Question about Winter Sports
How do you adjust clutch on a Polaris snowmobile
4 Suggested Answers
  • 12 Answers
SOURCE: 2003 polaris 550 trail touring,revearse not working
the high idle could be a dirty needle check your carbs i have that problem with my 550 rmk the reverse light could be your wire harness check your wires with any wire tester idk the specs for it but also clean your connections with some electrical wire component cleaner and use so di-electrical grease if all else fails you may need to bring it to a mechanic for a small fix like that it should run up that high
Posted on Aug 14, 2009
  • 35 Answers
SOURCE: how do I adjust the throttle on my 1996 Polaris
follow the cable down to the carbs, where it meets, there will be a threaded kind of bolt with two nuts on it. you ajust it by loostening the base nut, and threading that bolt looking thing into the pice of metal it sits in, when you are done, tighten the nit back down to prevent it from vibrating back out
Posted on Feb 19, 2010
emissionwiz
  • 75051 Answers
SOURCE: 1996 Polaris xlt 600 snowmobile carb slide adjustments for sync
This is the same as doing any slider type CV carb, no matter the machine. Check the link. How to Carb Synching
Posted on Jan 23, 2017
Start up idle is slow below 1050 rpms and sounds like going to stall while idling. Runs fine otherwise.
How to adjust your Polaris Snowmobiles TPS. - YouTube
? 6:05
https://www.youtube.com/watch?v=aEPx7OsywNk
Dec 11, 2009 - Uploaded by PolarisRich
A quick video on how to adjust your Polaris Snowmobiles Throttle ... TPS cause this? it seems like it hits top rpm, it runs flawlessup to the ... Would this work on a 2011 Polaris pro rmk 800?? ... I have a 2006 Polaris Fusion 600 h.o. It seems to bog out when u first start ... Sounds like its a carb or clutch issue!
2011 Pro RMK 800 Top End Bogging [Archive] - SnoWest Snowmobile Forum
www.snowest.com/forum/archive/index.php/t-298871.html
Jan 30, 2012 - 52 posts - ‎33 authors
[Archive] 2011 Pro RMK 800 Top End Bogging Polaris: Pro-Ride. ... Sled is a 2011 ProRMK 800 155, 1700 kms, MBRP can. ... problems with bogging at every rpm and roughidle, I am running 91 from .... fuel filter yet?...almost sounds like your fuel pump can't keep up with ..... I am running a 2010 660 CFI-4. 2010 dragon 155 RMK electrical problems
Feb 3, 2013
Polaris update
100+ posts
Nov 15, 2009
~~The Official Phazer Thread~~
100+ posts
Sep 12, 2009
M1000 Hiccups on the Bottom
100+ posts
Jan 28, 2008
More results from www.snowest.com
Jan 12, 2016 | Polaris 2010 RMK 800 Dragon 163-Inch
Can the timing be set on a 2012 polaris 550 snowmobile
no. and you should not need to. Just reassemble and it will be set.
Mar 01, 2015 | Polaris 2012 LXT 550 IQ
Polaris clutch
Need more information
Primary or Secondary?
What is wrong?
need more information
Jan 02, 2014 | Polaris Interactive Toy Concept Polaris...
Why does 1997 500 indy asilate on take off is it the clutch
YES IT COULD BE A CLUTCH, JACK SHAFT OR DRIVE SHAFT BEARINGS. ALSO SHECK YOUR CHAIN AND TRACK TENSION
Nov 14, 2010 | Polaris New Genuine Polaris Snowmobile...
How do i remove the drive clutch on an indy sport touring 440 1996
you need a clutch puller, Take out the center bolt and the clutch puller will thread into the same hole,as you tighten it up it pulls the clutch off; Good luck
Jan 26, 2010 | Polaris New Genuine Polaris Snowmobile...
How do I adjust the throttle on my 1996 Polaris snowmobile?
Jan 11, 2010 | Polaris New Genuine Polaris Snowmobile...
I was full throttle going across a lake when boom the snowmobile stalled and dropped down. I opened the hood and the primary clutch was in 3 pieces and the belt was in pieces. Tell me what it would have...
those 900s had a recal for many things, one of which was very poor cooling to the clutches, they recalled them and put aftermarket vent kits, your clutches got really really hot and came apart
Dec 17, 2009 | Polaris New Genuine Polaris Snowmobile...
Winter Sports Logo
102 people viewed this question
Top Winter Sports Experts
Arnie Burke
Arnie Burke
Todd Arndt
Todd Arndt
Are you a Winter Sport Expert? Answer questions, earn points and help others
