolux Oven EVEP6155A. I have a fault Code F239 showing on the screen Can you please help
this is a error for the touch controls its normally caused by moisture getting on it, theres an upgraded part you can order from electrolux which is basically just a strip of foam you fit under the touch controls to prevent moisture getting in
Dec 24, 2016 | Electrolux Ovens
Eecrolux combination wall oven / microwave is in demo mode model# ew30mc65jb
Good Morning Rolf, thanks for your post!
Based off the information you have provided your Electrolux wall oven/microwave combination is stuck in demo mode. The best way to remove demo mode from your wall oven/microwave combo is to hold the oven light button and the on/off keys at the same time and you should be able to toggle in and out of demo mode. Hopefully this is helpful. -Matt
Mar 09, 2015 | Electrolux 30" Built-In Double Electric...
How to address F14 code? Convection oven does not start.
Hey friend, thanks for your post!
I see that your Electrolux wall oven is displaying an "F14" error code. "F14" stands for display tail missing, which means you could have an issue within your main control board or keypad. I would perform a reset on your appliance which can be done by flipping your household circuit breaker off for roughly ten minutes. If that does not correct the issue I would suggest seeking a professional to come out properly diagnose and repair your appliance. I hope this is helpful. -Matt
Aug 31, 2014 | Electrolux ICON Designer E30EW75GSS 30"...
Electrolux oven racks how do they go in oven?
Hi Friend, that's a great question!
I see that your post is listed under Electrolux Wall-Oven. May I have your model number please? You can normally find the serial tag (which lists your model number) on the front of the oven, on the left side, as you open the door. With this material I can provide you the correct instructions on how to place the racks in your Electrolux wall-oven. Thank you! - Z
Jul 20, 2014 | Electrolux 30" Built-In Double Electric...
Self oven cleaner
Hi Debbie, this is AP
I understand you are having trouble getting the self-clean mode on your Electrolux ICON wall oven to start. On this model, E30EW86GSS, you must remove the rack supports in order for the self-clean mode to start. To remove the oven rack support for
a self-clean cycle, pull up the support to disengage them from the brackets. If the rack supports are not removed, the self-clean cycle won't start. If you find that this does not resolve your concern and you following the self-clean instructions precisely I would recommend contact a local authorized technician to inspect your wall oven. I you need assistance locating a technician please visit the manufacture website for additional information. I hope this information helps to some degree - thanks for your question, and please do not hesitate to reconnect if you have additional information regarding your question.
Thanks,
Mar 18, 2014 | Electrolux E30EW85GSS Oven
Touch button fail
Not to sure on this particular model but there maybe be multiple circuit boards for the touch controls or one board for the lot but sounds like you need to replace the control board that the on/off button is connected to because the signal is being interrupted and as with all Electrolux appliances it may be something you can do with just a flat blade screw driver in 5 minutes or it may take a couple of hours with every tool under the sun I would suggest getting a technician though coz it may be an expensive part and I can't do much more than a well educated guess without seeing the oven
Dec 07, 2013 | Electrolux Ovens
Hello and thanks in advance for any help!\r\n I have an Electrolux Wall oven model# E30EW75ESS that has seemingy lost its mind, or temp control at least. When I spoke with Elux they told me that the front...
Call Electrolux service and not a private service man. These appliances are sophisticated and many require proper factory training to service. Most likely there is some type of latch or a retaining key-screw that is not clearly visible to release the glass cover. Actually the cover is most likely ceramic and if so is expensive to replace if it gets broken. These can be delicate to handle.
Apr 02, 2017 | Electrolux 30" Built-In Single Electric...
Control panel doesn't light up
HI, this issue concerns the touch pad(control board led). This will happen in certain models. it could be some minor corrosion within the wire contact clips that are not allowing the proper current to illuminate the led that is used to light the specific button or, it could be a minor circuit issue within the control board as well.
i recommend inspecting the control panels wire harness contact clips that are behind the actual control board. make sure they are not corroded or lose. if they are lose or corroded, i suggest replacing the entire wire harness. this could be the possible reason for some of the lights that are not illuminating during operations.
If the wires and contacts are in good condition and the harness is in good condition as well, this could be an internal control circuit board issue, concerning the LEd lights. they may have burned out due to the age or heavy usage.(heat related)..
Please rate and god bless:)
Apr 20, 2009 | Electrolux 30" Built-In Single Electric...
Electric wall oven will not heat up
This is ovenmad from the previous post. I had a repair guy come out and he found the problem to be the Safety Thermostat. When tripped, this allows everything to work on the oven except the elements. He did not have the part with him so will return in 6 days to replace it. That should solve the problem. No idea why it tripped. The safety thermostat is located on the rear of the oven so we will have to pull out the oven to replace the thermostat. Again, this was a Frigidaire Single Electric Wall Oven made in 2004. Hope this helps somebody else.
Dec 22, 2007 | Frigidaire FEB27S5A Electric Single Oven
Ovens Logo
Top Electrolux Ovens Experts
ashburton
Mack Baxter
Are you an Electrolux Oven Expert? Answer questions, earn points and help others
