Question about Westinghouse Refrigerators
Westinghouse refrigerator leaking , dripping water and accumulates near bottom at fruit n veg basket. Some time it also forms ice layer on glass of basket. Any solution?
    Master:
  • Westinghouse Master
  • 610 Answers
You have a clogged defrost drain tube, beneath the freezer evaporator (remove the back wall of the freezer compartment) there is a drip tray with a hole in it, the hole leads to the defrost drain tube- take a turkey baster and flush the drain with warm water until you hear it pour into the pan beneath the machine... Help Me Find My Model Number
Posted on Dec 12, 2016
Ice build up under vegetable and fruit bins
Pull the bins out. Just above them is a channel with a hole in the middle. Push a drinking straw in the hole to clear the drain. The water will drain away instead of dripping under the veg bins.
May 04, 2017 | Refrigerators
Mw Daewoo fridge freezer FRS-20321BE is leaking water copiously from the refrigerator I cannot see any source for this but puddles form and flow internally under the veg box. Help!
All depends on how much water is collecting. A lot of water indicated a leak from the ice maker. A small amount and it's probably a clogged condensate drain. Here's a YouTube video on a different brand showing a clogged drain, your may be similar (or not), but it might give you an idea as to where to look. Refrigerator dripping water inside FIX
Mar 07, 2016 | Daewoo Refrigerators
We have a whirlpool gold bottom freezer refrig. that has been leaking moderate pools of water on each side of the refrig. It also has ice that forms on the floor of the freezer behind the baskets. We took...
Do you have a thin layer of ice in bottom of freezer? If so, its a clogged drain - drain located "behind" back wall in "freezer" side (bottom).
If not, may be a broken or leaky water line or water valve - best serviced by an appliance repair technician... GL
Please rate us 4 thumbs up!!!! Tips Provided by: GOFAR Services, LLC - Refrigerator repair Houston, Katy, Spring and Woodlands, TX!
Aug 29, 2011 | Whirlpool GI7FVCXWB (27 cu ft) Bottom...
There is layer of ice that has formed at the bottom of the freezer side. Due to this there is a leak of water that appears every two or three days. I cleaned the layer of ice once and after 2 or 3 weeks...
Sounds like the drainage hole is blocked with ice, i normally take the back cover off the freezer and at the bottom you will see a build up of ice at the bottom, turn freezer off and carefully remove as much ice as you can, then pour some boiling water over the excess ice and in the middle you will see a drain hole make sure water then freely flows down drain hole. Other than that you could try switching your freezer off for 24 hours to clear ice.
Nov 02, 2010 | Maytag MSB2654HE Side by Side Refrigerator
Water leaked from below refridgerator. Drip pan was not full. where woudl water come form and why? Unit is not eve 1 year old. mdel # KSCS 25 FVss
The evaporator coil is in the freezer. When it goes into defrost, that water should go down a drain in the freezer into the drain pan. Open the freezer door and see if there is any ice in the very bottom of the freezer compartment. If so, then the drain may be clogged and will have to be cleared. It is necessary to remove all of the racks and baskets to get to the sheet metal that covers the coil. Remove that panel to get to the evap coil and look below it to find the drain. It may be necessary to use a hair dryer to CAREFULLY melt any ice. Be careful not to melt the plastic liner. When you think you have the drain cleared, check it with a large glass of hot water.
If there is no ice in the bottom of the freezer, take the grill off the bottom of the fridge to see if there are any leaks under the fridge.
Could also be a pin hole leak in the water supply line to the fridge.
Mar 03, 2010 | KitchenAid KSCS25FVSS Stainless Steel Side...
Refrigerator is leaking/dripping clear water, but the ice maker lines have no leaks and it appears to be coming for the middle of bottom of the box somewhere.
You may have a leak from the water supply line that is attached to the fridge from the house hold line near the bottom right corner of the fridge.
Jan 29, 2010 | Westinghouse WRS3R3EW 33" 22.6 Cu. Ft....
Samsung RFG297AA Thin Film of Ice Forming Under Deli Drawer
My be an air leak,wipe/check all seals on doors and make sure doors are closing tight on seals.
Jul 24, 2017 | Samsung RF265AA Bottom Freezer French Door...
Water is dripping inside refrigerator
This ia a common problem that indicates the drain from freezer is clogged or blocked. I will send you to another link to help explain how to resolve this, Thanks, Sea Breeze
http://appliancejunk.com/forums/index.php?topic=22.0
Apr 27, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Bracket holding glass over fruit / veg compartment broke
http://www.partselect.com/Schematics/Maytag/54436.gif Maybe this diagram will help you. www.partselect.com I just replaced the Crisper Shelf Frame. I received it very quickly. I am now looking for some sort of support for the whole shelf, because it still seems to be sagging. I may have to invent something. If anyone out there has a solution, please post it.
Aug 26, 2008 | Amana ARB2217CSR Bottom Freezer...
Kenmore Elite 795 75542401
I replaced my "entire" ice cube maker (tube,hoses,water pump, ice maker) and it still pooled water at the bottom. I removed the back panel in the freezer and noticed the ciols go through a defrost cycle and water forms in tray under coils. I removed the lower panel on rear of fridge -and found a drain hose near the water solenoid/pump. I blew compressed air into the hose and hopefully unblocked it so it can drain into the pan not the freezer.
Jul 16, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerators Logo
49 people viewed this question
Top Westinghouse Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Westinghouse Refrigerator Expert? Answer questions, earn points and help others
