Question about Smart Computers & Internet
How to charge the battery on the smart tv - Smart Computers & Internet
What ampheres can be used for samsung LN40D550
  • Triple smart USB ports quickly and easily identify yours mobile devices, to provide optimal charging efficiency.
  • Built-in charging circuitry fully protects devices from any short circuiting,over-heating,over-charging,and over-currents.
  • Provides maximum 2.4A charge speed.Three USB ports offers rapidly charging of smartphones,tablets,and other devices.
  • Adopts highlight design with smooth surface, effectively prevent the scratch,to ensure that the beautiful appearance of the product.
  • Strong compatible:Apple and Android Phones and Tablets,Apple iPad Air,iPad 2,iPad 3,iPad Mini,iPhone 6 Plus/6s plus/7/7 plus Samsung/Nexus and More,HTC,Samsung,Motorola Android Phones and External Battery.
AmanStino Car Charger Quick Charger USB 3 0 3 Port with Smart Sense IC...
Feb 25, 2015 | Samsung LN40D550 LCD TV
Hitachi tv keeps turning itself off & on every 5 mins
First thing to check would be the remote, make sure the batteries have fresh charge. I would try that first before I look to a problem with the TV itself.
Feb 08, 2015 | Shopnbc Hitachi 1080p 3D Smart LED TV w/...
Just bought a Samsung smart tv and a pair of brookstone wireless tv headphones, however after setting the transmitter I am unable to get any sound on the headphones. I do not have a cable box or gaming...
try your headphones on another device to ensure the headphones are not the problem. ensure any mute or volume switch on the headphones are turned up. and ensure the batteries in the headphone are charged. check attn try both 0 and -8db setting,
check both headphone outlet and tv speaker outlet of smart tv. in TV settings ensure the audio out setting is set to ON so that the jacks for audio to external speaker are switched on.
i hope this was useful.
Dec 26, 2014 | Audio Players & Recorders
Whats the limit on charge time for a GPX TD730 Portable DVD/TV?
Consult the manual for sure but usually theres a light that will be red or flash while charging and be solid when fully charged. A good rule of thumb is drain the batter6 as close to 100% as possible as often as possible and charge for 12 hours. It has a smart charge system in the unit that do3snt allow overcharging but you can kill the battery by using it while plugged in all the time
Dec 20, 2014 | Televison & Video
What does the code F02 mean for a smart battery charger
It means one of two things. Either you do not have a good connection from the charger to the battery, check and clean the clamps and terminals, or the battery has too low a charge. A smart charger needs to measure the existing charge before it will work.
Aug 24, 2012 | Black & Decker Tools & Hardware - Others
Wont start
Your battery is junk. Replace it.
Lead/acid batteries lose about 1% of their charge per day, so in 90 days of non-charging they are basically discharged. This is a bad thing. When winter comes, put a smart trickle charger on it, or at least once a month put a non-smart trickle charger on it for a couple hours or an afternoon so you keep it charged up.
I love/hate batteries.
Apr 30, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
The batteries on my narrow boat ran low and the inverter appears to have cut out. We have recharged the batteries but there is still no power output. The inverter is live because there is a low power...
It's quite possible that you are charging your batteries with a "smart charger." The problem with some smart chargers is that when a battery is drained below a certain voltage, the charger assumes the battery is a lost cause and stops trying to charge it. You may have to get a cheap "dumb" charger to bring the batteries up to a reasonable voltage before turning things back over to the smart charger.
Dec 28, 2008 | Electronics - Others
Battery fails to charge completely
It sounds to me as if your battery is faulty. No way should it take 17 hours to charge. The battery is abviously not absorbing the charge and this could be because one or more cells are defunct. You can just wait until it fails completely or look at getting a replacement before this happens.
Please remember to rate this solution.
Nov 02, 2008 | Gateway CX200S Tablet PC
Computers & Internet Logo
114 people viewed this question
Top Smart Computers & Internet Experts
Computer Links
NOEL
NOEL
Pcm2048
Are you a Smart Computer and Internet Expert? Answer questions, earn points and help others
