Question about Amana Refrigerators
Is there a later model amana bottom freezer refrigerator with the same dimensions as the arb2557cb
  • 878 Answers
SOURCE: Amana bottom freezer/ refrigerator
Geezer, sounds like a defrost issue. I usually find the bi-metal to be the culprit on this model. Check out the pic. You will have to remove the back panel in the freezer and defrost the evaporator. Remove the ice maker if there is one. The back cover has 4 quarter inch screws. remove those. The air vent has 2 plastic clips one each side and one on the bottom, push in and pull the grill off. The thermistor cover has a slot for a flat blade screw driver,push in and pull the cover off. The thermistor will now slide behind the back panel. Check the bi-metal for buldging. As long as the evaporator fan is working, it's probably a defrost problem.
Posted on Jul 16, 2007
  • 59 Answers
SOURCE: Amana BX22A2W - freezer works, fridge not cooling
Check the damper in the top back of the fresh food section. make sure that it is open and air is coming through it.
Posted on Nov 02, 2008
  • 1214 Answers
SOURCE: anama bottom freezer
Chances are if they are getting cool -
1) the evaporator fan in the freezer is not running
2) Defrost heater has failed
3) Defrost sensor has failed
4) Defrost timer/refrigerator control has failed.
Check for ice build-up on the back wall of the freezer. If there is ice, unplug or turn the unit off for 6-8 hours with the doors open (put any food in a cooler with ice to maintain). Note water may come out of the refrigerator/freezer.
Plug the unit back in or turn it back on, close the doors, and check temperature after a couple of hours of operation. If all OK, you will need to have the above tested, or, if you know how to use a multimeter and can read a schematic/wiring diagram, I can instruct you on how to check the above.
Posted on Jan 16, 2009
  • 161 Answers
SOURCE: Ice build up in freezer
Defrost system failure.
Defrost timer, heater, therma disk, any one could be bad.
You could manually defrost and this would get the Ref back to working for a couple of days before it iced up again. Remember there is a lot of ice build up on the cooling coils in the freezer that you can't see so, a little extra time with a hair dryer is needed to do a complete manual defrost.
Posted on Jan 21, 2009
  • 1122 Answers
SOURCE: Bottom freezer on Amana refrigerator is too warm,
is there frost building up in the back of the freezer wall?mike
Posted on Mar 16, 2009
My fridge and freezer is not cooling down the fan runs and cool some then stops tks lance
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
Nov 04, 2010 | Amana ARB2557CW / ARB2557CB / ARB2557CC...
Ice maker quit making ice
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
Oct 15, 2010 | Amana ARB2557CW / ARB2557CB / ARB2557CC...
Top fridge will not keep cold,and no air flow is present when compressor is running.The bottom freezer chest stays cold. I cleaned the coils....what should I try next?
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Sep 01, 2010 | Amana ARB2557CW / ARB2557CB / ARB2557CC...
Ice maker did not produce ice, then it started to
Aug 24, 2010 | Amana ARB2557CW / ARB2557CB / ARB2557CC...
My freezer is not freezing and the fridge is barely cold. what can I do?
first check that the thermostat is working right it may just need turning up a bit if it dont work look at the compresor,,this could be past its sell by date,,,worn out! or the freezer may need to be re-gased,, in this case scrap it?
Jul 29, 2010 | Amana ARB2557CW / ARB2557CB / ARB2557CC...
Ice maker
unplug from wire harness and unbolt from side of freezer, make sure you shut off water
Jan 15, 2010 | Amana ARB2557CW / ARB2557CB / ARB2557CC...
The compressor has died.
replacing compressor 1080 HD video. Actual service call.
Dec 24, 2009 | Amana ARB8057C Bottom Freezer Refrigerator
Freezer not keeping food frozen
try unplugging it for up to ten minutes
this particular moddel has issues with the controls getgting lost after defrost
Oct 02, 2009 | Amana ARB2557CW / ARB2557CB / ARB2557CC...
Amana arb2557cw condenser coils freezing, fridge not cooling
There are a few things that it could be. Do you mean the evaparator coil? This would be the coil on the inside of the freezer, the condenser is outside the unit. If the evap. coil is freezing, you could have to much in your freezer blocking air flow. You could also have a evap. fan not running. Check the owner's manual for the location of the defrost timer, it could be bad. The thermostat needs to be checked and set so that it is at a reasonable level. One last thing to check would be the condensate drain. Make sure the drain is not plugged or the line is not plugged. Good luck.
Jul 31, 2009 | Amana ARB2557CW / ARB2557CB / ARB2557CC...
Refrigerators Logo
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
