My screen is bright even when I turn down the brightness I have to play with the different setting to see sum what of a picture but it still glows bright
    Top Expert:
  • Televison & ... Master
  • 74,459 Answers
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center.If you wish to get some details; check the site linked here.Pull up older posts. http://electronicshelponline.blogspot.com/In most cases, the main board might have to be replaced.If so, a software [firmware] update too might be necessary.
Posted on Dec 11, 2016
How do I turn up the brightness on a HP Probook 6550b?
PLEASE RATE ME!
go to the search icon under start. search brightness. it will tell you step by step what to do.
Every laptop is different, so adjusting the brightness or contrast on your laptop may vary from the steps provided on this page. However, understanding the process of how to adjust the brightness or contrast will help you change your settings.
Most laptops adjust their brightness and other settings using the function key in conjunction with another key. For example, pressing and holding the function key (abbreviated as "Fn") and pressing the up or down arrow keys as shown in the picture below, increases and decreases the brightness.
May 09, 2011 | HEWLETT-PACKARD HP ProBook 6550b Notebook
Faint picture screen
Press the reset switch to reset the garmin, is the backlight turned off in the settings or is it possibly faulty?
Oct 27, 2008 | Garmin StreetPilot c530 GPS Receiver
Suddenly lost all picture. Left only with a bright screen.Tried changing channels and inputs, no difference. Turned set off for a while and turned it on. No picture, just a bright screen.
Hello, holl125,
I have problem like that too, Screen just turn white and bright.
Change the T-con board .
T-con board like above pic ( * just sample pic not real for that type).
You can purchase it on samsung or online market.
Thanks.
Mar 15, 2011 | Samsung LE32R73BD 32 in. HD-Ready LCD...
I would like to reduce brightness on my ASUS VH242H
Actually, the problem isn't with the drivers. Right click on the battery icon in your system tray. Select "Power Options" (NOT Power4Gear eXtreme). On the right panel, select "Adjust the display brightness." Then, select "Change advanced power settings." Scroll down and open up the "Display" box. The options that are affecting your screen brightness on battery are "Allow SmartDimmer to reduce my brightness after," "Have SmartDimmer reduce my brightness by," and "SmartDimmer full-screen video mode." Playing with the percentages in these boxes will affect how your screen brightness adjusts itself. To get my screen to stop re-brightening itself, I changed "Allow SmartDimmer to reduce my brightness after/ On Battery:" to 100%. I then changed "Have SmartDimmer reduce my brightness by/ On battery:" to 0%. Finally, I set "SmartDimmer full-screen video mode/ On battery:" to Maximum Power Saving. This should solve your screen-rebrightening problems even with the 163.44 drivers (I use those too). Please Rate.
Thanks, Anand Fixya
Dec 23, 2010 | ASUS VW193T Monitor
My Nikon D70 lcd screen doesn't display correctly the colors on the screen show in bright glowing colors, but the pictures print out great and display well on my computer screen. Is there a setting that...
You are looking at two different monitors with different settings. In most cases you will need to do some editing yourself on your computer because of the difference. Or the brightness can be done in a lab.
Mar 22, 2009 | Nikon D70s Digital Camera
PS2 Picture Problem
Hi MG86,
Most PS2 games are dark and auto brightness controls will casue your LCD tv to brighten up automatically in response the dark video coming from PS2 games. I suggest you get into the menu settings of your TV and find a setting that will shut off the auto picture controls.
Nov 23, 2007 | Sony PlayStation 2 (PS2) Console
Screen too dark even with all brightness settings set to max
The picture is very dark it is mostly due to 1 power supply output is low. 2 voltage on crt g2 pin is low. 3 video output supply is low. 4 some components in luminance section might be defective or loose. 5 finally crt getting weak is set is old. good luck
Sep 21, 2007 | JVC AV-27430 27" TV
Brightness of picture
If you feel good about opening your set then you can try this: Look for the flyback (high voltage) transformer, with the thick red wire which goes to the top of the picture tube. There are 2 controls on the flyback transformer, focus (top) and screen (bottom)Turn the brightness and contrast all the way down and then increase the screen control until you see retrace lines, and then back it down until those lines just vanish. Return the brightness and contrast to normal and adjust the focus control, if necessary, for a nice sharp picture. Let me know if that brings your brightness back.
Aug 21, 2007 | JVC AV-27D104 27" TV
Acer AL11511
To even things out you need to use the controls on the monitor to lower the brightrnes. to acceptable levels. When playing a DVD there are seperate controls in the software and your graphics driver to adjust the Video Overly settings. Look for settings called gamma and brightness in the video overlay settings in the windows display properties panel. This should help even things out some. Deal is to crank down the brightness on the monitor and crank it up in the video settings in windows. It will make the DVD's brighter and rest of the time the regular screen darker.
Jun 26, 2007 | Acer AL1511 15" LCD Monitor
Photos are too bright, almost white....
camera makers would like to use flash lights as bright as the sun, so the flash is fine. the problem lies in the exposure time. continue trying different exposure settings. most makers provide these as pre-programmed settings while some offer manual fine tuning.
May 25, 2007 | Fuji FinePix S5000 Digital Camera
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
Electro Med Services...
