Question about Philips 32PFL3403D/27 32 in. LCD TV
My Philips tv wont turn on. Model # 32PFL3403D/27 checked fuse in the back and its good. I here a faint noise coming out of the main bored. Is there any breakers or reset buttons or in line fuses?
    Top Expert:
  • Philips Master
  • 75,178 Answers
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center.If you wish to get some details; check the site linked here.Pull up older posts. http://electronicshelponline.blogspot.com/In most cases, the main board might have to be replaced.If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first.If it does not help you, replace the main digital board.There are two methods to reset TVs.The first is simple to do; a Hard Reset.The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset.If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option.If you wish to get some details; visit the site linked here.
Posted on Dec 11, 2016
Slinteriors
  • 8617 Answers
SOURCE: Won't power on
yes all sets have a fuse, But its unlikely that if the fuse is blown replacing it will fix the set, as usually a short exist when a fuse blows. Post the make and model of your set and i should be able to post a link where you can get a service manual and some free support to help you diagnose your sets condition.
Posted on Mar 26, 2008
satavlad
  • 405 Answers
SOURCE: my sharp aquos lc-c3242u turned itself off and now
If power light continuously flashing it means backlight problem. Two possible causes. One, backlight invertor is faulty. Two, but realy rare, one of the CCFL lamps went bad.
Posted on Dec 02, 2009
SOURCE: Samsung model ln40a450c1d.TV is dead.
Some power? I would recommend you should get a sams photofact reference on your set and find out what voltages you should have at all exit points from the power supply.
I did find this entry on some people who had similar problems.
If you are handy with a soldering iron and not afraid to take apart the set give this a try!
Because the Samsung LNS4051D would not turn on and the power LED would blink 4 times and the relay would click and this would repeat again and again. I replaced power supply board parts CM806, 811, 812 & 817, all 1000 uf 10v capacitors, three had their tops bulged up slightly that I missed on initial visual inspection. After seeing the reports of problems with these caps on http://www.fixya.com/support/t1336881-will_not_turn_or_off , I replaced them with Radio Shack part 272-1032, 1000 uf, 35v. They are slightly bigger, but fit OK. TV is working fine now. Cost was 4 x $1.59 = $6.36 plus the time. I saved between $100 to 300 in the process of either replacing the board or getting the unit serviced. If you are not comfortable replacing components which means using a soldering iron, you can replace the power circuit board, available from http://www.discount-************/ProductDetails.asp?ProductCode=1030952-SAMSUNG&&Click=46
Posted on Oct 11, 2010
Testimonial: "Tried the 1000uf at 35volt Capacitor replacement and my TV came right on. They were slightly puffed up. Thanks very much.. Saved a lot of money...:) "
ginko
  • 19396 Answers
SOURCE: how do I test the y-sustain main board from a
Hi.
As such boards are cheap and fail quite easily (both the two sustain and the buffers) Philips service manuals are more oriented at board swapping then at proper testing. In this particular case the buffer boards fail very easily because of a bad soldering to IC. The short will regularly blow the main sustain board.
To start when a main sustain (e.g. Ysus) is fried the TV will go in protect mode with the led flashing in standby. One test is done disconnecting the Sus board (with power off) and restarting the TV. If TV does not go in protect, then the sustain board was good.
If there is no protection:
The first thing to check on a main sustain board is the fuse. If the fuse has blown the IC is probably fried.I believe fuse is F5004. Check for swollen capacitors that may have blown. Test the FET. That is the core of the board as it is the power amplifier.
Here the service manual:PHILIPS_SM_15540.pdf - Right Click "Save Target As"
Here a more useful service manual. Check and follow troubleshooting diagrams in manual.
Here some troubleshooting from users.
Note:if buffer board was shorted, then the main sustain board is usually faulty.
Regards.
Ginko
Posted on Sep 13, 2011
SOURCE: Turn tv off wont turn back on ! Model#32AV502R TOSHIBA
Green light is blinking someone help please, just bought it
Posted on Dec 23, 2011
I have a Philips Model 32PFL3403D/27 When turning on with tuner signal available it blank's out but it does not power off.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Oct 28, 2016 | Philips 32PFL3403D/27 32 in. LCD TV
Why will my 32PFL3403D/27 Philips will not power on
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis.
If the main board have shorted component/s [damaged]; this kind of fault can occur too.
Contact the authorized service center for Philips.
Jul 30, 2014 | Philips 32PFL3403D/27 32 in. LCD TV
Fuse blow
It happens sometimes...
Due to voltage fluctuations..Dont worry/..:P
Keep changing
Jul 16, 2012 | Philips 32PFL3403D/27 32 in. LCD TV
Trying to adjust my Philips TV's Custom Color Temperature
Philips 32PFL3403/12 problem with colours, after 1 hour working: starts to mix colours.
Feb 20, 2010 | Philips 32PFL3403D/27 32 in. LCD TV
Power light blinks red like 3-5 times and wont cut on
Pull the back out and check the SMPS. Check the main fuse to the AC line first.
May 25, 2009 | Philips 32PFL3403D/27 32 in. LCD TV
Attempting to connect PC to Philips 32pfl3403d TV, getting no sig
I had the same problem had to buy a s - video lead then when connected hold in function button n f4 to send the signal
Mar 16, 2009 | Philips 32PFL3403D/27 32 in. LCD TV
Philips flat screen tv will not power up.
Symptoms of a Defective or dying Power supplies on LCD TVs.
1. Light(s) on the front panel are behaving not normal example, blinking, amber color or
not steady, fainting, etc.
2. TV not turning ON properly.
3. TV turns OFF by itself.
4. Needs to be unplug to many times to make it work.
5. Humming or high pitch noise heard through speakers or at the back of the TV.
I repair these power supplies. Write to jah2mil@hotmail.com if you require further assistance.
Dec 20, 2008 | Philips 32PFL3403D/27 32 in. LCD TV
Philips 32PFL3403D/27 32 in. LCD TV Logo
185 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
